Author Topic: [IC] Cornelius R2 - Gasket mounted 40% column staggered keyboard  (Read 12423 times)
Offline foostan
Cornelius R2
Hello, everyone.
I'm foostan, let me introduce about the round 2 of "Cornelius".
The topic of round1 is here
INTEREST CHECK FORM
UPDATE
  • 08/27/2022, Create this post
  • 10/20/2022, Close IC, and Add the result
CONCEPT
  • Compact with a minimal number of keys required
  • Ergo-like layout to ease the burden of the body
  • Gasket mounted structure with a daughter board for focusing on the typing experience
  • Exclusive palm rest for comfortable use
What different between R2 and R1
  • Exclusive palm rest(Option)
  • The internal structure has been updated, including a larger gasket area
  • More color variations planned
DETAILS
  • Typing angle: 6.5deg
  • Mounting type: Gasket mount with a daughter board
  • Materials: Anodized(or E-White) Aluminum Body, Anodized Aluminum(or Polycarbonate) Plate, E-Black Brass Weight, PORON Gasket, and Foam
  • PCB: USB-C, hot-swappable or soldering PCB, configurable with QMK and VIA
COLORS
  • Body: Black, Dark Gray, E-white, and...
  • Plate: Black, Purple, Red, Blue, Polycarbonate, and...
Rendering
https://twitter.com/foostan/status/1538517200767975424?s=20&t=IKoLDBbJnNQS3lN_sqNavg
https://twitter.com/foostan/status/1538520585269088257?s=20&t=IKoLDBbJnNQS3lN_sqNavg
https://twitter.com/foostan/status/1538537706053332992?s=20&t=IKoLDBbJnNQS3lN_sqNavg
https://twitter.com/foostan/status/1538537862790287360?s=20&t=IKoLDBbJnNQS3lN_sqNavg
https://twitter.com/foostan/status/1538542673401118720?s=20&t=IKoLDBbJnNQS3lN_sqNavg
https://twitter.com/foostan/status/1538543550413275136?s=20&t=IKoLDBbJnNQS3lN_sqNavg
Photos (R1)
Compare Dark Gray with MacbookPro Space Gray (R1)
VENDORS
PRICING
TBD
RESULT of IC
Q: Which bodies would you choose? (Multiple Choice)
A:
  • E-White: 51.5%
  • Anodized Black: 42.1%
  • Anodized Dark Gray: 30.4%
Q: Which plates would you choose? (Multiple Choice)
A:
  • Polycarbonate: 47.4%
  • Anodized Aluminum Black: 40.4%
  • Brass:28.1%
  • FR4: 22.2%
  • Anodized Aluminum Gray: 20.5%
  • Anodized Aluminum Red: 18.7%
  • Anodized Aluminum Purple: 10.5%
  • Anodized Aluminum Pink: 9.9%
  • Anodized Aluminum Violet: 9.4%
  • Anodized Aluminum Blue: 8.2%
Q: Which PCBs would you choose? (Multiple Choice)
A:
  • Hotswap PCB: 87.7%
  • Soldering PCB: 23.4%
Q: Need a palm rest?
A:
  • Yes: 76.6%
  • No: 23.4%
Q: Which palm rests would you choose? (Multiple Choice)
A:
  • Walnut: 55%
  • Cherry: 46.2%
CONTACT
« Last Edit: Wed, 19 October 2022, 19:28:10 by foostan »
Offline DirtyGingy
Re: [IC] Cornelius R2 - Gasket mounted 40% column staggered keyboard
« Reply #1 on: Sat, 27 August 2022, 05:07:35 »
kind of a selfish ask, but any chance at alps support?
Offline Pontus
« Reply #2 on: Sat, 27 August 2022, 08:01:37 »
Awesome that it’s getting a R2, I was really regretting not buying into R1.  ;D
Offline MinaDarsh
« Reply #3 on: Sat, 27 August 2022, 08:06:20 »
Missed R1 as well, but loving the upgrades, very, very interested in joining!
Offline synthtastic
« Reply #4 on: Sat, 27 August 2022, 10:54:12 »
Very nice!
Expensive plastic makes me sigh.
Offline forbidden404
« Reply #5 on: Thu, 01 September 2022, 06:57:29 »
Missed R1, won't miss it this time
Offline synthtastic
« Reply #6 on: Fri, 09 September 2022, 02:44:53 »
Pretty sure I already submitted the IC form, but any chance of a red case? The red on the alu plate is really nice. Love how bright it is.
Offline foostan
« Reply #7 on: Sat, 10 September 2022, 18:49:11 »
Depending on the outcome of the IC, this may be difficult.
I'm sorry, the PCB is not compatible alps. It's difficult because the PCB and plate must be changed to accommodate alps.
Offline jojoy
    • Jojoy
« Reply #8 on: Thu, 15 September 2022, 04:55:40 »
Is the solenoid striking fr4 or the acrylic guard somehow? And would if be feasible to have it strike a different material? Like an eraser if you need to type on the DL, or a tiny wine glass for toasting purposes? :)
Offline IceCandle
« Reply #9 on: Sun, 05 March 2023, 00:07:00 »
« Last Edit: Sun, 23 November 2025, 14:39:44 by IceCandle »
