Author Topic: [IC] BB60 - $30 RP2040 Universal 60% PCB  (Read 10219 times)
Offline Sleepdealr
  • my name is calliah
    • https://sleepdealer.xyz
« on: Fri, 29 July 2022, 13:49:45 »
BB60
A basic-***** 60% PCB.
DISCORD | IC FORM
V1 Proto Photos
THESE HAVE THE OLD OUTLINE
Photos taken by Ankit
V2 Renders
V2 Has additional mounting point locations and an updated JST location
Specifications
Switch type:
MX Only
Connector:
USB-C -or- JST-SH-4P
Firmware:
Lighting:
Capslock 3mm indicator LED
Hotswap:
No
Encoders:
No
Compatibility
Outline most o-ring boards, does not support tray mount.
USB-C version uses GH60 location. JST is located under “2”, same as bakeneko
Step file to check fitment avail here
JST Version
Bakeneko outline: Yes
Ampere outline: Yes
Kei outline: Yes
USB-C Version
Prophet: Yes
Sangeo-60: Yes
Frog mini: Yes
Every other GH60 board under the sun: Yes (except for tray)
Supported layouts
Colors
:-* Green :-* (for now)
Sale Format
50 units in-stock total
$30 with only US shipping for the first run
Split between JST and USB-C depending on IC form results
Vendored by ankit.works. Ankit discord
Future runs’ sale format will be decided after the in-stock sale
If you have bulk order(10+) requests, please message me on discord, bulk PCBs are available at a discount.
DISCORD | IC FORM
« Last Edit: Fri, 29 July 2022, 14:09:28 by Sleepdealr »
Offline Sleepdealr
Re: [IC] BB60 - $30 RP2040 Universal 60% PCB
« Reply #1 on: Fri, 29 July 2022, 13:50:33 »
Reserved for updates.
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #2 on: Fri, 29 July 2022, 13:51:02 »
hell yes new ankitty ic
Offline Choerry
  • stan loona
« Reply #3 on: Fri, 29 July 2022, 14:14:01 »
ankit so based
Offline puggo69
« Reply #4 on: Fri, 29 July 2022, 14:14:54 »
this is nice i would love to see a eu vendor/run in the future  :p
Offline herbologist
  • beige enjoyer. send help.
« Reply #5 on: Fri, 29 July 2022, 14:16:20 »
10u makes me hard
« Last Edit: Fri, 29 July 2022, 14:22:52 by herbologist »
Offline Hinkerbottom
« Reply #6 on: Fri, 29 July 2022, 14:23:12 »
let’s go sleep
Offline nonuser
« Reply #7 on: Fri, 29 July 2022, 15:01:09 »
goodbye old h60  :-[ :-[ :-[ ....hello new bb60  :cool: :cool: :cool: #hineykiller #tothegrave
Offline Cipulot
    • Website
« Reply #8 on: Fri, 29 July 2022, 15:06:52 »
Based PCB by a based designer.
Clean, layout options are good for what I need (10u is based, and if someone disagrees then they need to cope harder :cool:)
I also greatly appreciate the inclusion of decoupling capacitors that are actually doing their job instead of being included "only because the reference design shows them" wink wink.
EU vendor option would be appreciated to disrupt the Old Continent's scene but that might be a future consideration.
Great work  :thumb:
Offline mmayhem17
    • Steam profile
« Reply #9 on: Fri, 29 July 2022, 15:53:22 »
Very nice price, I am glad that the community found a replacement for cuck prices on mcu. And thank you for your guide on it.
Offline stewfayew
« Reply #10 on: Fri, 29 July 2022, 15:53:50 »
Any interest in supporting Bakeneko v3?
Offline linell
« Reply #11 on: Fri, 29 July 2022, 17:19:18 »
can I have it in aluminum?
bro this a **** set, just be thankful you even getting 1 base running fr
Offline daviddgm
« Reply #12 on: Fri, 29 July 2022, 19:10:51 »
Very interesting...
Offline hlord2000
« Reply #13 on: Sun, 31 July 2022, 15:56:51 »
Great work  :thumb:
Rent free
Offline Riizmaa
« Reply #14 on: Wed, 03 August 2022, 02:35:33 »
will this make my board thock also can you make it red and jst #hineykiller
Offline Seunghyun Lee
« Reply #15 on: Wed, 03 August 2022, 03:53:48 »
my red h60 getting nervous. hope jst and usb-c separated
Offline HappyB0T
  • I'm a Piggie
« Reply #16 on: Wed, 03 August 2022, 23:53:19 »
10 u eh?
« Last Edit: Fri, 26 August 2022, 21:57:05 by HappyB0T »
Offline panka
« Reply #17 on: Tue, 09 August 2022, 13:09:37 »
ne alps avail?
Offline herbologist
« Reply #18 on: Thu, 25 August 2022, 10:19:51 »
Can confirm that this pcb is fire
Offline Farhandsome
    • Han Boards
« Reply #19 on: Thu, 25 August 2022, 12:34:23 »
10U support we love to see it
Offline geohammy
« Reply #20 on: Thu, 01 September 2022, 21:54:15 »
looks good
so is jst connector in the same position as h60?
edit:nvm
« Last Edit: Fri, 02 September 2022, 22:01:18 by geohammy »
Unagi, Bias, Dolphin, XTAL
Join the YVKB Discord:
https://discord.gg/pCjDYqup6r
Offline The0rigina1
  • fumoposting
« Reply #21 on: Thu, 08 September 2022, 12:11:37 »
1.2 mm avail?
