Author Topic: [IC] XOX70 FRL TKL - Gasket mounted,longer, better looking 70%  (Read 71630 times)
Offline well_cooper
  • Turn metal in to typing machine
    • Thocc Supply
XOX70
Introduction
Hello Geekhack friends, after a year in development please allow me to introduce XOX70 an FRL TKL or in my own words the better-looking 70%
XOX or Hugs and Kisses is a personal project I started designing back in May 2021, during the strictest lockdown in Melbourne Australia where I rarely get the chance to meet my friends and family and the easiest way to communicate is via typing. After using many keyboards and running a few proxy group buys I’ve set out to design a board that meets my own expectations.
IC Form - Click HERE
Join Discord - Click HERE
Spec Summary
  • 8-degree typing angle with 2 internal brass weights (E-Clear coat treated)
  • Screwless exterior design (adjusted for switch  & plate clearance and ease of assembly)
  • Gasket Leaf Spring (full plate  & half-plate, multiple materials)[/*]
  • Solder and Hot-Swap PCB with flex cut (VIA ready) 1.6mm thick
  • Carry case included
  • Pricing ~ 380 USD for a standard kit
Standard Kit Planned Contents
  • Top & Bottom case with Badge, LED diffuser & weights pre-installed
  • Solder PCB + Daughter board + JST cable
  • Full Aluminium Plate
  • JST cable cover
  • Gasket poron foams (with extra)
  • Rubber Feet
  • Assembly Screws + Torx driver
  • Badge light-blocking foam
  • 3u stabilizer wire x 2
  • Anti Static sheet, Poron case & plate foam
  • Carry Case
Extras
  • Full & Half plates in FR4, PC, Aluminium
  • Solder & Hot-swap PCB with Daughterboard and cable
  • 3u stabilizer wire pack (2 wires per pack)
Vendor
USA - Mechs & Co.
Canada - Shockport Keyboards
SEA - ilumkb
Europe - KeyGem
UK - Proto[Typist]
Vietnam - Uniqmeck
South Korea - Swagkeys
OCE - Thocc Supply
Content Creator - Schedule
Colour
Link
Date & Time
SwitchDoctor
Lilac WK
https://www.youtube.com/watch?v=qDYfLzedoeM&t=20s
10th July @ 11 AM AEST
MrB0dyMassage
Black WK
https://www.youtube.com/watch?v=gdq6Cq7Nf7U
15th July @ 7 PM AEDT
warmthoughts
Moss WKL
https://www.twitch.tv/warmthoughts
TBC
NEARLUCID
Plum WKL
https://www.youtube.com/c/nearLucid
https://www.youtube.com/watch?v=yJENNgbqELc&t=1s
LightningKeyboard
Black WKL
https://www.youtube.com/watch?v=9tV46zET-io
Aug 4th @ 8PM EST
Alexotos
E-White WKL
https://www.youtube.com/watch?v=WHYyeLJH-1I
July 31st @ 1PM EDT
DBOKEY
Lilac WKL
https://www.youtube.com/c/%EB%93%9C%EB%B3%B4%ED%82%A4DBOKEY
In Progress
:3ildcat
Silver WK
https://www.youtube.com/c/3ildcat
In Progress
IC case colour - will trim down to 4 after IC results
From top left to bottom right
  • Black & Silver
  • Silver & Blue
  • Moss & Black
  • Plum & Black
  • Lilac & Silver
  • E-White & E-Yellow
  • Dirty Pink & Black
PCB Layout
Daughterboard - Aio3 Unified Daughterboard footprint with JST connector
The main PCB Solder version supports multi layouts, Hot-Swap is fixed ANSI with 7u spacebar
Exploded
Render Gallery - Full Render Album click HERE
Final Prototype Photo - Full Album click HERE
XOX v1 & v2 Renders by YorkChan - Full Render Album click HERE
XOX previous Prototypes - Full Album Click HERE
Typing test
In COVID isolation and soz for some stab ticks, this is my daily test driver and I've yet to redo all the stabs
SwitchDoctor's FR4 half plate typing test
Banner
Code: [Select]
[url=https://geekhack.org/index.php?topic=117730][img width=210 height=120]https://i.imgur.com/ffu8hrP.jpg][/img]
Special Thanks
My Family and Friends who aren't in the keeb world but are still hyped about what I'm doing
Eureka Foundry - For providing valuable feedback and shipped out these amazing final prototypes
JPermz - Co-Founder of Peac Design, legendary mate, excited about this project since day 1. You can't get PLX anymore but can get some sick merch @ https://peac.design/
Jess - Thank you for the kick-in-the-butt confidence boost, not just once
Content creators - Thank you for taking your time to preview and sharing your experience with everyone
XOX70 FAQ
Q: WKL, ISO Support, Half plate please?
A: Plz just scroll up, all of them are listed in the description, specs, renders and IRL photos
Q: Do I have to use included foam?
A: No. Including foam cause…we all have personal PREFERENCE and making logistic easier for the vendors
Q: Could you please allow plate choice and PCB choice for the standard kit?
A: PCB yes, plate no. This is to reduce possible shipping and packing errors and make logistics slightly simpler. For the number pros, there are 144 different combinations if we allow mix match all the available options, not including any extras
Q: Will the plate and PCB design file be released to the public?
A: Plate file yes, PCB design file no. I do plan to have a rolling release for in-stock PCBs depending on the demand, regional vendors will have access to those if they want to stock them on a regular basis
Q: Can I have super slick/cute none typing-related features such as screen, knob, touchpad, fingerprint scanner, incense holder etc etc?
A: Maybe in the future, right now XOX70 is a good keyboard and needs to do keyboard things
Q: Why the badge?
A: Design to look like a computer screen, it shows the abundant relationship between input and display device, it also adds a small bit of flare so it doesn’t look like your office 3000
Q: HHKB layout perhaps?
A: BIG maybe, could be interesting but not for this run. If you are a PCB designer and have experience in designing PCB for electrostatic capacitive switches, please, get in touch  :-*
« Last Edit: Fri, 26 August 2022, 18:26:57 by well_cooper »
Offline well_cooper
    • Thocc Supply
Re: XOX70 FRL TKL - Gasket mounted,longer, better looking 70%
« Reply #1 on: Sat, 09 July 2022, 07:28:54 »
Reserved
The blue bottom case colour in the prototype is lighter than the renders, will do another anode sample before the full production run
Based on IC result, 6 out of 7 colours will be offered in GB, sorry Pink lovers
« Last Edit: Sun, 07 August 2022, 07:51:29 by well_cooper »
Offline Nonnegaard
« Reply #2 on: Sat, 09 July 2022, 07:39:25 »
Reserved
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline well_cooper
    • Thocc Supply
« Reply #3 on: Sat, 09 July 2022, 08:06:36 »
Offline Mecxs
« Reply #4 on: Sat, 09 July 2022, 09:01:50 »
That's a pretty impressive commitment to the prototyping.
Definitely keen to pick one of these up if you can stick close to that target price.
Offline ee
  • hi
« Reply #5 on: Sat, 09 July 2022, 09:42:03 »
reserved
Offline linell
« Reply #6 on: Sat, 09 July 2022, 11:59:51 »
I bet the db cover makes it thock harder
nice design  :thumb:
bro this a **** set, just be thankful you even getting 1 base running fr
Offline well_cooper
    • Thocc Supply
« Reply #7 on: Sat, 09 July 2022, 21:11:35 »
nice design  :thumb:
Thank you, the design felt complete with that cover added in
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #8 on: Sun, 10 July 2022, 04:24:38 »
"UK & Europe - TBD"
If you haven't rated it yet, please consider using a specific vendor for EU and a different one for UK.
Great design!!!
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline well_cooper
    • Thocc Supply
« Reply #9 on: Sun, 10 July 2022, 04:42:11 »
"UK & Europe - TBD"
Great design!!!
Yes they will be separate vendors
Offline Keeblet_257
« Reply #10 on: Sun, 10 July 2022, 08:48:55 »
"UK & Europe - TBD"
Great design!!!
good news.
I have a question, what material is the case made of? Might be me but I cant see the material of both top and bottom beeing named. If I had to make a guess Id say that both top and bottom are 6061 aluminium? Since there is a standard kit it would mean that there will be a more premium option right?
just a few question that came up when I read the IC.
oh and thats a lot of protos you guys made  :eek:
Offline Mecxs
« Reply #11 on: Sun, 10 July 2022, 20:17:59 »
6063 according to Discord. Might have changed for most recent round of protos though, not sure?
Offline Rory
« Reply #12 on: Mon, 11 July 2022, 05:45:21 »
this is it - absolutely love the silver but you can put me down for plum wkl
pls and thanks
Offline well_cooper
    • Thocc Supply
« Reply #13 on: Mon, 11 July 2022, 06:34:00 »
Very much the same, I did change supplier after the second prototype was not satisfactory
"UK & Europe - TBD"
Great design!!!
good news.
I have a question, what material is the case made of? Might be me but I cant see the material of both top and bottom being named. If I had to make a guess Id say that both top and bottom are 6061 aluminium? Since there is a standard kit it would mean that there will be a more premium option right?
6063 series aluminium, there was a tease I shared with a small group of Discord members regarding a possible FE edition however it is been put on hold (not cancelled) due to machining difficulty and very very low yield
Offline saab
« Reply #14 on: Mon, 11 July 2022, 06:35:06 »
Great To see, more FRLs. The prototypes are looking great! GLWIC
Offline TQuest
« Reply #15 on: Fri, 15 July 2022, 15:25:37 »
I completed your IC form, but marked "Forest" for color selection because I thought it was Moss. I now realize my error. I would have marked "Black" instead.
I'm rather boring, so I hope you offer either Black or E-White as one of your 4 colors in the GB.
Offline turangaleela
  • らんだむぶれいん!わおっ 叫んじゃえ わおっ
« Reply #16 on: Fri, 15 July 2022, 19:40:31 »
Filled out the IC form! The finish on the e-white looks incredible, thanks for all the prototype photos. In another life would have loved to see a soya/beige one...
Offline well_cooper
    • Thocc Supply
« Reply #17 on: Sun, 17 July 2022, 03:14:16 »
Noted, it's on my plan :thumb:
Offline well_cooper
    • Thocc Supply
« Reply #18 on: Sun, 17 July 2022, 03:15:56 »
pls and thanks
No and you are welcome (silver is lit)
Offline well_cooper
    • Thocc Supply
« Reply #19 on: Sun, 17 July 2022, 06:02:49 »
Typing test added, I'm in COVID isolation mean there some extra free time on hand to do a short video
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #20 on: Sun, 17 July 2022, 16:39:40 »
I have a weakness for FRL TKL 70s, and I love the colors that you're offering! GLWIC, though I don't think you'll need much!
Current Boards: Aaru TKL Old Dark Sand, Drop + Planck Purple, Mr Suit WKL Black w/Gold Chamfers, Sangeo60 Black, KBD67Lite White, D45 E-Grey, Wind X Pink, NCR 80 Beige, QK65 Dark Green, Gentleman65 Black, Av4 Claymore, TGR x Monokei Tomo Suave Blue, Heracles80 Holy White, Snake60 Rust, Array E-White, Capsule E-White, QK75 E-White, Zoom75 Milky Green, QK80 Black, Envoy 65 PC, Mode Sonnet Ice Blue, Cycle 7 Lavender, E-White; Neo70 Retro White, Black; Reflection Chocolate, Neo80 Champagne, Matra Alice 90 Glossy Red;
Offline well_cooper
    • Thocc Supply
« Reply #21 on: Sun, 17 July 2022, 19:02:53 »
UwU thank you hopefully I have tickled your weak spot
Offline Homiezoned
« Reply #22 on: Sun, 17 July 2022, 22:45:32 »
The colors :nut:
Offline Ra66it_AU
    • Najakeys
« Reply #23 on: Mon, 18 July 2022, 19:01:42 »
Looks really great, GLWIC!
Less is more?
Offline zuiKatsu
  • ****in weeb
    • Twitch channel
« Reply #24 on: Thu, 21 July 2022, 03:31:31 »
Looking good man! great colours on the protos and i really like the thought put into the internals, outside is classy too
Offline well_cooper
    • Thocc Supply
« Reply #25 on: Wed, 27 July 2022, 05:52:41 »
The colors :nut:
Thank you very much, fill out the short IC and vote for your favourite colours!
Offline well_cooper
    • Thocc Supply
« Reply #26 on: Wed, 27 July 2022, 05:53:38 »
alexotos stream time added  :-* scroll up and save the date
warmthoughts will be streaming Moss WKL build, time and date will be updated once confirmed
« Last Edit: Wed, 27 July 2022, 05:58:14 by well_cooper »
Offline mr_foggy
  • neue = nope
« Reply #27 on: Fri, 29 July 2022, 11:08:34 »
in a time of crazy inflated prices this is really surprising. nice design, nice colors, nice price. will most likely consider it.
Offline well_cooper
    • Thocc Supply
« Reply #28 on: Wed, 03 August 2022, 22:39:47 »
Thank you, Thank you and Thank you Ɛ>
Offline well_cooper
    • Thocc Supply
« Reply #29 on: Wed, 03 August 2022, 22:42:30 »
LightningKeyboard will stream Black WKL build on Aug 4th @ 8PM EST
Offline well_cooper
    • Thocc Supply
« Reply #30 on: Sun, 07 August 2022, 08:59:38 »
Added FAQ at the end of IC post (based on current IC results)
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #31 on: Sun, 07 August 2022, 13:14:42 »
"UK & Europe - TBD"
Great design!!!
I'm sorry but I still see Proto[Typist] as the only vendor for UK and Europe.
As Depeche Mode would say: "It's No Good".
Offline pixelpusher
« Reply #32 on: Sun, 07 August 2022, 15:47:52 »
Excellent color choices.  Classy style.  I like it.  :thumb:
Offline well_cooper
    • Thocc Supply
« Reply #33 on: Sun, 07 August 2022, 18:27:24 »
"UK & Europe - TBD"
Great design!!!
I've reached out to serval EU vendors and waiting on reply = it's is not final yet
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #34 on: Mon, 08 August 2022, 06:59:37 »
Thanks for the update :)
If it has not been taken into consideration yet, I would like to suggest KEYGEM: I have no business relationship with them but they have always been attentive and kind.
Offline Psyrkle
Re: [IC] XOX70 FRL TKL - Gasket mounted,longer, better looking 70%
« Reply #35 on: Thu, 11 August 2022, 00:16:31 »
if you made a version with the arrows on the left side I will literally give you all of my money
Offline well_cooper
    • Thocc Supply
« Reply #36 on: Mon, 15 August 2022, 01:02:39 »
Very proud to have SwagKeys as KR vendor and KeyGem as EU vendor <3
Offline well_cooper
    • Thocc Supply
« Reply #37 on: Mon, 15 August 2022, 01:03:45 »
Haven't thought about southpaw variant, if there is enough interest I can look into it in R2
Offline Nonnegaard
« Reply #38 on: Mon, 15 August 2022, 01:12:17 »
kc lookin ahh plate
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #39 on: Mon, 15 August 2022, 02:21:21 »
Great!!! Thank you :thumb:
Offline Bozs
« Reply #40 on: Sat, 20 August 2022, 13:09:56 »
is there still a discord for this board? the link seems to be broken here and on reddit.
Offline gunth
« Reply #41 on: Sat, 20 August 2022, 13:35:41 »
https://discord.gg/KPac9uBa
Offline well_cooper
    • Thocc Supply
« Reply #42 on: Sun, 21 August 2022, 02:29:17 »
Thank you <3
Broken link fixed
Offline well_cooper
    • Thocc Supply
« Reply #43 on: Fri, 26 August 2022, 08:34:04 »
GB Post waiting for approval
Offline well_cooper
    • Thocc Supply
