Author Topic: WKL PCB models available  (Read 2275 times)
Offline daviddgm
« on: Wed, 27 July 2022, 12:00:21 »
Hi!
Which are the pcb 60% WKL available on the market? I found just DZ60RGB-WKL... Who can suggest any others options?
Thanks.
Offline MIGHTY CHICKEN
Re: WKL PCB models available
« Reply #1 on: Wed, 27 July 2022, 12:43:49 »
Most if not all dz60 like pcbs that are solder should support wkl, it just requires 7u support, it depends on the case if wkl is supported
