Author Topic: [GB] HR2 by Sho - Drop-in Aluminum Case for Realforce R2  (Read 3553 times)
Offline hong@RebultKeyboards
  • Rebult Keyboards
    • Rebult Keyboards
« on: Sun, 17 July 2022, 13:23:29 »
289085-0
Continuing hot after the end of the S60 Aluminum Case for HHKB Pro 2, Sho is running another design of his that he has been working on for a while, the HR2.
This time, it is an aluminium case for the Realforce R2. The HR2 is a drop-in replacement case for the Realforce R2, which means that the original plate+pcb combo can be directly installed into the case, unlike a previous IC of his, the SR2, which requires PCB and housing transfers onto the new plate.
The HR2 follows more of a vintage design language, with slopes on both ends, offering a more comfortable typing experience without a wrist rest.
This is a drop-in replacement, which means you just need to extract the internals of your Realforce R2 without taking the PCB and Plate apart, and you can straight away install it into this case using the original screw holes. USB-C daughterboard is included.
The HR2 can support all of the Realforce R2 TKL series of boards, including both the US and JP layouts along with the RGB variant.
Product Page: Rebult Keyboards
*Images are from a pre-production prototype
*Anodization samples from factory here, the first chip from the top is Lavender. Black Silver and Grey should be pretty self-explanatory.
Case Material: 6063 Aluminum
Case Weight: 2.3kg
Pricing: US$370.05 / RM1568 / SGD512.74
Colors Available: Ano Silver, Ano Black, Ano Grey, Ano Lavender
GB Dates
Already Started
End: 10 August 2022 (Extended from the original 20 July 2022)
Estimate Fulfilment: Approx. 3 months after end of GB
Video and Typing Test: https://www.bilibili.com/video/BV1Ya411W7nR?spm_id_from=333.337.search-card.all.click
Package Includes:
  • Top Case
  • Bottom Case
  • All required screws
  • Case Feet
  • Poron Case Foam Sheet
  • USB-C Daughterboard
  • Carrying Case
To complete the build, you will need:
  • Realforce R2 TKL Keyboard
Re: [GB] HR2 by Sho - Drop-in Aluminum Case for Realforce R2
« Reply #1 on: Tue, 26 July 2022, 16:40:40 »
Approved :thumb:
