Author Topic: cheaper or more expensive  (Read 2641 times)
Offline PlayBox
« on: Sat, 06 August 2022, 17:52:08 »
so im thinking about buying my first keyboard ( i'm in the hobby for quite a long time already) and i have 2 keyboards on my target the cheap that is
krux atax pro rgb (gateron/outemu) that might be unknown for you bevause its gaming, and its like poland only (where i live), but its like dirt cheap especially used and it looks pretty clean. im planning on (heavy) modding this one, that is swapping swotches, keycapls usb-c mod etc. and there is the expensive one akko 5075s/b plus. akko should be better quality but the gaming keygboard would be more customisable for me (im on a budget) and muchb more fun to make. which one do you think is better? im open for reccomendations but there is almost no tkl/75% keyboards that fully build wpuld fit into my 120$ budget.
propably sent from my amazon kindle 10th gen
