Author Topic: [IC] GMK Euler Group Buy will live on December 28, 2022  (Read 59031 times)
Re: [IC] GMK Euler now with Cadet Sublegend (Oblotzky approved)
« Reply #50 on: Tue, 23 August 2022, 08:54:38 »
also can you make a comparison image w dolch
maybe you did and i just missed it?
Hi there, I updated the post with some color comparison. Hope that you find it's useful.
it is, thank you
Offline iamtienng
« Reply #51 on: Tue, 23 August 2022, 09:12:57 »
Have you considered including <> instead of cursed double \ for iso coverage?
This. If you want to do terminal ISO (basic support) there should be a r4 <>, not 2 pipes. Check GMK Classic Retro Zhuyin if you're unsure how to kit terminal ISO.
Also consider adding navigation sublegend to the numpad. It looks a bit empty in contrast to the busy alphas.
Fixed R4 / | with R4 < >.
For the numpad, I would like to keep it for my aesthetic.
I also suggest adding mod color keys for R1 tilde and R2 pipe too. These are very important for aesthetic in some layouts. Hope you consider adding them. About the new renders, are those N9 and CR? They look a lot like them, however the alpha color is not N9 like Shashin in the comparison you make. I would love to see some deep green for board color  :thumb:
Pretty sad I probably won't be able to do this at R1 to save on production costs. Thank you very much for your opinion.
Includes R3 1u home for some unknown reason but won't include standard keys like mod pipe and mod tilde to save production costs. Makes sense.
I also wanted to point out the obvious dodging on all the people saying that a dark green fits your inspiration much better.
I totally forgot about researching on the R3 1u Home. Final kitting will be announced after quoting with GMK. Don't worry about that.
Offline anderw
Re: [IC] GMK Euler (now with Color Comparison)
« Reply #52 on: Wed, 24 August 2022, 22:33:28 »
RESERVED
Offline Alva_Works
« Reply #53 on: Thu, 25 August 2022, 07:36:39 »
Im in  ;D
Offline mariajose1197
« Reply #54 on: Thu, 25 August 2022, 12:25:51 »
I really want that desk mat, is gorgeous.
This idea is great, I'll like to see more green color than grey on the keycaps, but its an excellent choice.
I need that Euler’s Identity novelties.
Offline iamtienng
« Reply #55 on: Thu, 25 August 2022, 13:33:14 »
Kitting changed. Thank you all for your opinion.
Offline iamtienng
« Reply #56 on: Thu, 25 August 2022, 13:38:11 »
The color comparison GMK Nord is as good a guess as what we’ll get as any out there
Love the work you’re putting in. The alphas being darker than N9 are gonna be real dark in non-sunlight and I’m looking forward to it.
Thank you so much <3
adding mod tile and pipe are not going to bump the price up exponentially dont be that guy
I fixed base kit with some changes, thank you so much.
RESERVED
Im in  ;D
I'm also quite surprised that the deskmat is so loved. Thank you so much.
For the color, green is also a good color but to be able to match as many keyboards as possible, I think a gray-toned black would work better.
Offline nvh2092
« Reply #57 on: Fri, 26 August 2022, 01:36:07 »
There is a snall error in legend info of the mini accent bar in the bar kit render, it should be 2.75.
Offline jtqx
« Reply #58 on: Fri, 26 August 2022, 08:28:11 »
numpad subledgends pls
Big boys: JER1800, Cypher, IBM Model M, W1-AT
TKLs: F1-88, F1-8x_722, F2-84, EO87, Matrix ME, IBM 'SSK', Bias, NCR80
Small boys: HHKB Pro 2, KWa.6, Maggio
Others: Praxis, LZ Phase, Sagittarius
65% and 75% bad
Offline iamtienng
« Reply #59 on: Fri, 26 August 2022, 10:02:02 »
Fixed that. Thank you so much <3
Thank you so much for your opinion.
Mono numpad is good for left hand numpad (mirrored layout) so I would keep it mono like that.
Offline nvh2092
« Reply #60 on: Fri, 26 August 2022, 16:41:59 »
Small change request, Code key should be "Super" or "System" to better go with any OS
Offline DeMechanica
« Reply #61 on: Sat, 27 August 2022, 05:42:18 »
How do they go better with any OS? They are all equally applicable, no?
Offline bshendy
« Reply #62 on: Sat, 27 August 2022, 12:46:19 »
Great set; In reference to the deskpad design, it's kinda weird seeing imperfect handwriting, and then seeing the most perfectly drawn sphere on what appears to be a chalkboard. Just wanted to make note of that lol. GL w/ IC!
Offline EdgeOfInfinity
« Reply #63 on: Mon, 29 August 2022, 17:26:45 »
cadet subs really fit nicely here and the color comparisons are always appreciated. will def keep an eye on this if/when it hits GB
Offline FiEND
« Reply #64 on: Mon, 29 August 2022, 17:31:41 »
great set. def going all in on this if/when hits gb.
Offline iamtienng
« Reply #65 on: Fri, 02 September 2022, 10:18:47 »
Thank you so much for your support <3
Offline aamo
  • aaaaaaaaaaaaamo
Re: [IC] GMK Euler
« Reply #66 on: Fri, 02 September 2022, 11:13:37 »
Color: Simulate colors on a chalkboard.
What does this mean and what are the colors?
Also consider an ISO novelty.
I mean colours are inspired by a chalkboard like this:
I will publish colour after group-buy (if interest is high enough for GB).
For ISO novelty, I am trying to do it.
Thank you for your opinion.
I would love a deskmat that has denser writing like that sample image, the current deskmat design is neat but a little sparse for my taste
Please go full A Beautiful Mind on the chalkboard thank you
Offline vhaarr
Re: [IC] GMK Euler (render will be added daily)
« Reply #67 on: Thu, 08 September 2022, 10:05:03 »
ignore all the people who want more writing please
I want deskmat with no writing whatsoever plz
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline arr1
  • Ñ supporter
Re: [IC] GMK Euler
« Reply #68 on: Sat, 29 October 2022, 04:01:41 »
Would you consider any other deskmat design? Not really sure about the one given.
Offline TheLostTurtle
Re: [IC] GMK Euler
« Reply #69 on: Sat, 29 October 2022, 23:47:18 »
Ahhhh Euler.  The most mispronounced name for math undergrads everywhere.
I'm in!
I'd argue L'Hopital is a good contender for that title
Offline ph4nt0m
Re: [IC] GMK Euler
« Reply #70 on: Sun, 30 October 2022, 03:29:09 »
I'm in!
Even the spelling might be challenging.
Offline DaaDaa
Re: [IC] GMK Euler
« Reply #71 on: Sun, 30 October 2022, 05:37:19 »
Change the shift to text only or better yet actually do some design and make a new cool graphic.
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline jtqx
« Reply #72 on: Mon, 31 October 2022, 00:57:54 »
would argue that few people use numpad is the first place, much less a mirrored layout on southpaw. even for southpaw users, its an option to use it mirrored or not.
imo, the presence of numpad subs would fit the Euler theme much better and fit the aesthetic of the cadet subs better, due to the 'busyness'.
numpad subs are also functional in nature, and its been sorely lacking in most new sets. but i guess if you want to ensure compat for the smallest groups of users (numpad users, who use it southpaw, and mirrored) its fair too.
65% and 75% bad
Re: [IC] GMK Euler
« Reply #73 on: Tue, 01 November 2022, 16:16:13 »
Is there a discord or mailing list to get updates about how the project is going?
Offline chigi22
Re: [IC] GMK Euler
« Reply #74 on: Tue, 01 November 2022, 16:32:26 »
Would love to see macro columns as an add-on kit
Offline acerb
Re: [IC] GMK Euler
« Reply #75 on: Thu, 03 November 2022, 06:11:14 »
I love the new renders with the Werk.One! (discovered it in the discord)
And the set is really ncie now with the cadet sub legends. No ISO novelty is final?
Offline iamtienng
Re: [IC] GMK Euler
« Reply #76 on: Sat, 05 November 2022, 12:24:02 »
aaaaaaaaaaaaaaaaaaamo
Thank you for your support <3. The deskmat design is final and if there is anything change, it will be made in the future.
Thank you for your support <3. The design is final and if there is anything change, it will be made in the future. I will note your opinion, if it can be run for a V2, more novelties will be made.
For the first run, I would like to make it for as many people as possible, if there are not many people want that, I will change in the future. Thank you for your comment <3
I think you are the same person that I replied on reddit, please check it out. Thank you so much for your support.
I will announce the colorway soon and it will relate to your request. Thank you for your comment <3
Thank you for your support <3. Sadly at the end no ISO novelty, I will try to do more novelties if it can be run for a R2.
Have a nice day you all. Thank you so much for your support!
Offline iamtienng
Re: [IC] GMK Euler (Color, HIBI, Timeline revealed)
« Reply #77 on: Thu, 01 December 2022, 18:54:24 »
Time for Group Buy.
Offline BruceDinh
  • Explorer | Artist | Petrolhead
    • ORI CLUB
« Reply #78 on: Fri, 02 December 2022, 09:07:04 »
The color combination is so beautiful, goodjob  :thumb:
« Reply #79 on: Tue, 06 December 2022, 13:39:01 »
the HIBI is really cool, looking forward to joining this one.
Offline honeybee
Re: [IC] GMK Euler Group Buy will live on December 28, 2022
« Reply #80 on: Thu, 15 December 2022, 20:33:12 »
I'm in!
Offline iamtienng
« Reply #81 on: Sat, 17 December 2022, 10:33:22 »
I love Custom Cable, please check out Cable Collaboration with 15Cables for more information.
Offline arr1
  • Ñ supporter
« Reply #82 on: Sat, 17 December 2022, 15:36:47 »
Looks awesome. GLWB
Offline Ikeygai Designs
« Reply #83 on: Tue, 20 December 2022, 21:02:09 »
love this idea
