Author Topic: How many macropads do you have?  (Read 5975 times)
Offline vincesatsong
    • Vince Satsong
« on: Sun, 24 July 2022, 00:26:12 »
I am the one who likes to have the macropads on my desk. I currently own the CU7 and I really like it. But I think it should have more colors, better structure and design. So I decided to design it by myself with more color options.
Here's the prototype.
What do you think?
Sent from my XQ-AT52 using Tapatalk
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
Re: How many macropads do you have?
« Reply #1 on: Fri, 16 September 2022, 08:04:29 »
A grand total of 0  :'(
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline TheMastermind
« Reply #2 on: Fri, 16 September 2022, 11:06:46 »
I wouldn't consider it a maco-pad per say but I use a JJ50 as one. I've reflashed it with QMK and it works like a charm! I have mine setup as a 59 key + spacebar if I need to use it as a "Normal" keyboard.
    • Vince Satsong
« Reply #3 on: Sun, 18 September 2022, 22:15:29 »
Why though? They're the good toys
Offline norm
  • My kingdom for convex blanks
« Reply #4 on: Sun, 09 October 2022, 18:24:39 »
I only have one, but I call it a numpad......
    • Vince Satsong
« Reply #5 on: Sun, 09 October 2022, 21:09:19 »
Now, it's time to get more
Offline mohawk1367
« Reply #6 on: Tue, 11 October 2022, 07:34:43 »
idk i just dont have a use for one. i used to have a stream deck which maybe counts but i sold it to my dad because i didnt use it much anymore.
Though if i were to get another macropad it would be a stream deck. Sorry mechanical crew, but they're just so useful and customizable and its all soooo easy. No relegendables, just upload a picture and it shows on the key.
« Last Edit: Tue, 11 October 2022, 07:59:31 by mohawk1367 »
Offline norm
« Reply #7 on: Wed, 12 October 2022, 20:04:43 »
I think you are on to something here......
