Author Topic: 【IC】Lila switches  (Read 8685 times)
Offline Aregs Keyboard
【IC】Lila switches
« on: Tue, 05 July 2022, 01:10:06 »
Hello! Here are Aregs Keyboard!
Very happy to bring you a new product that we are very satisfied with!——Lila Switches
Lila switch is inspired by the lilac, and the switch was designed by Aregs Keyboard and Suixin Studio. The lila switch uses JWK's latest material - LY, a hybrid material with an extremely low coefficient of friction In the case of Unlubed, it brings a very smooth feel, will get better performance after lubricating, With an extended spring and Long Pole stem, he will have a very elastic and feedback feeling. Now more and more people are in love with this feeling!
They are preparing for GB now!
Details
* Linear
* 3.7mm travel / 2.0mmactuation
* Stem: LY(JWK Exclusive Materials)
* Top Housing: Nylon
* Bottom Housing: Mixed nylon
* Spring: 67g(bottom out) extended gold spring
* PCB mount (5 pin)
* unlubed from factory
* Manufactured by JWK
Vendor list:
US: Dangkeebs
CA:Mech.Land
EU:KEYGEM
UK:Mechboards
AU:TBD
Singapore:ilumbkb
SW:TBD
Our Discord:discord.gg/aYYESXTsts
« Last Edit: Tue, 12 July 2022, 06:05:41 by Aregs Keyboard »
Offline 0xtanja
  • need 1.5u supers
    • linktr.ee/tanjarinne
Re: 【IC】Lila switches
« Reply #1 on: Tue, 05 July 2022, 02:14:00 »
Linear? Tactile?
Offline Mr Chrome
« Reply #2 on: Tue, 05 July 2022, 02:35:37 »
Not enough info. I'm guessing these are linear long poles?
Is the LY material used for the whole switch? Just the stem? Just the housings? Is it similar to UHMWPE?
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
« Reply #3 on: Tue, 05 July 2022, 06:30:10 »
Hey, sorry for my mistakes, full details have been added, and only the stem is LY !
Offline Mr Chrome
« Reply #4 on: Tue, 05 July 2022, 07:13:30 »
All good, thanks for updating :thumb:
JWK nylons are really nice, so I think this could turn out to be a great switch! Unlubed was a good choice too.
Offline conternecticus
« Reply #5 on: Tue, 05 July 2022, 09:02:28 »
Any soundtests?
Offline 3yatt
« Reply #6 on: Tue, 05 July 2022, 20:55:46 »
GB date?
Offline bshendy
« Reply #7 on: Tue, 05 July 2022, 21:10:52 »
I take it the stems are the same as what's found in the Nebula switches?
Offline zghtyarecrenj
« Reply #8 on: Wed, 06 July 2022, 02:12:13 »
The stem is the same material as the stem of Nebula switches and the stem of the Soul of the Coast switches. But the mould might be slightly different.
Offline DirtyGingy
« Reply #9 on: Fri, 29 July 2022, 07:30:08 »
what happened the the group buy post?
