Author Topic: Holiday time by the Aegean Sea - Thera75 V2  (Read 19462 times)
Offline made in China
« on: Sun, 31 July 2022, 04:25:07 »
Greetings guys, this is Createkeebs,
   First, we would like to express our heartfelt gratitude to all who have been supporting us with high expectations in the past year. At this point of time, we’re here bringing you--Thera75 V2.
Kit Introduction
If Thera-V1 shows the night scenery of this Aegean Sea Island through the image of the auditorium with star badge and stainless-steel weight; then in Thera V2, we will set this island as the starting point to start our summer journey to the Aegean Sea.
On the back of Thera V2, we still choose the dome auditorium: the iconic building on Thera, as the weight. The difference is that we make the weight a silhouette of the auditorium this time, making this design element bridges two generations, and emphasizing the starting point of this journey.
Badge
Let’s start with the obvious, on the front badge, we bring the biggest difference, it’s square now  This time we provide three standard badges to choose from, corresponding to the three colorways, as well as two additional badges and a knob for extra.
Greece badge (matching white): Your starting point of the journey, Santorini, on the Thera Island in Greece.
Rudder badge (matching grey): The steering wheel that determines the direction of your travel.
Anchor badge(matching blue): Keeps you safe in the port.
75 Badge (optional): assembled by three different parts, which represents the blue sea, the red weather vane, and grey rocks near the cliffs along your journey through the bayside.
Santorini (optional):The iconic buildings on the Thera Island
Rudder Knob (optional): Steering Wheel knob (Assembled by 11 small parts)
PCB
In addition to the hot-swap PCB option, we generally follow the design of the previous generation of Thera the keep the signature soft typing experience. As you can see, we will use a new PCB material to provide better strength and sound performance. We also replaced the gasket material with silicon for even better sound and easier installation. Another upgrade is that the Thera now support multi-mounting-system: PCB Gasket plateless or with plate and Top Mount.
Both Hotswap and Soldered PCB can be added with a volume knob but need to be purchased separately.
Plates
For the instock sale, we will provide PC plate (supports Gasket mount) and carbon fibre plate (Top mount). And we highly recommend you to try the plateless build, so much flex *chefkiss*
The plates will be in 2 different options: for plate mount stabilizers or PCB mount stabilizers.
Keymap
Instock color options (More colors will be released for GB sale)
Off-white
Grey 430c
Navy 295C
Theme Keycaps
We also prepared some sets of Thera theme keycaps for you to choose from, from retro warm white and gray color scheme with some themed keycaps with Greek letters.
General infomation
Keyboard Kit color: Off-White/Grey 430C/Navy 295C/GB will release more color
Weight: Stainless steel black matte PVD
Case Material:6063 Alu
Badge: Greece/anchor/rudder hard-bundled with instock keyboard colorways (at GB you will be able to freely choose the badge)
           75 badge/Santorini badge/Rudder knob only available at GB
Mounting: Top Mount/PCBGasket Mount (Plateless supported)
PCB: 1.6mm Soldered or Hotswap;BLE hotswap(GB only)
Plate material: 1.5mm PC plate supports PCB gasket mount
               1.5mm Carbon Fibre plate supports top mount;GB sale will be more options
Matching Theme Keycaps: Three colorways (in stock)
Box Content
1*Top case
1*Bottom case
1*Stainless steel weight (black matte PVD)
1*standard badge (hard bundled with colorway during instock sale)
1*PCB (hotswap/soldered/GB only: BLE hotswap)
1*1.5mm Plate(PC/Carbon Fibre)
1*1mm+ 1*2mm bottom case poron foam
1*3.5mm switch poron foam
1*5mm switch poron foam (recommended for plateless building)
2*3mm battery cavity foam
1*0.5mm PE poron foam
1 set of Silicone gasket socks
1 set of Screws and tools
Sales Information
Price:
Standard kit:$270
BLE Version kit:$305
Tentative launch time: End September
Additional Extras and price
Instock Extras:
PCB: $30/$65(BLE hotswap)
Plate: $25(pc/Carbon Fibre)
Foam kit: $15
Keycaps: $50
GB only Extras (also includes all instock Extras)
Greece badge: $20
Anchor badge: $20
Rudder badge: $20
Santorini badge: $20
75 badge: $40
Rudder knob: $45
More renders
Explosive view
« Last Edit: Tue, 06 September 2022, 03:39:48 by made in China »
Offline towi1989
Re: Holiday time by the Aegean Sea - Thera75 V2
« Reply #1 on: Sun, 31 July 2022, 04:36:48 »
This looks awesome. Why you do this to me!?
Offline Necrolegion
« Reply #2 on: Sun, 31 July 2022, 10:05:09 »
It's insane to see you guys going for a R2 Thera, especially while keeping the price about the same as R1 while adding more value to it!
I supported you guys on the Vast60 R1 & R2, Thera75 R1, and Glacier80 (R1). Never disappointed so will gladly support this one too.
My Thera R1 is still one of my flexiest boards and it also sounds amazing. Cannot wait to get my hands on the R2!
Offline freakologic
« Reply #3 on: Sun, 31 July 2022, 10:47:11 »
missed the V1 and FOMOed like a *****, surely won't miss this one!!
Offline PuNkShoO
  • I make keyboard switches.
    • Check out my projects!
« Reply #4 on: Sun, 31 July 2022, 13:02:51 »
Will the V2 PCB fit and function in the V1?
Offline johntron25
« Reply #5 on: Mon, 01 August 2022, 00:46:11 »
no one wants this lol. Look at the response in your own server.
Your Glacier80 shipment has been a ****show.
#CashGrab
« Reply #6 on: Tue, 02 August 2022, 04:13:05 »
The Thera75 v2 can not match the v1,either the pcb or the badge.
Offline Banzai
« Reply #7 on: Tue, 01 November 2022, 10:36:54 »
Might grab one of these. Been wanting to do a navy blue nautical themed build with KAT Atlantis, and 75% is my favorite layout.
Stupid question: Is the Rudder Knob an actual functioning rotary encoder? Or is it just a fancy badge that spins?
Offline FiXXXerX
« Reply #8 on: Thu, 08 December 2022, 16:06:44 »
Any place that I could buy the Navy keycap set? Can't seem to find it in stock anywhere, not sure if it's permanently OOS.
« Reply #9 on: Sun, 11 December 2022, 21:11:52 »
https://createkeebs.com/collections/keycaps/products/in-stock-thera75-v2-keycaps createkeebs website,you can purchase it
Offline hzh0525
« Reply #10 on: Wed, 12 April 2023, 15:32:21 »
I love the Knob!
