Author Topic: 【IC】CLAP ARTISAN WRIST REST  (Read 6014 times)
Offline CLAP_STUDIO
« on: Tue, 30 August 2022, 09:33:28 »
Hello Geekhackers, today I want to present you a artisan wrist rest.
Front height:20MM
Length:318MM (works with most 60-65%)
Width:80MM
Typing angle:6.5°
The wrist rest can hold 13 artisans with height no higher than 14MM
The specs:
6063 Aluminum
Ano: Silver and black
PC Cap to prevent dust
Walnut wood with wood wax coat
Magnets X8 to hold the wood onto the casing
Photos of the R2 Prototypes https://imgur.com/gallery/wTNrH5K
MOQ 100 sets
MSRP US 120USD+domestic shipping and tax
MSRP worldwide 100USD+international shipping and duty
Worldiwde vendor: https://keyspensory.store/
Non US customers will be shipped directly from China
Please fill in the google forms if you are interested! https://forms.gle/5h93n1VLSocybyqm8
Thank you!
Discord:discord.gg/C7rPhkAr3U
Instagram:https://www.instagram.com/clap__studio__/
Offline CLAP_STUDIO
Re: 【IC】CLAP ARTISAN WRIST REST
« Reply #1 on: Tue, 30 August 2022, 09:34:23 »
Reserved :)
Offline 360Ceeee
« Reply #2 on: Tue, 30 August 2022, 10:43:35 »
Looks good for me
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #3 on: Tue, 30 August 2022, 19:01:53 »
does this support topre artisans?
Offline CLAP_STUDIO
« Reply #4 on: Tue, 30 August 2022, 22:43:44 »
The dimension for the artisans are 22*22MM with height no over 14MM
Offline CLAP_STUDIO
« Reply #5 on: Tue, 30 August 2022, 22:44:06 »
Offline Nuap
« Reply #6 on: Tue, 30 August 2022, 23:10:53 »
Wow very nice artisan wristrest, when I get one I'll be sure to proudly let everyone know "I GOT THE CLAP".
Now for some real feedback: I can't see any easy way to remove the lid ("PC cap"). It seems like when it's in palce it'd be hard to remove without a suction cup or turning the wrist rest upside down (and therefore potentially scattering your priceless resin). Other lidded cases implement tabs in their lid that allow you to get some grip to lift them up, see the Naptime if you want an excellent example.
Offline iNKY Studio
  • long-term partner with Domikey
« Reply #7 on: Tue, 30 August 2022, 23:58:12 »
a bao wo di shen
Offline CLAP_STUDIO
« Reply #8 on: Wed, 31 August 2022, 00:14:47 »
Ooooops MY BAD! I forgot to mention the suction cup that will be provided in the set! Thanks for noticing!!
I have also been thinking about implementing a small cutout on both ends of the PC cap, which might be easier for users, in case the suction cup is lost!
Thanks for the good feedbacks!
Offline CLAP_STUDIO
« Reply #9 on: Wed, 31 August 2022, 00:52:58 »
Offline akejojo
« Reply #10 on: Wed, 31 August 2022, 08:44:24 »
a bao li hai bang bang bang
Offline Morbii
« Reply #11 on: Thu, 01 September 2022, 15:48:08 »
This looks great, and I'm definitely interested depending on when the GB comes up.
I'm with the others that mentioned a tab instead of a suction cup as being preferrable.
Offline CLAP_STUDIO
« Reply #12 on: Fri, 02 September 2022, 23:34:51 »
Thanks! And yes we'll be changing the design of the PC cap. For the GB date we're not sure just yet, we'll be sure to update!
Offline less_blank
« Reply #13 on: Sat, 03 September 2022, 18:32:56 »
Looks awesome, will definitely be in for one. Only nitpicks I have are I'd prefer a completely clear window rather than slightly frosted and would prefer no logo, but I'm in either way!
Offline CLAP_STUDIO
« Reply #14 on: Tue, 06 September 2022, 00:19:50 »
Thank you for liking and the feedbacks! Will definitely consider clear PC cap option!
