Author Topic: [IC] Simple | 60% Plateless Top mount  (Read 7951 times)
Offline djok0127
« on: Tue, 09 August 2022, 02:32:16 »
Simple
Simple is a budget 60% plateless + top mount keyboard with simplistic design.
290021-0
IC FORM
Tofu Discord
290025-1
290023-2
290027-3
Specifications
Mount - Plateless Top Mount
Typing Angle - 5°
Front Height - 18.5mm
Width - 115mm
Length - 294.4mm
Standard Daughter Board top right corner
Pricing
TBD
Sound Test
Thanks to:
ToastyStoemp for the PCB design
Penbird for the writing
Please fill out the IC FORM and share your thoughts on Tofu Discord
Prototype Pictures
290045-4
290049-5
290051-6
« Last Edit: Tue, 09 August 2022, 18:50:24 by djok0127 »
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] Simple | 60% Plateless Top mount
« Reply #1 on: Tue, 09 August 2022, 02:56:40 »
i'd strongly recommend moving the center two mounting tabs near the spacebar more outwards
did not make the connection that i had gotten the chance to type on an older revision of this board. strongly recommend removing the two bottom center mounting tabs all together -- I thought it felt much better without those screwed in
« Last Edit: Tue, 09 August 2022, 03:32:37 by ankit-sachdeva »
Offline chat and team
« Reply #2 on: Tue, 09 August 2022, 03:00:05 »
sure if it was sub 200
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Sissy
« Reply #3 on: Tue, 09 August 2022, 03:05:33 »
simple
Offline KeyBros_
« Reply #4 on: Tue, 09 August 2022, 03:35:23 »
Really like it, hope the pricepoint it's nice, probably in
Offline stewfayew
« Reply #5 on: Tue, 09 August 2022, 14:22:25 »
I see potential
Offline daviddgm
« Reply #6 on: Tue, 09 August 2022, 17:19:51 »
Nice simple design... What is the price expectation?
Offline djok0127
« Reply #7 on: Tue, 09 August 2022, 17:54:30 »
@daviddgm
I want the price to be low as possible...
But depends how well we go with the GB. There is not a set price yet, but I wanted to go around low - mid 200s.
Possibly lower than 200 if there are more people who are interested.
Offline zyyg
« Reply #8 on: Sat, 13 August 2022, 10:33:06 »
it's only wk?
Offline Nonnegaard
« Reply #9 on: Mon, 15 August 2022, 01:34:44 »
the price is make or break here.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
