Author Topic: [IC]Arqtisan Box - Boxes arrived - QC starting NOW! (12/07/22)  (Read 9916 times)
Offline arq1999
« on: Wed, 03 August 2022, 21:56:27 »
GB Link
GB Live 10/01/22 - 11/05/22
GB post is pending
Prototypes
Top and Bottom
Front View and Side view
Older Proto Pic
Update 11/30/22
Production Done and in route to me!
Update 11/21/22
Machining done
Waiting anodizing if everything goes well it ships by the end of the week.
Rubber feet arrived
Im going to order the packaging material now.
Next update when I get tracking.
Update 11/09/22
GB Period over
Invoiced Paid
ETA for Manu completion Nov 26th
Next update when machining is done
Thank you everyone!
Update 10/06/22
GB is live
Update 09/14/22
Hi everyone!
First of all I want to thanked everyone who has supported this project so far. Now lets talk updates.
- Raw material is secured and there wont be a increase in price.
- Stands for the case have arrived.
- Added the total weight of the case for anyone that was wondering and its heavy boi
- I have also decided that there wont be a logo in the top pc maybe in the bottom but probably not
- Currently working on the website. Should be done by the end of the week.
- Pending New photoshoot with stand
- Target GB date 10/01/22.
Sale format is going to be FCFS at MOQ 50.
if you have any other feedback please let me know
Revisions and Idea
The main idea for the project was to learn fusion360, but also to make an artisan case that I personally like.
Many artisan cases rely on magnets to hold the cover on top and I just didnt like that. So this is my approach. My first Idea was to make a case with a rail system, but it became too complicated and it was way to expensive. (shoutout to rmendis because he was able to make it!)
V1:
The idea was to make a somewhat gasket mount system to prevent from the acrylic to hit the alu, but after making the first prototype I realized that It wasnt necesary
Explored view of V1
V1.1 and current: I removed the gasket and added feet.
Specs
  • Alu 6061
  • Weight: 2.6lb or 1.1kg
  • CNC Acrylic Top
  • Bead Blasting 150#
  • Rubber Feet
  • 7x7 Artisan Box
  • 19cm x 19cm x 3.1cm
  • Max artisan height: 19.85mm
  • Lead Time 3 months
Price (8/05/22)
MOQ 50 will cost $160 per unit.
This new quote was just gave it to me yesterday. They also told me the there was a price drop in terms of raw material which is good! Im pretty happy with this price. Let me know what you guys think
Colors and Logo
Black
e-White
Red
Logo
Free Stand
After some feedback about the stand. Ill be able to source it from china at no extra cost! This is the same stand that I used for the previous picture. I need to do some testing to see whats the max angle but easy could do up to 45 degrees
Acknowledgments
  • To Mr. Bingo for doing the renders
  • To Digidier and Pensa73 for helping me with fusion360
  • To VatoDeHarina, Annie, Luis(latamkeys) and many more
That was it for today and thank you for reading!
« Last Edit: Wed, 07 December 2022, 15:21:16 by arq1999 »
Offline arq1999
Re: [IC]Arqtisan Box - IC - Premium Artisan Box
« Reply #1 on: Wed, 03 August 2022, 21:58:12 »
Reseverd
Offline o3okevin
« Reply #2 on: Wed, 03 August 2022, 22:15:48 »
How does someone pick this up? The majority of the grippable edge is the acrylic cover, but that doesn't seem to be attached to the base in any way.
Offline arq1999
« Reply #3 on: Wed, 03 August 2022, 22:58:11 »
Well you just grabbed from the bottom. Unless you put it 90 degree the cover doesn't fall. I have a picture where I put it in a stand and it works just fine. I'll reply with it tomorrow morning.
« Last Edit: Fri, 05 August 2022, 06:08:59 by arq1999 »
Offline arq1999
Re: [IC]Arqtisan Box - IC - Premium Artisan Box - Price update
« Reply #4 on: Fri, 05 August 2022, 06:42:21 »
Price update!
Offline milka158
« Reply #5 on: Sat, 06 August 2022, 07:27:17 »
Maybe you can use some magnets to keep the cover in place more securely?
Offline alvrnicu
  • Collecting Bongo Cat Keycaps
« Reply #6 on: Sun, 07 August 2022, 15:18:34 »
It's very clean and I like the size. Any idea about how steep of an angle it can get without the caps falling off? Definitely'd be a plus from me and a reason to switch off my current bongo cat case if it displays well at an angle.
Offline arq1999
« Reply #7 on: Mon, 15 August 2022, 10:56:40 »
I would say around 45 but I can do more testing in a bit. Ill be also providing the stand for free! Im able to source it out from china at no extra cost from you guys. Thanks for the interest!
Offline arq1999
Re: [IC]Arqtisan Box - IC - Big Update 09/14/22
« Reply #8 on: Wed, 14 September 2022, 09:01:33 »
Hey, everyone I have updated the post with some more information of the current status. Please let me know if you have any other questions or suggestions
Offline alvrnicu
« Reply #9 on: Thu, 15 September 2022, 00:00:21 »
Looking forward to seeing it displayed with the stands that have arrived :)
Offline arq1999
Re: [IC]Arqtisan Box - GB is live!
« Reply #10 on: Thu, 06 October 2022, 09:54:30 »
GB is live!
GB post is pending approval.
Offline alvrnicu
« Reply #11 on: Tue, 01 November 2022, 16:09:57 »
Size of box and stand did it for me, put in for one. Hopefully it hits its MOQ :)
Offline arq1999
« Reply #12 on: Sat, 05 November 2022, 08:45:47 »
Thank you! Dont worry about MOQ it is getting made.
LAST Day!
Offline ZenKeycaps
Re: [IC]Arqtisan Box - GB Last Day!
« Reply #13 on: Sun, 06 November 2022, 02:45:37 »
Great piece for collectors, I'll make one for myself too :)
Offline arq1999
Re: [IC]Arqtisan Box - Machining Done - Waiting Anodizing (11/21/22)
« Reply #14 on: Mon, 21 November 2022, 08:17:54 »
Update here cause my GB thread never got approved :blank:
Machining done.
Anodizing is next.
Hopefully ships to me by the end of the week.
Rubber feet arrived.
Offline Rationalkeys
« Reply #15 on: Mon, 21 November 2022, 09:35:59 »
Machining done.
Anodizing is next.
Thanks for the update.
Offline arq1999
« Reply #16 on: Wed, 30 November 2022, 22:07:00 »
Update 11/30/22
Pictures from China. Production is done. Shipping on the way.
Offline alvrnicu
« Reply #17 on: Thu, 01 December 2022, 13:10:37 »
Can't wait!
Update 11/30/22
Offline arq1999
Re: [IC]Arqtisan Box - Machining Done - Shipping to me (11/30/22)
« Reply #18 on: Wed, 07 December 2022, 15:20:45 »
They have arrived! QC starting now
Thanks everyone for the support
