Author Topic: Would you buy a laptop with a truly mechanical keyboard?  (Read 22940 times)
Offline keyboardlover
« on: Sat, 25 September 2010, 08:49:15 »
If there were laptops made with a combination of low profile keys and true mechanical switches (cherry, topre, etc.) would you buy it?
I definitely would. After typing on Topre, I can't stand my keyboard scissor switches anymore.
Offline WhiteRice
« Reply #1 on: Sat, 25 September 2010, 08:57:12 »
I'm a big fan of the ultra portable 13.3" laptops. The addition of the plate and the switches would probably add too much weight.
I guess having them on the laptop would be better than the alternative, carrying around an extra keyboard.
Offline d2v
« Reply #2 on: Sat, 25 September 2010, 08:58:27 »
Reminds me of this image from Toshiba website.. check out the piece on left hand side ! On the right is probably the future of laptops.
« Last Edit: Sat, 25 September 2010, 09:00:40 by d2v »
DSI SMK-88 (Black cherry), TVS Gold, Kensington Expert Mouse, MS NEK 4000, MS NWM 6000
Offline ch_123
« Reply #3 on: Sat, 25 September 2010, 08:59:36 »
As far as I know, most low travel mechanical switches just feel like stiff scissor switches. Fitting in normal travel switches is obviously going to make the thing too bulky. Scissors are an acceptable compromise to me. Obviously, the quality varies greatly from one laptop to another.
Offline WhiteRice
« Reply #4 on: Sat, 25 September 2010, 09:00:58 »
We should start doing laptop keyboard comparisons.
Offline d2v
« Reply #5 on: Sat, 25 September 2010, 09:04:03 »
How many people even like laptop style keyboards ? (scissor, chiclet rubber dome, any other switch)
Offline ch_123
« Reply #6 on: Sat, 25 September 2010, 09:13:52 »
I'd take my Thinkpad keyboard over certain types of mechanical switch.
« Reply #7 on: Sat, 25 September 2010, 09:30:26 »
If my Thinkpad had slightly bigger (but still low profile) keys and Topre switches, it'd be a dream for me. Even if it made the laptop a little bigger, it'd be worth it. I'm sure they could design it to have a shorter travel distance as well.
Offline ch_123
« Reply #8 on: Sat, 25 September 2010, 09:37:08 »
I'm not sure how the low-profile Topre switches work exactly, but I'm not sure the mechanism used in the full travel ones would scale down well to a rubber dome the size of the one in a scissor switch.
« Reply #9 on: Sat, 25 September 2010, 09:38:08 »
Quote from: ch_123;226568
Anything's possible ;)
« Reply #10 on: Sat, 25 September 2010, 09:51:58 »
Where do you want the actuation point? At the middle, as with present mechanical switches or at the bottom as with rubber domes and scissor-switch keyboards?
Are there not already vintage low-profile linear switches that use leaf springs?
Offline d2v
« Reply #11 on: Sat, 25 September 2010, 09:52:25 »
Quote from: keyboardlover;226566
One way to do it would be to shift the motherboard and everything on it onto top side of laptop, i.e. behind the LCD. This would make the thickness of LCD as large as the base of laptop. This should liberate enough space into the base to mount a MX switch.
I think if the ML keyswitches had the same feel as MX till 2mm valve actuation (Force diagram), that would be perfect !
Offline didjamatic
« Reply #12 on: Sat, 25 September 2010, 09:55:34 »
Q: Would you buy a laptop with a truly mechanical keyboard?
A:  I already have, multiple times.
Offline ch_123
« Reply #13 on: Sat, 25 September 2010, 09:56:50 »
That would make the screen excessively top heavy and would pull the screen backwards. You'd need pretty big and strong hinges to mount a combination screen/computer onto a keyboard.
At the end of the day, the laptop would still be very thick, you'd just concentrate the thickness elsewhere.
« Reply #14 on: Sat, 25 September 2010, 09:57:34 »
Quote from: didjamatic;226579
I was referring to a modern laptop, but that looks pretty awesome (and exactly the idea I'm talking about).
Offline Rajagra
« Reply #15 on: Sat, 25 September 2010, 16:32:41 »
I'm sure they could design a switch mechanism that laid flat when the laptop was closed, and popped up when opened to give full travel action. If they cared.
To answer the question: I would see it as a positive selling point, and it would influence my choice.
Offline wellington1869
« Reply #16 on: Sat, 25 September 2010, 16:44:07 »
i'd buy it BUT -- laptops often are used in libraries and etc, so couldnt be too loud. And also, well, the old ibm laptop keyboards were pretty much perfect, so I'd also settle for just a well-built tactile switch even if it werent mechanical.
using: ms 7000/Das 3
Offline NewbieOneKenobi
« Reply #17 on: Sat, 25 September 2010, 17:01:43 »
Quote from: ch_123;226561
Actually, I find scissors to have good tactile quality if done well. You could even type by the sound if you really wanted. I suppose a metal scissors AND spring build could probably beat most switches to overall coolness.
« Last Edit: Sat, 25 September 2010, 17:05:06 by NewbieOneKenobi »
Offline Ekaros
« Reply #18 on: Sat, 25 September 2010, 17:25:07 »
I dunno if MLs would work. Not too many options while still being able to hold it thin or light...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline Scott
« Reply #19 on: Sun, 26 September 2010, 02:11:52 »
Quote from: d2v;226563
I like laptop keyboards as I learnt to touch type on one (my first computer was a laptop). I like how I can slide my fingers seamlessly between them. My laptop keyboard seems to give quite a lot of tactile feedback, it seems, because I could actually type faster on my laptop (before spending more time on my desktop keyboard and getting more used to the spacing).
