Author Topic: [GB] XOX70 FRL TKL - Extras Available Now  (Read 163338 times)
Offline well_cooper
  • Turn metal in to typing machine
    • Thocc Supply
« on: Fri, 26 August 2022, 08:32:15 »
XOX70
Spec Summary
  • 8-degree typing angle with 2 internal brass weights (E-Clear coat treated)
  • Screwless exterior design (adjusted for switch  & plate clearance and ease of assembly)
  • Gasket Leaf Spring (full plate  & half-plate, multiple materials)[/*]
  • Solder and Hot-Swap PCB with flex cut (VIA ready) 1.6mm thick
  • Carry case included
Standard Kit Contents
  • Top & Bottom case with Badge, LED diffuser & weights pre-installed
  • PCB KIT (Solder / HS)
  • Full Aluminium Plate
  • JST cable cover
  • Gasket poron foams (with extra)
  • Rubber Feet
  • Assembly Screws + Torx driver
  • Badge light-blocking foam
  • 3u stabilizer wire x 2
  • Anti Static sheet, Poron case & plate foam
  • Carry Case
Extras
  • Full & Half plates in FR4, Aluminium, Full Plates in PC, POM
  • Solder & Hot-swap PCB with Daughterboard and cable
  • 3u stabilizer wire pack (2 wires per pack)
  • Gaskets
  • Foam Pack
  • Additional Screws
  • Feets
GB Date 31st Aug - 30 Sep (your local vendor timezone)
Availability - Unlimted (we will adjust production capacity to meet delivery time frame)
Delivery to Vendors - Q1 2023
Vendor
USA - Mechs & Co.
Canada - Shockport Keyboards
SEA - ilumkb
Europe - KeyGem
UK - Proto[Typist]
Vietnam - Uniqmeck
South Korea - Swagkeys
OCE - Thocc Supply
[/center]
Content Creator Builds
Colour
Link
Date & Time
SwitchDoctor
Lilac WK
https://www.youtube.com/watch?v=qDYfLzedoeM&t=20s
VOD Available
MrB0dyMassage
Black WK
https://www.youtube.com/watch?v=gdq6Cq7Nf7U
VOD Available
warmthoughts
Moss WKL
https://www.twitch.tv/warmthoughts
DONE
NEARLUCID
Plum WKL
https://youtu.be/yJENNgbqELc
DONE
LightningKeyboard
Black WKL
https://youtu.be/Qz2GC8RbMJE
DONE
Alexotos
E-White WKL
https://youtu.be/WHYyeLJH-1I
DONE
DBOKEY
Lilac WKL
https://www.youtube.com/c/%EB%93%9C%EB%B3%B4%ED%82%A4DBOKEY
In Progress
:3ildcat
Silver WK
https://www.youtube.com/c/3ildcat
In Progress
GB Colour offering
From top left to bottom right
  • Black & Silver
  • Silver & Blue
  • Moss & Black
  • Plum & Black
  • Lilac & Silver
  • E-White & E-Yellow
  • Dirty Pink & Black will not run
PCB Layout
Daughterboard - Aio3 Unified Daughterboard JST connector
The main PCB Solder version supports multi layouts, Hot-Swap is fixed ANSI with 7u spacebar
Exploded
Render Gallery - Full Render Album click HERE
Final Prototype Photo - Full Album click HERE
Typing test
Banner
Code: [Select]
[url=https://geekhack.org/index.php?topic=117730][img width=210 height=120]https://i.imgur.com/ffu8hrP.jpg][/img]
Change Log Since IC Post
1. Increase GB colour from 4 to 6
2. Dirty Pink will not run this time
3. Open Solder and Hotswap PCB option for Standard Kit
4. Added POM to plate option
Link to previous IC post click here
GB Updates will be shared in the first comment in this post, passed on to vendors and on Discord
Join Discord - Click HERE
« Last Edit: Sun, 09 July 2023, 00:37:56 by well_cooper »
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - Shipping!
« Reply #1 on: Fri, 26 August 2022, 08:32:34 »
RESERVED
Update - Early July 2023
Our own in-stock extras are available
Prototypist & Keygem also appear to have extras
No news from Mechs & Co at the time of this update unfortunately
Update - Mid June 2023
All our own GB orders have been shipped, extras are scheduled to be released at the end of the month
Update - Early June 2023
Our own stock have reached port and undergoing custom clearance then final delivery, GB fulfilment to follow soon
For other vendor shipment status please get in touch with your local vendor :thumb:
Update - Early May 2023
Vendor fulfilment has begun as of today. I ask you kindly NOT to bomb your vendor for their ETAs as we work through the logistic process.
Customers who purchased directly from us please wait for further announcements regarding address change, extras, ETAs, etc. More info to follow
Update - April 2023
https://thocc.supply/blogs/xox70/blog-posts-xox70-progress-update-late-april-2023
Update - March 2023
https://thocc.supply/blogs/xox70/xox70-progress-update-late-march-2023
Update - Feb2023
https://thocc.supply/blogs/xox70/blog-posts-xox70-progress-update-feb-2023
Update - Jan2023
https://thocc.supply/blogs/xox70/xox70-progress-update-happy-2023
Update - DEC 2022
Production started, going full speed
PCB Flex Limitor - final test, signing off and in the queue for production
Carry Case - will place order towards the end
EC PCB kit - Slider housing & Slider finalized, testing doms with various materials and design
XOX70 Badge collection - waiting to be kicked off
Special Edition - update available
Read more https://thocc.supply/blogs/xox70/xox70-progress-update-mid-dec-2022
Update - Nov 2022
Production begins next week - Delivery schedule remains unchanged (Q1 2023)
PCB Flex Limitor - Included with every GB order
EC PCB kit - prototyping
Read more at https://thocc.supply/blogs/xox70/xox70-progress-update
« Last Edit: Sun, 09 July 2023, 00:40:04 by well_cooper »
Re: [GB] XOX70 FRL TKL - Gasket mounted,longer, better looking 70%
« Reply #2 on: Fri, 26 August 2022, 09:15:49 »
Approved :thumb:
Offline TQuest
« Reply #3 on: Fri, 26 August 2022, 14:41:32 »
Looking forward to this GB!
Offline well_cooper
    • Thocc Supply
« Reply #4 on: Fri, 26 August 2022, 18:10:31 »
Amended GB date, it is from 31st Aug to 30th Sep
« Last Edit: Fri, 26 August 2022, 18:23:34 by well_cooper »
Offline marcowhatever
« Reply #5 on: Fri, 26 August 2022, 20:20:28 »
I noticed the post states a flex cut will be on the pcb, do you have a prototype of this on the hotswap and solder pcb?
Offline well_cooper
    • Thocc Supply
« Reply #6 on: Fri, 26 August 2022, 23:43:40 »
Yes, and all the case prototypes sent to content creators have included one of these
« Reply #7 on: Sat, 27 August 2022, 07:44:10 »
That's nice, but I think it would be helpful for myself and other people to have a quick reference of it on a gb thread.
« Reply #8 on: Sun, 28 August 2022, 11:11:08 »
Lets go!
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - GB now LIVE!
« Reply #9 on: Wed, 31 August 2022, 07:32:48 »
GB is now live on SwagKey, Shockport Keyboard, Keygem, Proto[Typist] and Thocc Supply
Mechs & Co, Uniqmeck, iLumKb to follow soon
Offline ABlazinBlueToe
« Reply #10 on: Thu, 01 September 2022, 05:22:11 »
Still not live on Mechs & Co and iLumKb
Offline francois.m
« Reply #11 on: Thu, 01 September 2022, 20:27:26 »
Just checked and it's live on iLumkb.
Offline well_cooper
    • Thocc Supply
« Reply #12 on: Sat, 03 September 2022, 23:56:09 »
GB are live on all vendors :thumb:
Offline Sieglinde
« Reply #13 on: Sun, 04 September 2022, 10:13:02 »
Great looking board. How can I get a matching bottom case for the e-white? Asking for a friend :D
Offline idealape
« Reply #14 on: Fri, 09 September 2022, 10:14:54 »
No pink offered. My wallet is safe
Sent from my J9210 using Tapatalk
Offline well_cooper
    • Thocc Supply
« Reply #15 on: Sat, 10 September 2022, 07:38:54 »
Think yellow is another form of E-White  :p
Offline well_cooper
    • Thocc Supply
« Reply #16 on: Sat, 10 September 2022, 07:39:30 »
For now yes, future hmmmm
Offline idealape
« Reply #17 on: Sat, 10 September 2022, 07:42:33 »
Lilac is the new pink du jour.... Dirty pink or rosegold, wonder if I'll ever get a nice board in that color
Offline idealape
« Reply #18 on: Sat, 10 September 2022, 07:46:01 »
Offline Kev95os
« Reply #19 on: Thu, 22 September 2022, 00:20:44 »
Hi do you ship to China?
Offline well_cooper
    • Thocc Supply
« Reply #20 on: Fri, 23 September 2022, 19:30:43 »
Offline Sieglinde
« Reply #21 on: Thu, 29 September 2022, 22:49:32 »
Purchased mine today. Now the waiting game begins  ^-^
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - GB Closed!
« Reply #22 on: Mon, 03 October 2022, 07:59:32 »
GB is closed, thank you for joining in :-*
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - Nov 2022 Update
« Reply #23 on: Fri, 11 November 2022, 19:56:43 »
Nov 2022 Update avil in first comment  :thumb:
Offline The0rigina1
  • fumoposting
« Reply #24 on: Sat, 12 November 2022, 04:59:56 »
Wait so you flex cut your PCB to the high heavens and then you come up with something called "PCB flex limiter"?
We live in a society  :-\
Offline well_cooper
    • Thocc Supply
« Reply #25 on: Sat, 26 November 2022, 02:36:46 »
different strokes for different folks
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - Dec 2022 Update
« Reply #26 on: Sun, 18 December 2022, 07:24:55 »
December update is now available on first comments and https://thocc.supply/blogs/xox70/xox70-progress-update-mid-dec-2022
Offline Literal
« Reply #27 on: Mon, 19 December 2022, 14:44:57 »
Hope there’ll be extras or another round on the cases; I would have bought in for the EC PCB.
Offline well_cooper
    • Thocc Supply
« Reply #28 on: Tue, 28 February 2023, 05:53:12 »
Feb update in the first comment
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - Feb 2023 Update
« Reply #29 on: Sun, 26 March 2023, 00:31:36 »
March Update in the first comment - TLDR we are very close to vendor fulfilment
Offline Sieglinde
Re: [GB] XOX70 FRL TKL - March 2023 Update
« Reply #30 on: Mon, 27 March 2023, 17:41:12 »
Thank you for the updates.
Will there be any extras? I ordered a e-white but maybe I should have gotten the Silver...
Offline well_cooper
    • Thocc Supply
« Reply #31 on: Mon, 24 April 2023, 23:33:30 »
Yes, there will be limited extras
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - Vendor shipping soon
« Reply #32 on: Mon, 24 April 2023, 23:33:57 »
April Update now avil in 1st comment
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - Vendor Fulfillment
« Reply #33 on: Fri, 05 May 2023, 05:30:46 »
Vendor fulfillment starting now
Offline ocular
« Reply #34 on: Mon, 15 May 2023, 03:55:44 »
Do you already know when the extras will be available?
Offline well_cooper
    • Thocc Supply
« Reply #35 on: Mon, 22 May 2023, 06:43:55 »
Our extra will be available after GB order fulfilment, expecting some time in late June if no shipment delays
Offline ImaSpacePotato
« Reply #36 on: Thu, 22 June 2023, 17:31:17 »
What's the status with Mechs and Co. Orders? Have they paid you? Have the boards been sent out? Apparently they've just ghosted MW on payment for some keycap sets, what about this board?
Offline Sieglinde
« Reply #37 on: Fri, 23 June 2023, 10:47:21 »
I checked the discord. The status for Mechs and Co. is "Pending Pickup"
Offline well_cooper
    • Thocc Supply
« Reply #38 on: Sat, 24 June 2023, 20:15:04 »
They have paid my invoice in full. I can confirm Mechs & Co's stock was picked up and on its way to them, logically I can't see them not fulfilling GB orders. If they have purchased any extras they can put them up for sale which generates more income, a win-win situation imo
Offline Sieglinde
« Reply #39 on: Sat, 24 June 2023, 20:39:04 »
Please update us when your extras are ready, I might have to pick up one up if Mechs and Co. doesn't do anything.
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - Extras coming soon!
« Reply #40 on: Tue, 04 July 2023, 05:09:13 »
Extras are scheduled for this weekend
Offline well_cooper
    • Thocc Supply
Re: [GB] XOX70 FRL TKL - Extras Available Now
« Reply #41 on: Sun, 09 July 2023, 00:38:22 »
Extras now available
Offline mgsickler
« Reply #42 on: Tue, 07 November 2023, 13:49:05 »
For the XOX70 keyboard through Mechs and Co, we were able to come up with a solution to those impacted.
These boards were actually stuck in port, and we were able to work with Mechs and Co to pay to get them out of port, clear customs, and ship to our warehouse.
As with the last batch of items, we do not have any order information, and will need every customer who ordered this board to submit proof of their order. Please use this google form link to upload your order confirmation, along with checking off what you ordered.
Please note that if you have successfully chargebacked on this item, you are NOT eligible for receive this board. This is only for people who did not chargeback.
After we receive everyone’s order information, we will compare that vs the inventory we have received. If it all matches up fine, we can set up the product pages and get the customers impacted links to set up their order again. We are only charging shipping costs for these customers.
Please submit your order information through the google form link no later than November 20th at 2pm Eastern. There will be no exceptions or extensions on this timeline.
Google Form Link - https://forms.gle/5wUfzcTLqJV4ffePA
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #43 on: Tue, 07 November 2023, 14:02:34 »
My man Mike, coming clutch for this whole Mechs & Co. mess. Huge respect!
Offline rmendis
  • Artisan addict
« Reply #44 on: Wed, 06 December 2023, 15:13:13 »
GOAT
Offline Bozs
« Reply #45 on: Thu, 21 December 2023, 17:20:42 »
F*^%*%K, i gave up looking for new info on this last month because it was causing me anxiety, and there was no new info. Then i see extras on Novelkeys and come to check.... i had 2 boards. This is sad.
Good on you though.
