Author Topic: [IC] Epomaker Alice - An Ergonomic QMK/VIA Gasker DIY Keyboard Kit  (Read 7172 times)
Offline EpomakerKeyboard
    • Epomaker
Hi everyone!
We would like to share with you an Alice keyboard we are working on. We might put it to another groupbuy if you like it!
It will be much appreciated if you could spend some time giving us some feedback!
Find details in IC Form
Get more updates on our Discord Server
Epomaker Alice QMK/VIA gasket hot-swappable acrylic wired mechanical keyboard DIY kit is coming soon! It is made with an acrylic case to be shine-through. To offer more fun in customzing the keyboard, it also supports the VIA/QMK program.
Specs:
Keyboard Model: Epomaker Alice QMK/VIA DIY keyboard kit
Keyboard Layout: Split layout
Hot-swap Availability:  3/5-pin Hot-swappable
Keyboard Mount Type: Gasket mounted
Connectivity: USB-C
Case Material: Acrylic Case
Plate Material: PC
Program: Compatible with VIA/QMK
Backlight: RGB (sorry for the north-facing LEDs)
We might turn the top corner key into a knob if you could give your opinion on our IC Form. And there might be other modifications to this board, such as adding other case colors if we receive more than 200 votes in the form. So it's waiting for you to unlock the barebone kit's final version!
289881-0
289883-1
289885-2
289887-3
289907-4
289909-5
« Last Edit: Thu, 04 August 2022, 23:00:44 by EpomakerKeyboard »
Offline panka
Re: [IC] Epomaker Alice - An Ergonomic QMK/VIA Gasker DIY Keyboard Kit
« Reply #1 on: Thu, 04 August 2022, 20:05:07 »
reserved
Offline stewfayew
« Reply #2 on: Thu, 04 August 2022, 22:09:30 »
Where is the solder pcb?
Offline ankit
  • Formerly ankit-sachdeva
Offline jiminojimi
« Reply #4 on: Fri, 05 August 2022, 06:56:32 »
Transparent glass green is an excellent and original choice, it really feels like a glass coffee table from the 90s
Offline LMarci
« Reply #5 on: Fri, 05 August 2022, 07:37:29 »
 :blank:
Offline The0rigina1
  • fumoposting
« Reply #6 on: Fri, 05 August 2022, 10:12:23 »
Alice deez nuts, this is not an alice.
Offline NamesReed
  • 40 enjoyer, Cheapskate.
« Reply #7 on: Fri, 05 August 2022, 12:30:00 »
Definitely get coffee table/mason jar vibes from the clear green. I dig it
IDK man, be positive, kind and caring.
Offline Mike2046
« Reply #8 on: Sun, 07 August 2022, 14:22:32 »
Forget the knob. Make the switches South-facing first. North-facing switches is a typical gamer move, because of the RGB. Gamers won't use Alice layout.