Offline chrs
« Reply #20 on: Sun, 26 September 2010, 13:52:20 »
The problem I see with this idea is that it would only appeal to true devotees of mechanical keys (us).  We don't have one favorite key type that works for all of us.  So the market for any one type would be a tiny fraction of a tiny fraction of us.  What I could see would be a laptop made for cherry keyswitches, and you custom order it with the type you want.
Or, better, a laptop with no keyboard, and you buy a portable keyboard separately.   iPad has paved the way for that--I'm hoping to see more soon.
« Reply #21 on: Sun, 26 September 2010, 13:57:18 »
Quote from: chrs;227020
That gives me an idea...why not a laptop as thin as the iPad, but with a mechanical keyboard attached (maybe similar to an HHKB layout but a bit more user-friendly and with more keys). With lower-profile keys, it wouldn't take up much more space than a modern day laptop. My preference would be for topre switches, but I'd buy one with cherry browns.
Offline whiskerBox
« Reply #22 on: Wed, 09 November 2011, 23:49:40 »
Getac s400
   Water-resistant mechanical membrane keyboard
Optional water-resistant backlit mechanical membrane keyboard
[ Attachment Invalid Or Does Not Exist ] 31455[/ATTACH]
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline Tony
« Reply #23 on: Wed, 09 November 2011, 23:56:30 »
It is just an idea, laptop manufacturers (HP, Sony, IBM, Toshiba) will never make such laptop.
The market for mechanical keyboard is already small (5-7%) and the market for such laptop will be even smaller - 1% or so.
For modding, perhaps someone like Lanx will do it once per his lifetime, just to show it can be done.
Offline pitashen
« Reply #24 on: Thu, 10 November 2011, 01:18:32 »
if i got money to waste yes. Otherwise, consider the short life spam of the laptop, it is not worth the extra cost to get mech board and then go down the drain with the laptop after 3-5 years.
Offline laffindude
« Reply #25 on: Thu, 10 November 2011, 01:25:44 »
Nope. The Cherry switch is about as thick as my current notebook.
Offline peda
« Reply #26 on: Thu, 10 November 2011, 01:54:48 »
Quote from: keyboardlover;227023
i think your best bet to get something like that is actually an ipad-accessories.
something like that: [ Attachment Invalid Or Does Not Exist ] 31460[/ATTACH]
maybe get a kbc poker in a case with connectors to an ipad?!
Offline duncan
« Reply #27 on: Thu, 10 November 2011, 06:33:12 »
Quote from: peda;449127
+1
Exactly right.
The details can change, maybe a HHKB2?, maybe another type of pad.
But the point is a mobile computer with a keyboard of your choice is something you can build yourself if you want to.
Get a little briefcase type thing and you can have this put together in a weekend.
Show us the pics when you are done.
Realforce 86UB || HHKB P2 || FILCO MT 87 Blues || FILCO MT 87 Browns || FILCO MT 87 Ninja  Blacks || Poker X Reds
« Reply #28 on: Thu, 10 November 2011, 06:59:11 »
I love that idea...
And nice necro! I was just thinking about this thread the other day...
Offline himynameisbunny
« Reply #29 on: Thu, 10 November 2011, 07:17:46 »
I can't see why you couldn't have a hybrid Topre/scissor type of switch. The whole point of the scissor is to keep it on a straight trajectory.
Most modern laptop keyboards are mounted on a steel plate anyway.
[SIGPIC][/SIGPIC]
Happy Hacking Keyboard Pro 2 // Logitech M570 Trackball // Topre Realforce 23UB
« Reply #30 on: Thu, 10 November 2011, 07:21:17 »
I think low travel topres would work (like in the he00100). They are stiff tho.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #31 on: Thu, 10 November 2011, 07:26:35 »
Quote from: himynameisbunny;449185
With every laptop keyboard I've ever had it has seemed a whole lot closer to foil than plate, and I'm pretty sure it's always been aluminum.  They flex easily when they are out of the chassis.
Filco w/ Imsto thick PBT
Offline flyball
« Reply #32 on: Thu, 10 November 2011, 07:27:37 »
Quote from: alaricljs;449189
sounds like that would be a big problem if you ever took the keyboard out of the laptop.
[SIGPIC][/SIGPIC]
« Reply #33 on: Thu, 10 November 2011, 07:40:12 »
My 2510p keyboard was on a metal plate. It flexed a bit but once screwed in it was very very sturdy.
[SIGPIC][/SIGPIC]
« Reply #34 on: Thu, 10 November 2011, 08:40:35 »
Quote from: himynameisbunny;449196
It depends on the laptop: Some manufacturers use the keyboard as part of the top case, and those are quite stiff. Once you remove it, you can access the ram, etc. I don't like that design.
I but it also had 2-4 screw mounts on the bottom, too. It's a HP, right? they like to do that sort of thing.
On the other hand, you can have all the components accessible through the bottom, and have the keyboard rest in a niche on the top case. In the case, the keyboard doesn't contribute to the overall structural integrity of the computer, and it'll be flimsy.
I guess there's a third design: have the keyboard be inseparable from the top case, but this is really bad if you spill on it (and all the components attach to it) 'cause then it's super expensive to repair. The apple unibodies are like this.
