Author Topic: Tips on Modifying PCB layout?  (Read 2475 times)
Offline Will_I_am344
« on: Sat, 16 July 2022, 15:07:27 »
Hi! I found a keyboard I really like (Lily58) https://github.com/kata0510/Lily58
However, I want to modify the layout slightly (remove the top 2 outer buttons and add thumb buttons)
I downloaded the pcb and schematic files to KiCAD and checked them out but I am not entirely sure how to proceed with applying the changes I want. Can I get some tips please?
Offline controller-works
    • Controller.works
Re: Tips on Modifying PCB layout?
« Reply #1 on: Thu, 21 July 2022, 14:05:10 »
You will need to research as much as you can on KiCAD, and keyboard PCB design. You will also need to back fill any knowledge you are missing on circuits. These will get you started.
https://github.com/ruiqimao/keyboard-pcb-guide
https://matt3o.com/book/
There are also many tutorials on YouTube if you search there.
