Author Topic: [IC] i7 - 65% + Macro Column + Animated Screen with Colour  (Read 12445 times)
Offline mecha.store
« on: Thu, 30 June 2022, 11:12:37 »
i7
By EuaticL and 大帅比
288503-0
288505-1
288507-2
288509-3
Mecha Discord
More renders/pictures
Details
Case
- Exploded 65% with Macro Column
- OLED Screen, capable of playing gifs in colour
- Magnetic Badge
- Poron Gasket Mount
- ANSI/ISO
- "Seamless"
- 1.48kg~ built
- 6 degree typing angle
- 1.2mm Thick FR4 Plate
- 21.5mm front height from top of lip to bottom without feet.
PCB
288511-4
-1.2mm PCB thickness, will come with 0.4mm thick shims
- USB Daughterboard (Pinout is different from UDB)
- QMK/VIA
- 0.96 OLED Module
- Hotswap ONLY
- Ultra-soft JST cable
- 6.25u and 2.75u,1.25u,1.75u split spacebar support
Sale Info
DISCLAIMER: ALL INFORMATION IS SUBJECT TO CHANGE.
Fulfilment
This will be fulfilled in a group buy.
Due to the amount of options regarding the parts of the aluminium case, ordering a flat number of each colour for each piece and packaging it would be a logistical nightmare.
That being said, the cases are already currently being machined, and the orders will be submitted to the factory for coating after the machining is completed. This way, the lead time is significantly reduced, with the customer only needing to wait for the surface treatment to be completed.
Pricing
400SGD~ for e-coated colours at MOQ of 30 sets total, regardless of colour, pricing will be adjusted accordingly to demand.
60SGD - Extra PCB package, includes PCB, OLED, daughterboard, ribbon cable and JST cable
Colours
Due to current developments with the anode factory, there will not be anodised colours in favour of E-coated colours instead for the time being.
- Beige
- Dark Green
- Pink
- Blue
- Yellow
- Lilac
- Black
288513-5
Package Contents
1x Aluminium Top, Bottom, Badge, Weight, Weight Accent(6063)
2x Case Polycarbonate Diffusers (#150 Grit)
1x Badge Polycarbonate Diffuser (#150 Grit)
1x Hotswap PCB
1x Daughterboard
1x Oled Module
1x FR4 Plate
10x 1.5mm Poron Gaskets
10x 2.0mm Poron Gaskets
4x Rubber Feet
8x M2.5x8mm Pan Head Steel Screw
5x M2x4mm Pan Head Steel Screw
3x M2x4mm Countersunk Steel Screw
1x Carrying Case w/ Microfiber Cloth
Definitely not biased video
IC FORM
We also have the i7 prototype on display in the physical store to try in person!
Offline bow3i
Re: [IC] i7 - 65% + Macro Column + Animated Screen with Colour
« Reply #1 on: Thu, 30 June 2022, 11:53:36 »
Looks pretty cool, glwgb!
Offline Alejo1707
  • Gimme some more caps!
« Reply #2 on: Thu, 30 June 2022, 12:21:11 »
Nice! Will keep an eye on this! GLWIC
Sent from my GM1917 using Tapatalk
Offline Thana
« Reply #3 on: Thu, 30 June 2022, 15:17:04 »
Looks good, GLWIC!
Sidenote, can't access the IC form. Says "This form can only be viewed by users in the owner's organization.".
Offline SDKCAMPING
« Reply #4 on: Thu, 30 June 2022, 23:31:19 »
a Little busy looking but that is an acquired taste, I can see some would love this
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline mecha.store
« Reply #5 on: Thu, 30 June 2022, 23:54:27 »
Fixed! Thanks for letting us know!
Offline ritualconfession
« Reply #6 on: Fri, 01 July 2022, 15:46:14 »
The enormous light-up badge on the right completely overshadows the OLED on the left.
Offline Keeblet_257
« Reply #7 on: Sat, 02 July 2022, 01:14:38 »
to me the bottom looks weird or unpleasant. it really bugs me when I see this  1.25U 1U 1.25U 6.25U 1U 1U 1.25U. Would it be a option to make it 1.5U 1U 1.5U 7U 1U 1U? or at least offer the option for solder so ppl can choose what they want in for the bottom row?
I do like the customizability and the oled as well as the cheap price but making it hs only and forcing me to use that bottom row really makes me question if I really want that board.
Speakig of hs pcb. In my opinion its never a good idea to make it ISO and ANSI compatibel HS. I can already see the crooked pipe keys or west/east facing switches.
other than that I think that its a good board
« Last Edit: Sat, 02 July 2022, 01:16:49 by Keeblet_257 »
Offline Neprawdda
« Reply #8 on: Sun, 03 July 2022, 03:04:19 »
The best layout that I wanted) Yes, even immediately hotswap.
Offline Tsenohebot
« Reply #9 on: Sun, 03 July 2022, 06:28:40 »
def buying this lol  :eek:
Offline conternecticus
« Reply #10 on: Sun, 03 July 2022, 07:36:58 »
I prefer a different design language, so I'm not interested in this one. Still, GLWIC!
Offline Uki
« Reply #11 on: Fri, 08 July 2022, 08:03:57 »
Interesting keyboard. Design is unique not sure if I like it or not it is very techy. But what I like is layout, that left column adds so much functionality I mean you coud just make regulars 65 but regular 65 it is very compressed this is much much nicer for person like me who likes exploded layouts. Oled screen... it's just cool. And customizability... wow stepped caps lock, split spacebar, iso and all that on hotswap pcb. The only thinkg missing here is split backspace. I'm especially happy with split spacebar this is so functional. I'll consider this kb for sure.
