Author Topic: [IC] JRIS65 - PCB Gasket Mount Customize Keyboard  (Read 137957 times)
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« on: Wed, 20 July 2022, 06:28:23 »
Hi Everyone,
We would like to introduce our first keyboard project---JRIS65, which IRISLab designed.
JRIS65 is a budget-friendly and high-quality PCB gasket-mounted, full CNC aluminum keyboard.
To let everyone able to experience the higher-end customization, we are working on the typing sound, typing feel, craft, and quality of the kit, which benchmarks mainstream customized keyboards.
JRIS65 Info:
JRIS65 design concept is elegant, simple, durable, and comfortable.
Full CNC aluminum case: aluminum top case and aluminum bottom case
Simple and atmospheric front side, and laser engraving of LOGO on the back
The weight on the side is the same color as the bottom so that you can feel the nobility in daily use!
The separate daughter board brings you a better typing experience.
PCB gasket jackets or socks make your building more convenient and simple!
JRIS65 Specifications:
Typing angle: 6°
Front height:19.3mm
PCB GASKETS structure
PCB with USB-C daughterboard
Both PCB and plate adopt flex cut design
PCB gasket jackets or socks (included as default)
QMK/VIA Supported
Support PCB stabilizers
What you can customize for JRIS65?
Case Colors Options:
E-White
Yellow
Black
Milky-White
E-White + Black
Maroon + Black
Navy + Black
Titanium Grey+Black
Yellow + Black
Pink
Weight Options:
Anodized Alu Weight: Black, Silver, and Gold
PVD Mirror Stainless steel Weight: Gold, Silver, Black, and Chroma
PCBs Options:
To ensure better quality and typing feel, we adopt the separate daughter board and use JST cable for a more friendly building.
Hotswap PCB support layout
Solder PCB support layout
5.2 Bluetooth hotswap PCB(battery included) support layout.
We are cooperating with Li Dana for Bluetooth hotswap PCB. Li Dana is famous in China because his PCBs are stable and qualified. And the BT PCB has its drive, so it doesn't support VIA/QMK
Plate Options:
PC
POM
FR4
ALU
Brass (Add-on only)
Black core FR4 (Add-on only)
Plateless Options:
If you need to build as plateless, please purchase the 5 mm plate foam as extra. And we highly recommend ordering the solder PCB for the plateless build.
What's Included?
Full CNC Aluminum Case
Weight( Anodized Alu/ PVD Mirror Stainless steel)
1*PCB (Hotswap/ Soldered/ Bluetooth)
1*Plate (PC/ FR4/ Alu/POM)
Type-C Daughterboard
IXPE Foam
Poron Plate Foam
Poron Case Foam
Masking paper for PCB
JST Cable
10 * gasket jackets
20 * gasket socks
1 Set of PCB Shims
1 Set of Footpad
1 Set of screws
Battery(Only for the Bluetooth version)
Gift(will not send make-up or replacements)
Carrying Case
USB-Type C keyboard cable
Pricing:
Vendor List:
US: KeebsForAll
Canada: Ashkeebs
EU: Candykeys
UK: Prototypist
South American: LatamKeys
Oceania: Daily Clack
South Korea:Geonworks
Japan: Basekeys
Singapore: Mecha.Store
Indonesia:KeebsMark
Philippines: Jaekeyed
Thailand& Malaysia : Klackzkrypt
Vietnam: MOKB STORE
Bangladesh: KeyB
Rest of the world: Mykeyclub
GB Time:
September 27 - October 3, 2022
Review links:
Alexotos build E-White&Black Case+Gold PVD Weight+Hotswap PCB +FR4 plate
TofuTypes build E-White Case+Chroma PVD Weight+Solder PCB+Alu plate+POM plate
Yo_keebs build Milky-White Case+Chroma PVD Weight+Hotswap PCB+POM plate+FR4 plate
sviz build Pink Case+Silver PVD Weight+Hotswap PCB+PC plate
Maybe our voice is weak, but we are working to bring you a good value kit. So, the price is competitive enough to let everyone able to leapfrog to experience a higher-end kit and enjoy the customized experience.
Let's stay tuned for future posts.
Please check the MORE prototype photos below#
Pink Case with Chroma PVD Mirror Weight
Maroon + Black Case with Gold PVD Mirror Weight
Maroon + Black Case with Silver PVD Mirror Weight
Milky-White + Black PVD Mirror Weight
Titanium Grey+Black
Accessories
Build and Typing Sound (This is not the final prototype, please look forward to the future review videos)
If you are interested in IRIS65, please fill in IRIS65 IC form
Mykeyclub is a platform that integrates creativity and innovative design, helping more studios join this hobby community and bringing more fun and cool products to you guys.
For more discussions and future updates, please join Mykeyclub discord
Thank you everyone!
Best Wishes
Mykeyclub Team
« Last Edit: Sun, 18 September 2022, 04:52:20 by Mykeyclub »
Offline VXQN
Re: [IC] JRIS65 - PCB Gasket Mount Customize Keyboard
« Reply #1 on: Wed, 20 July 2022, 06:30:48 »
Reserved.
Offline Tsenohebot
« Reply #2 on: Wed, 20 July 2022, 06:48:23 »
Broo this is sick 100% will buy.
Offline purryoverlord
« Reply #3 on: Wed, 20 July 2022, 07:00:36 »
I've seen the photos on zfrontier, the pink looks really good!
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #4 on: Wed, 20 July 2022, 07:14:52 »
Is it called JRIS OR IRIS?
Offline antifocus
« Reply #5 on: Wed, 20 July 2022, 08:07:02 »
Iris, this account must be operated by a different person from the team, and they got confused with the cursive writing on the back
Offline TheOmen
« Reply #6 on: Wed, 20 July 2022, 08:23:55 »
Would 100% buy if this wasnt a 65% (no offense to 65s). The Value is insane here. Would love to see this in an Alice or TKL Layout
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #7 on: Wed, 20 July 2022, 09:26:42 »
Because the DBA Keebio holds the trademark of IRIS, we don't want to risk infringement and respect the property rights of others, so we rename the IRIS65 to JRIS65.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #8 on: Wed, 20 July 2022, 09:29:56 »
We plan to launch the 75% in the near future and hope it will be an option for you.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #9 on: Wed, 20 July 2022, 09:31:42 »
Thank you for your support.
Offline Ram08
« Reply #10 on: Wed, 20 July 2022, 11:53:09 »
I was desperate for this!! Thanks so much for considering making a 75% version, it's insta-buy for me! I hope it would be an exploded layout and we get to see that same Maroon case.  ;D
Cheers and best wishes with this Group Buy!
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #11 on: Wed, 20 July 2022, 21:15:51 »
Thanks, let's stay tuned the future post.
Offline Jooosh
« Reply #12 on: Thu, 21 July 2022, 00:16:24 »
will this ship to the US?
Offline superjackie
« Reply #13 on: Thu, 21 July 2022, 01:25:17 »
any exploded 65/75 option? glwic.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #14 on: Thu, 21 July 2022, 02:59:44 »
We will discuss this. Thanks for your opinions.
Offline Shunfry
  • #Yolo.
« Reply #15 on: Thu, 21 July 2022, 10:08:58 »
So clean, I'm in.
Envoyé de mon KB2003 en utilisant Tapatalk
Offline Akele
« Reply #16 on: Thu, 21 July 2022, 17:35:14 »
Looks like a strong competitor to the QK65, with a few features (daughterboard, full CNC case, multiple brass PVD options) that could give it an edge. Not sure I like Jris text on the weight (I'd prefer a plain weight or a nice logo or image), but I don't hate it and I think the rest of the design elements look really good. The rounded corners are also a nice differentiator to the QK65's sharp corners.
I have a QK65 already, but the JRIS65 is tempting me.
Offline obscurastudios
« Reply #17 on: Wed, 27 July 2022, 13:46:11 »
Really hope this one comes through. Any plans on shipping some of these for some influencers to take a look at?
Offline Necrolegion
« Reply #18 on: Wed, 27 July 2022, 19:38:25 »
Please start the GB soon. Would love to pick up two (home and office).
Offline Deadline.Studio
« Reply #19 on: Fri, 29 July 2022, 06:47:52 »
pvd looks cool
Offline KaosJ
« Reply #20 on: Fri, 29 July 2022, 09:59:46 »
Looks amazing, will probably sound similar to the zoom65 and QK65 (good), but i like this design more.
I hope we can decide how to mix and match the colors: top/bottom/weight  :thumb:
« Last Edit: Fri, 29 July 2022, 10:01:21 by KaosJ »
Offline mr_foggy
  • neue = nope
« Reply #21 on: Fri, 29 July 2022, 10:50:27 »
aesthetically blows the QK and Zoom out of the water. way cooler design while retaining the same characteristics and price.
will consider the BT variant as a travel keeb. nicely done.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #22 on: Mon, 01 August 2022, 21:19:25 »
Thanks. We will discuss this.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #24 on: Mon, 01 August 2022, 21:22:40 »
Yes, and it will be a US vendor.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #25 on: Mon, 01 August 2022, 21:46:40 »
YES, we will send some prototypes to the content creators for review.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #26 on: Mon, 01 August 2022, 21:48:29 »
Thanks for support
Offline menuhin
« Reply #27 on: Tue, 02 August 2022, 04:35:05 »
I already have quite a few 60% but not yet a 65%.
I am already saving money for this GB, hope there is enough time to save enough money for the configuration that I want to get  :thumb:
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #28 on: Wed, 03 August 2022, 22:03:34 »
Thanks for your support :)
Offline Jho
« Reply #29 on: Thu, 04 August 2022, 23:08:14 »
Love the PCB. The fact that this is seemingly gonna be budget friendly makes me way more interested.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #30 on: Fri, 05 August 2022, 06:38:42 »
We are glad to hear the word you said.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #31 on: Tue, 09 August 2022, 11:34:06 »
;D
Offline Hiiro_XoXo
« Reply #32 on: Wed, 10 August 2022, 11:38:52 »
Need a 65%. In on this for sure
Offline chat and team
« Reply #33 on: Wed, 10 August 2022, 12:03:59 »
are these guys iris lab or are they intermediaries for them
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline HYP3RION
« Reply #34 on: Thu, 11 August 2022, 15:45:13 »
Looks amazing with that pcb. Can't wait to see it go to GB.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #35 on: Fri, 12 August 2022, 02:35:41 »
We are running the international GB for the Irislab.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #36 on: Fri, 12 August 2022, 02:39:54 »
Thanks ;D
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #37 on: Fri, 12 August 2022, 02:41:03 »
Offline Hiiro_XoXo
« Reply #38 on: Sat, 13 August 2022, 10:34:08 »
Any idea of a potential gb date? Just wanna know if i should expect to drop money soon or not
Also, is pvd rose gold plate no longer an option?
« Last Edit: Sat, 13 August 2022, 12:50:32 by Hiiro_XoXo »
Offline Backspace2
  • Third most used key on the keyboard is Backspace!
« Reply #39 on: Sat, 13 August 2022, 23:52:16 »
value is insane. I think I might consider
Yes
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #40 on: Sun, 14 August 2022, 21:18:42 »
The GB data will be in September. The PVD rose gold weight prototype is very different from the render. We are still working on this. If it can't be improved then the color will be removed.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #41 on: Sun, 14 August 2022, 21:19:21 »
Thanks
Offline Uki
« Reply #42 on: Tue, 16 August 2022, 09:36:29 »
Do you still make any changes to design or is it final? It's a great value for a price but I need split spacebar. I think we generaly need more split spacebar boards. You already made pcb ultra compatible so do you think is it possible to add a few extra sockets? Would be awesome
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #43 on: Fri, 19 August 2022, 23:18:45 »
Thanks for your suggestion. We will consider this.
Offline Uki
« Reply #44 on: Sat, 20 August 2022, 19:50:48 »
Great! I will be following this project
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #45 on: Mon, 22 August 2022, 12:36:23 »
Thank you
Offline Tackweetoes
« Reply #46 on: Mon, 22 August 2022, 15:32:32 »
Will the design of the letters on the back change at all? I specifically wanted this board after seeing it on Youtube because it was called IRIS but am not really a fan of the new name.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #47 on: Mon, 22 August 2022, 20:50:56 »
Because we don't want to risk infringement and respect the property rights of others, so we change the name in public, but the letters or other details do not change.  About the name, you can call it whatever you like personally.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« Reply #48 on: Wed, 24 August 2022, 01:52:59 »
Thanks
Offline rodok
« Reply #49 on: Wed, 24 August 2022, 07:43:50 »
The yellow seems like a nice colour, almost perfectly matching Greg, as in one would want that.
GL w IC
