Author Topic: [IC] M93I, A 87% Keyboard kit with Numpad +GB IS LIVE!  (Read 13330 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
« on: Fri, 15 July 2022, 13:17:31 »
Edit: October 29th,
Thank you for following this project! We finally get a confirmation for the GB Time.  :cool:
GB Time: Oct.26th - Nov.9th,2022
Delivery time: Start packing and sending to Wuque Studio direct customers in Q2, 2023.
GB Product Page
Hi Everyone,
We are glad to come back to update M93I final GB items this week! Based on our IC feedback we’ve able to finalize the final product Specifications and GB prices.
M93I Gallery
Update Info
* GB Time: Expected end of October (will post updates again 7 days before the GB)
* GB Price:
- White Navy (Top case: E-white; Bottom case: Blue Anodized): 289 USD
- Black (Anodized): 269 USD
- Navy (Anodized): 269 USD
* Typing Sound Test
* Add PE switch poron foam
(To further improve the typing sound of the M93I keyboard kit, JOJO Studio has added PE switch poron foam to reduce the sound of the switch striking and increase the mute effect.)
IC Form Feedback Update
(Based on feedback from the M93I keyboard kit IC form.)
* The final decision was made to use optical lamp beads as the default M93I standard version.
* Default M93I keyboard kit will be available in 3 colors: White Navy, Black and Navy
* Default PCB type is wired PCB
Streamers/Youtubers
* Alexotos - M93I Navy keyboard kit
* Xingxing wong - M93I Navy keyboard kit
* Apiary - M93I White Navy keyboard kit (Top case: White; Bottom case: Blue ,Time: TBD)
* Clackbait - M93I White Navy keyboard kit (Top case: White; Bottom case: Blue ,Time: TBD)
M93I Keyboard Kit Highlights
*Cluster Shortened Numpad and Utility keys: M93I keyboard kit retains the basic F-zone and the Home, End, PG UP, and PG DN keys, while adding a numpad area for easy data entry
Specifications
Typing angle: 5.5 degrees
Dimension: 363 x 147 x (20-30) mm
Front Height: 20mm
Weight (unbuilt): 1.7 kg
Case Material: 6063 Aluminum
Mounting Method: Top Mount
Supports ANSI Layout only
PCB Specifications:
- 1.2mm Hot-swap PCB
- Stepped Caps Lock Supported
- VIA supported
- ESD Protection
M93I Kit Contents:
* Aluminium Top and Bottom Cases
* PC Plate
* Hot-swap PCB
* Plate Poron foam
* Poron Foam under PCB
* PE switch poron foam
* LED diffuser
* Type C module
* Keyboard feet
* PCB JST cable
* Hex screwdriver
Colors: White Navy (Top case: White; Bottom case: Blue), Black, Navy
If you are interested in this kit and/or have any suggestions, please fill in the M93I IC form and join the M93I  discord channel in Wuque Studio’s Discord server.
Thank you!
« Last Edit: Sat, 29 October 2022, 10:21:57 by Ckeeb »
Offline superjackie
Re: [IC] M93I, A 87% Keyboard kit with Numpad
« Reply #1 on: Fri, 15 July 2022, 20:07:48 »
will it have brass weight? 7U spacebar? wkl?
Offline whitewolf154
« Reply #2 on: Tue, 06 September 2022, 21:19:52 »
I would like to see brass weight option and more layout options. But otherwise, board looks great
Offline Ckeeb
    • MELETRIX
« Reply #3 on: Fri, 21 October 2022, 09:56:43 »
sorry, only have this version.
Offline Ckeeb
    • MELETRIX
Re: [IC] M93I, A 87% Keyboard kit with Numpad +GB IS LIVE!
« Reply #4 on: Sat, 29 October 2022, 10:22:26 »
GB IS LIVE NOW  :thumb:
