Author Topic: [IC] Helheim Designs Freja65 65% Glass Keyboard Kit  (Read 13381 times)
Offline HelheimDesigns
  • Location: Bay Area, California / Albuquerque, New Mexico
    • Helheim Designs
« on: Fri, 12 August 2022, 12:24:02 »
Link to IC: https://forms.gle/37C2RzGfc85ShWqu9
Hello GH! Angel from Helheim Designs with an IC for our next case, only this time we are doing a full kit.
Freja65 [ fray-aa ] is our premium 65% case made out of five low-iron glass pieces that are melted together to make one solid piece of glass.
This board will be Gummy O-Ring mounted similar to the Bakeneko, but instead of just an O-Ring, we will also include rubber inserts that go into screw holes on the PCB to make the fit universal to most 65% PCB's.
This kit will include:
1x Freja65 Glass Case
2x Gummy O-Rings with different hardness (30A and 50A)
1x Soldered PCB
1x 65% Plate of your choice
5x Rubber inserts for screw holes to create space between PCB and the bottom of the case
1x Microfiber cloth
1x set of Cherry Clip-In Stabilizers (3x 2u, 1x 6.25u, 1x 7u)
Pricing is not yet confirmed, but we expect this kit to be less than $400.
This time around we will have both Frosted and Clear options
290198-0
Back of each case finish
290200-1
Clear case with underglow in dark
290202-2
Frosted case with underglow in dark
290204-3
PCB with our own custom design
290206-4
Frosted case with underglow in light
290208-5
Clear case with underglow in light
290210-6
Other information for upcoming products can be found at our instagram, our website, or our discord:
https://www.helheim.design
https://www.instagram.com/helheimdesigns
https://discord.com/invite/yTQWbwecUM
IC will be open until 8/30/2022
Thank you!
Offline stewfayew
Re: [IC] Helheim Designs Freja65 65% Glass Keyboard Kit
« Reply #1 on: Fri, 12 August 2022, 12:36:33 »
You mean the little rubber standoff rings for tray mount or an actual O-ring?
    • Helheim Designs
« Reply #2 on: Fri, 12 August 2022, 12:38:58 »
We will provide two full size O-Rings to go around the whole PCB assembly for mounting (30A and 50A), this case will not be a tray mount
Offline chat and team
« Reply #3 on: Fri, 12 August 2022, 13:34:37 »
I dont know too much about the material
can you provide a video of a drop test from various heights and on different surfaces
cant speak too much about the price i have no idea about glass
but under 400 for this is pretty steep for me
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #4 on: Fri, 12 August 2022, 16:34:53 »
Looks great guys! Awesome use of the material
Offline lishan1988
« Reply #5 on: Fri, 12 August 2022, 18:44:06 »
Would it be possible to put the octopus design at the bottom of the PCB so we can see it through the glass case after the keyboard is built?
Offline jiminojimi
« Reply #6 on: Wed, 17 August 2022, 07:54:26 »
I’ve been dreaming of a glass keyboard for a long time. It’s almost an Insta buy … hotswap and maybe add in a wrist rest.
Offline turangaleela
  • らんだむぶれいん!わおっ 叫んじゃえ わおっ
« Reply #7 on: Wed, 17 August 2022, 15:51:08 »
This is hot, if not impractical... but so pretty... IC filled out; looking forward to more updates!
Offline Mr Chrome
« Reply #8 on: Tue, 23 August 2022, 10:37:24 »
The PCB is secks. The clear option is secks. I’m 60s gang though so I hope you bring back the Baldr in clear…
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #9 on: Tue, 23 August 2022, 16:21:38 »
No ISO support?
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline AshF
« Reply #10 on: Sun, 12 March 2023, 17:56:00 »
No ISO and no exploded or the very least an option for a blocker....grrrr.
GLWIC
Sent from my ASUS_I003D using Tapatalk
