Author Topic: [IC] NoFaff - low profile macropad  (Read 5265 times)
Offline kbex
« on: Thu, 14 July 2022, 15:43:58 »
The group buy is now live
you can buy it at my shop :D
DISCORD | SHOP
Hi everyone!
My name is Kfir and i would like to present to you - NoFaff macropad.
NoFaff macropad
NoFaff is a project of mine that addresses some of the things i found missing on other keyboards out there,
i'm really happy with the outcome so far. i hope you will like it too.
i wanted to make a macropad that would:
   1. be low profile.
   2. have a small foot print on my desk.
   3. have enough keys and layers to serve all my daily use-cases (video editing, CAD, EDA, Gaming, streaming, etc)
   4. be usable without any screens.
   5. easily configurable.
   6. and would be ascetically pleasing. (Bongo cat is the cutest :3 )
Easy per key color editor:
Layer changing:
About me:
i'm a maker at heart and i do a bit of everything.
CAD,CNCing, embedded code, PCB design. what ever the project requires.
Details :
- Open hardware
- Kailh Choc compatible
- Type-C USB connector
- QMK / custom Vial firmware
- FR4 mounting plate
- FR4 back plate with gold plated Bongo cat :D
- 24 Very bright RGB LEDs.
- Per key LED color mapping supported for all 8 layers through custom instance of Vial.
- Easy assembly/built with a soldering iron and a screw driver.
- supports Linux, Windows, MacOS, Android and so on...
physical size:
120 x 80 x 11 - mm
4.7 x 3.15 x 0.43 - inch
vendor:
kbex.me - click the "get notified" button to get email notifications about the keyboard.
Avilability:
- Only 150 boards for the time being.
- Group buy early August 2022 depending on the interest. (FCFS)
Pricing:
- 125 euro
+ 19 euro shipping for most of the world
Estimated shipping : 8 week from the end of the group buy.
Mitigating risks:
 - i have secured components for 150+ keyboards.
 - i have validated manufacturing with a small run of keyboards with my manufacture.
To Do:
- custom made keycaps (not sure yet if it's going to be with this GB)
- fix global illumination, cause it's too bright.
Discussion and feedback on my Discord
See my site for me examples of using the keyboard
Thank you for reading my IC !
Beauty shots:
size comparison:
Dissaembly:
« Last Edit: Thu, 01 September 2022, 14:59:21 by kbex »
Offline controller-works
    • Controller.works
Re: [IC] NoFaff - low profile macropad
« Reply #1 on: Wed, 20 July 2022, 13:56:01 »
This looks amazing! I love the PCB art on the back.
Offline kbex
« Reply #2 on: Fri, 22 July 2022, 13:20:11 »
Thank you :D it was a lot of work to draw it.
Offline kbex
« Reply #3 on: Mon, 29 August 2022, 07:46:26 »
 hi ! everyone, i've ran the IC a little longer then planned as the overall interest was low. i'm still going move forward with the GB and get the boards to those who want them
group buy starts 1.9.22
« Last Edit: Mon, 29 August 2022, 08:34:02 by kbex »
