Author Topic: [IC]The Xtreme 60% Update: Exploded View Added And Proto Coming Soon  (Read 5868 times)
Offline ThomasLT
    • ThomasLT Studio
Layout:60%
Price:$3XX
Units:Unlimited
The group buy will be held at https://www.thomasltstudio.com/
Google Form Interest Check: https://forms.gle/mMHbd8VZwJJk9RrN6
JOIN OUR DISCORD FOR FREQUENT UPDATES: https://discord.gg/fjSn5dsFCj
Renders
Navy Blue
E-White
Midnight Black
Graphite
Hotswap layout
Soldering layout
Base Kit Specifications
  • Poron dampener
  • Grade 6063 anodised aluminium case
  • Interchangeable brass accent pieces
  • PVD coated brass weight
  • 1.5mm brass/carbon fiber/polycarbonate/FR4 plate
  • 60% layout PCB
  • 5.5 degrees typing incline
  • rubber feets
  • Silicon socket
PCB Specifications
  • QMK and VIA Compatible PCB
  • Center USB-C(Daughterboard)
Case Colours
  • Midnight Black
  • E-White
  • Navy Blue
  • Graphite
Update:Here is the exploded view of The Xtreme
And proto is coming soon!
Join us on Discord & Instagram:
Discord: https://discord.gg/fjSn5dsFCj
Instagram: https://www.instagram.com/thomaslt_studio/
« Last Edit: Mon, 10 October 2022, 09:06:58 by ThomasLT »
Offline Kamui7
Re: [IC]The Xtreme 60% Silicon Socket Mount Keyboard
« Reply #1 on: Wed, 10 August 2022, 12:15:54 »
Ne exploded or internal view?
Offline chat and team
« Reply #2 on: Wed, 10 August 2022, 12:17:31 »
where proto
and this is ugly
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline blaqbern
« Reply #3 on: Wed, 10 August 2022, 12:18:47 »
What is a silicone socket mount?
Offline Backspace2
  • Third most used key on the keyboard is Backspace!
« Reply #4 on: Wed, 10 August 2022, 12:30:13 »
Proto?
Yes
Offline stewfayew
« Reply #5 on: Wed, 10 August 2022, 15:38:19 »
I can't tell how this board is mounted
Offline Nuap
« Reply #6 on: Thu, 11 August 2022, 01:14:12 »
Proto? Internal view?
Also, why is split right shift absent from the solder layout?
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #7 on: Thu, 11 August 2022, 02:53:22 »
any pictures of the internal view?
I can't figure out what is "Silicon Socket Mount"  :(
