Author Topic: I am looking for the exact mounting hole dimensions of the KBDfans DZ65 PCB  (Read 5859 times)
Offline Blitzschnitzel
Hi I want to 3d-print a case for DZ65 PCB but I can’t find any documentation on the mounting hole placement. KBDfans has dxf files for older PCBs but nothing for their current PCBs. Does someone know the dimensions? Or is this board perhaps based on another board for which documentation exists?
Anyone got some information?
Offline PlayBox
maybe find a compatible case and try to find mounting hole dimensions of a case?
propably sent from my amazon kindle 10th gen
All cases seem to be aluminium and to expensive to buy just to take some measurments.
Offline PlayBox
i mean these may be avaible online unlike the pcb
Re: I am looking for the exact mounting hole dimensions of the KBDfans DZ65 PCB
« Reply #5 on: Sat, 03 September 2022, 11:15:22 »
This one?  There are three holes that look like slits in gold circles (between Tab and Q, ANSI \| and ], and left of Right Alt) which are in the same positions as they are on the standard Poker/GH60 and compatible PCBs.
The other holes appear to be spaced equally between switches so it should be easy enough to calculate their positions based on that.
