Author Topic: [IC] icp - Compact 1800  (Read 7812 times)
Offline illusixn
  • Formerly illusixn
« on: Tue, 28 June 2022, 07:38:26 »
icp
icp is a compact 1800 layout keyboard.
I have a talent for naming things. As such, the extremely creative name I've come up with follows the nomenclature of TX-CP, hbcp, and BOK.CP.
I would eventually like to run a group buy for this project, so I am using this post to gauge interest.
IC form: https://forms.gle/6mhqU53CkFUHrjuk6
Specs
Layout: Compact 1800 (all layout options to be included will be in an image below)
Typing Angle: 5 degrees
Mounting: Top mount
Case materials: 6063 aluminum top/bottom, brass weight
Plate: 5052 aluminum full plate by default, would like to offer PC plates as well
PCB: 1.6mm, solder only, using C3 Unified Daughterboard, QMK/VIA
Front height(s): ~18.2mm, ~18.9mm, ~22.1mm ("unadjusted", "adjusted", and EKH. Everyone likes to use different numbers so take your pick.)
Layout Options
The below layout options will be supported:
Prototype Photos
Possible Buy Details
A group buy for this is quite a ways out, so these details are subject to change.
  - Pricing: ~$575 (Final price could be higher or could be lower by the time the buy happens. I'll update pricing once I have final quotes closer to the time of gb)
  - Number of units: 20
  - Color options: Anodized silver and anodized black, 10 of each
  - No estimated group buy date since I'll be prototyping until I have the design dialed in to where I want it, and I'm not sure exactly how long that will take.
Project Progress/Planning
Prototype 1 - built, identified change areas
Rev2 of the PCB ready to be proto'd
  - I want to have a clock on the oled, so I've added a coin cell battery holder
  - Ribbon cable to connect to oled daughterbaord instead of JST
  - oled daughterboard work mostly complete. I have the 3D file in hand, currently checking for any necessary adjustments.
  - rev2 protos will be ordered once the oled db is finished
[Post IC and gather feedback]
Complete firmware - Main portion of the firmware already completed
  - Finalize information shown on oled
  - Trying to figure out how to best display some dynamic info. Currently looking at this: qmk-hid-display
  - Simple battery level indicator once I have rev2 PCB in
Prototype 2 - Will be ordered once some design details are finalized. Targetting end of July/beginning of August to place that order. Gonna get it in black since that's the second color I'd like to run.
  - Possible switch to SKUF from SJ5302 bumpons
Thanks for any feedback and/or support for this project.
« Last Edit: Sun, 03 July 2022, 08:04:24 by illusixn »
Offline illusixn
  • Formerly illusixn
Re: [IC] icp - Compact 1800
« Reply #1 on: Tue, 28 June 2022, 07:38:44 »
reserved
« Last Edit: Tue, 28 June 2022, 07:41:49 by illusixn »
Offline Oggi
« Reply #2 on: Tue, 28 June 2022, 07:43:57 »
« Last Edit: Tue, 28 June 2022, 07:45:54 by Oggi »
Offline FiEND
« Reply #3 on: Tue, 28 June 2022, 11:48:20 »
came in expecting an insane clown posse inspired board. MMFWCL!
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #4 on: Tue, 28 June 2022, 17:30:53 »
yessir.
Offline mcmcmc
« Reply #5 on: Tue, 28 June 2022, 18:25:19 »
yes. this should probably be a private gb, but yes
Offline maelkesnot
« Reply #6 on: Tue, 28 June 2022, 20:14:03 »
awooga, woah mama, kaboinka :eek: :eek:
Offline ankit
  • Formerly ankit-sachdeva
« Reply #7 on: Tue, 28 June 2022, 21:24:42 »
Any photo of the side profile avail?
Offline HungHingDaiLo
  • 無間道
« Reply #8 on: Tue, 28 June 2022, 23:14:28 »
Yes please. Been waiting for this since last year
Great job illusixn :thumb:
Offline spedywin
  • Formerly spedywin
« Reply #9 on: Wed, 29 June 2022, 01:29:50 »
nice
Offline treeleaf64
    • treeleaf64
« Reply #10 on: Fri, 01 July 2022, 23:25:03 »
good work board but doesn't need the weight because big keyboards already weigh quite a lot
Everyone must pay the cat tax
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #11 on: Sat, 02 July 2022, 00:02:20 »
keycaps, thock, clack and stabs
****ing keyboards how do they work
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #12 on: Sat, 02 July 2022, 06:02:42 »
ne side profile photo? otherwise looks good, am interested.
Offline HappyB0T
  • I'm a Piggie
« Reply #13 on: Sat, 02 July 2022, 06:30:20 »
ditto - this is magic.
Offline illusixn
  • Formerly illusixn
« Reply #14 on: Sat, 02 July 2022, 10:51:47 »
Forgot to add that in. Kept the sides pretty simple.
Side and front pics added into op.
« Last Edit: Sat, 02 July 2022, 10:58:32 by illusixn »
Offline vodanhdaisu
« Reply #15 on: Fri, 29 July 2022, 09:40:31 »
I'm a very fan of 1800 and 980 keyboard. This project is definitely the one I have to put to my collections  :thumb:
Offline iamtragic
« Reply #16 on: Sat, 30 July 2022, 00:10:05 »
5 degrees? Say less.
Yes.
Offline superjackie
« Reply #17 on: Sat, 30 July 2022, 00:48:15 »
shipping 2024?
Offline Nonnegaard
« Reply #18 on: Mon, 01 August 2022, 15:30:36 »
why
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Nonnegaard
« Reply #19 on: Mon, 01 August 2022, 16:05:08 »
treeleaf64 ▾English ▾
______________________
I'm weak
