Author Topic: PCB colours changed on Planck  (Read 5509 times)
Offline sandywind
« on: Wed, 03 August 2022, 19:59:34 »
Hi all,
the 8 leds of my OLKB Planck PCB suddenly changed colour. They were pink (sort of), now they are red.
Is there a key combination that changes the colour, I might have inadvertently pressed?
The page that came with the keyboard does not mention it's possible to change colours.  Either it's an undocumented feature or this sample is malfunctioning.
Corsair Vengeance K65 w/ SP DCS Twilight Keycaps | Poker II w/ Danger Zone keycaps | HHKB Pro 2 | Realforce 87UW55 | IBM PC BS 80's | OLKB Planck | IC WhiteFox | Varmilo VA87ML
Re: PCB colours changed on Planck
« Reply #1 on: Sat, 06 August 2022, 19:49:09 »
Yes, there's a key for that.  I'm not a QMK expert but if you hold the raise and lower keys this is the layer keymap it will activate, the top row all look to be LED related (except Reset and Debug) so press them and see what happens.
Code: [Select]
/* Adjust (Lower + Raise)
 *                      v------------------------RGB CONTROL--------------------v
 * |      | Reset|Debug | RGB  |RGBMOD| HUE+ | HUE- | SAT+ | SAT- |BRGTH+|BRGTH-|  Del |
 * |      |      |MUSmod|Aud on|Audoff|AGnorm|AGswap|Qwerty|Colemk|Dvorak|Plover|      |
 * |      |Voice-|Voice+|Mus on|Musoff|MIDIon|MIDIof|TermOn|TermOf|      |      |      |
Offline sandywind
« Reply #2 on: Sat, 20 August 2022, 21:50:09 »
Yes! Thank you very much.
