Author Topic: [GB] Ciel65 - Gasket 65% - GB Live 8/12-9/2  (Read 11136 times)
Offline MIGHTY CHICKEN
« on: Thu, 11 August 2022, 17:33:33 »
Ciel65
Originally based off the Bakeneko by kkatano and now Ciel, Ciel65 is a 65% version of the Ciel.
Now with an external weight, in 6063, and PC
Discord
Za Specs
  • Case:6063 Aluminum or PC with a through Brass Weight
  • Finish:Anodised or Frosted, Brass will be passivated
  • Typing Angle:6°
  • Mount:Gasket Gummy Worm O-Ring
  • PCB:QMK/VIA compatible, Multilayout Hotswap, Solder in extras
  • Plate:5052 Alu Plate anodised Silver, other options avail in extras, PC, FR4, Pom
  • Weight:1.1kg unbuilt, 1.6kg built
  • Kit:Case, Weight, 5052 Plate, 50a Oring, Custom Silicone Feet, JST and Daughterboard, All required hardware
  • Colors: Burgundy, Black, Silver, Lavender, Forest Green
Purchasing Info
Layouts and Some Other Specs
Screw-In stabs supported
Solder on RGB underglow strips sold alongside
The chicken engraving has been moved internally and replaced with the cloud on outside
Extended Album
Media
Saladknight Soundtest 1
Saladknight Soundtest 2
Nearlucid Review
Re: [GB] Ciel65 - Gasket 65% - GB Live 8/12-9/2
« Reply #1 on: Thu, 11 August 2022, 17:33:44 »
reserved for updates
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2 on: Mon, 15 August 2022, 11:05:30 »
approved
Offline leexy
« Reply #3 on: Tue, 30 August 2022, 01:22:54 »
is there a photo of the back of the hotswap pcb?
« Reply #4 on: Sun, 18 December 2022, 00:16:59 »
Haven't updated in a while, finished manu and packing/preparing for shipment
