Author Topic: [GB] Aurora x Camping and WS Camping  (Read 3457 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
« on: Tue, 23 August 2022, 03:41:12 »
Hi everyone,
We are excited to bring you Ikki68 Aurora x Camping and WS Camping designed by Kingnestea. Now The GB is live on Wuque Website
Two Aurora x Case Designs
Ikki68 Aurora x Camping Peak
Ikki68 Aurora x Camping Camp
Introducing WS Camping
WS Camping applies all-sided dye-sub method. It's a new technique that changes the old dyb-sub heating process and solves problems commonly seen from traditional dye-sub PBT keycaps.
WS Camping keycap Prototypes, Comparison with GMK Camping, Aurora x Camping color chip, photos and videos
Group Buy Details
GB Time: August 23, 2022 - September 12, 2022
Delivery Time:Start packing and sending to Wuque Studio direct customers and vendors in Q1, 2023.
GB Prices
WS Camping Base (Burgundy), Cherry Profile, 79USD (Soft limit)
WS Camping Base (Green), Cherry Profile, 79USD (Soft limit)
WS Camping Novelties, Cherry Profile, 25USD (Soft limit)
WS Camping Spacebars, Cherry Profile,19USD (Soft limit)
Aurora x Camping keyboard kit, 169USD (Limited to 1000 globally)
Aurora x Camping Highlights:
  • Variable gasket mount structure. Remove some or all of the gasket chips to change from firm to bouncy. Both Silicone and Poron gaskets are included to fine tune the experience even further!
  • Default PCB (PCB05 Bodo) is a hot-swap PCB that supports multiple layouts with flex cut! This is a very unique feature that lets you use any or all of split L Shift, split R Shift, split Backspace, split spacebar, stepped Caps Lock and ISO Enter, anytime you want. No soldering necessary!
  • The badges are hot-swappable, meaning you can change them without taking apart the case!
Specs:
Case material: Injection molded Polycarbonate.
Default plate material: PC
Weight (fully assembled, with optional weight): 1040g
Weight (fully assembled, no optional weight): 720g
Case finish: Translucent top case, Opaque bottom case.
Typing angle: 6.5 degrees
Dimensions: 13.6" x 4.4"
Base height: 0.9" tall without rubber feet
What's included:
1x Ikki68 Aurora PC top case and bottom case
1x Multi-layout hot swap QMK PCB (Bodo)
1x Hotswap Name badge set
1x Default PC plate
1x Silicone dampening pad between PCB & plate
1x Silicone dampening pad between PCB & case
1x Silicon Gaskets Set
1x Poron Gaskets Set
1x Keyboard storage case
1x Black Coiled USB cable
6x 2u + 1x 6.25u set of stabilizers.
Extra screws, diodes, sockets, keyboard feet, hex screwdriver
Vendor
We'll be producing a maximum of 1000 Aurora x Camping (both Peak and Camp) in total. Each vendor has a different limit as below. Some vendors may share their QTY with others several days before end of GB.\
Cannonkeys: 370
Mech.land: 120
Dailyclack: 50
Mykeyboard.eu: 50
Proto[Typist]: 40
Brovotec: 50
ilumkb: 50
Rebult: 50
Zion Studios: 40
Taobaosoup: 30
Taiwan: 30
Wuque Studio China: 60
Wuque Studio International: 60
More Info about Aurora
Ikki68 Aurora is an affordable 68% variable gasket mount keyboard kit with an injection molded polycarbonate case. The default PCB has Kailh hot swap sockets and supports multiple splits like split space, shifts, backspace and more!
Please join Wuque Studio Discord for more discussions and updates.
Thank you again!
« Last Edit: Tue, 23 August 2022, 03:48:34 by Ckeeb »
Re: [GB] Aurora x Camping and WS Camping
« Reply #1 on: Tue, 23 August 2022, 17:48:51 »
Approved :thumb:
Offline Ckeeb
    • MELETRIX
« Reply #2 on: Tue, 23 August 2022, 22:03:45 »
Thank you  :thumb:
