Author Topic: NT19 bluetooth Numpad  (Read 13694 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Sat, 25 June 2022, 00:51:32 »
NT19 Bluetooth Numpad
2.4G Mode Connection Tutorial
When you first connect with 2.4G Mode, pls switch the battery button(at bottom of the case) on first, then press FN+4 for 3 sec to make sure the 4 key green LED is twinkling, then plug the 2.4G Adapter in, NT19 will match the adapter automatically.
Pls don't plug the 2.4G Adapter in before you press FN+4, otherwise NT19 cant find it.
Bluetooth Connection Tutorial
Make sure your keyboard is not connected to a cable
Turn the battery button on(at the bottom of the keyboard)
Press Fn+1 or 2 or 3 for 3 sec, make sure NT19 is in pairing mode
Then search Bluetooth device on your mobile device and connect with NT19, next time, you just need to press Fn+1 or 2 or 3 to change with different devices.
LED Control with Combine Key
FN+* key = change LED effect
FN+ plus key = increase brightness
FN+ minus key = decrease brightness
check video here
BUY IT NOW
« Last Edit: Sat, 25 June 2022, 00:55:49 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: NT19 bluetooth Numpad
« Reply #1 on: Sat, 25 June 2022, 00:56:39 »
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #2 on: Sat, 25 June 2022, 00:57:32 »
