Author Topic: Which ancient keyboard is this?  (Read 4652 times)
Offline NewbieOneKenobi
« on: Thu, 23 September 2010, 08:32:39 »
It must come from the Neolithic, judging by the layout. Designated as C2. Probably older than F by some, isn't it. Somebody surely must know more about this. Or whether it can be made to work on a modern computer and with how much hassle.
http://allegro.pl/1032-zabytek-klawiatura-ibm-oryginal-i1244332289.html
I've just bought it for $8.
« Last Edit: Thu, 23 September 2010, 08:39:31 by NewbieOneKenobi »
Offline Shawn Stanford
« Reply #1 on: Thu, 23 September 2010, 09:24:30 »
It's an old mainframe terminal keyboard. I don't think they're PC compatible without significant work.
The Brat Prince of COBOL
« Reply #2 on: Thu, 23 September 2010, 10:14:37 »
Thank you. Well, at worst I'll keep it for spare parts. Wonder how the keys feel.
« Reply #3 on: Thu, 23 September 2010, 14:17:40 »
IIRC: Everyone who has one of these says it is amazing.
Offline ch_123
« Reply #4 on: Thu, 23 September 2010, 14:47:37 »
It's a Model F keyboard for the 3178 Model C2 Display Terminal.
« Last Edit: Sun, 26 September 2010, 03:56:48 by ch_123 »
« Reply #5 on: Thu, 23 September 2010, 15:02:40 »
Thank you, sirs. Is there a way to make it work with a PC (USB) without being a physics major or do I keep it for spare parts? I don't dabble with cables but I have a friend who could help me if it were as simple as to wire the cables into a different plug and then use a premade converter (and then another) or cannibalise the USB or PS/2 controller from the cheapest Logitech or Microsoft.
He did turn a radio adapter into computer speakers for me or cut a LAN cable to give a speaker an additional yard, or install two fans on a single plug etc. for me, so if the operation doesn't require more skill, we should be able to pull it off.
Quote from: Shawn Stanford;225886
Perhaps transplating the alpha key springs into an M could be worth it, just to see what I get.
« Last Edit: Thu, 23 September 2010, 15:13:27 by NewbieOneKenobi »
Offline WhiteRice
« Reply #6 on: Thu, 23 September 2010, 15:04:28 »
You want an electrical or computer engineer actually.
Offline ch_123
« Reply #7 on: Thu, 23 September 2010, 15:11:38 »
Quote from: NewbieOneKenobi;225911
As pointed out above, you'd probably need to be very experienced in electronic engineering matters. It hasn't been done before, and given how completely different the signaling is to modern keyboards, it is not a trivial task.
It's been tried before, it won't work. The springs and hammers are too different.
« Reply #8 on: Thu, 23 September 2010, 18:09:50 »
Unicomp is selling some keyboards of the 122 kind and there's the magical word "emulator" there. Wonder if they wouldn't, say, have designed a makeshift converter already, such as in order to be able to test those on a PC.
Offline Oqsy
« Reply #9 on: Thu, 23 September 2010, 21:08:03 »
crooked keycaps are crooked.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline ch_123
« Reply #10 on: Fri, 24 September 2010, 03:53:32 »
Quote from: NewbieOneKenobi;226000
The terminal emulator keyboard is just a standard PS/2 keyboard with extra buttons. All the emulation is done in software.
Quote from: Oqsy;226071
Model F keycaps have a lot of 'wiggle' in them due to the way that barrels are mounted.
« Reply #11 on: Fri, 24 September 2010, 18:56:56 »
Another find:
http://www.aukcjoner.pl/gallery/003412217-.html#I1
But this one looks very, very odd, despite the five pins in the plug...
Offline Hak Foo
  • Make America Clicky Again!
« Reply #12 on: Sat, 25 September 2010, 17:32:41 »
seems like a language swap on that Sanyo MBC-555 someone posted a while ago.  Love the unlabelled keys, and the symbol for shift.
Overton130, Box Pale Blues.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #13 on: Sat, 25 September 2010, 17:40:35 »
Quote from: ch_123;225896
It's a Model F keyboard for the 3179 Model C2 Display Terminal.
As such, this thread should be worth reading.
« Reply #14 on: Sat, 25 September 2010, 18:07:42 »
Quote from: Hak Foo;226790
Does the 5 din possibly yield to an AT>PS/2 converter?
Quote from: keyb_gr;226794
Thankee.
« Last Edit: Sat, 25 September 2010, 18:11:28 by NewbieOneKenobi »
Offline JohnElliott
« Reply #15 on: Sat, 25 September 2010, 19:44:14 »
Quote from: NewbieOneKenobi;226805
No, according to kbdbabel the MBC-555 protocol is completely different.
Offline ch_123
« Reply #16 on: Sun, 26 September 2010, 03:56:23 »
3178. Whoops.
