Author Topic: [GB] 40rmie LX (GB ended, cases ordered.)  (Read 35261 times)
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
« on: Tue, 30 August 2022, 19:34:54 »
40rmie LX
Group buy from September 1st to October 3rd, at 10am CST
Orders are set to ship 3-4 months once the GB ends
Vendor
p3dstore
Kuro's prototype, with nav top, mirror ss base, and brass grill
My updated prototype, with the final placement for the bottom text
Dede's prototype, with nav top, mirror ss base, and ss grill
Jake's prototype, with knob top, Alu base, and brass grill
40rmie KLE including Winkeyless option
"The 40rmie came about as my own love letter to a few of my favorite boards in the 40% scene (including the Equinox, V4N4G0N, and Field Trip). What I’ve always enjoyed about 40s was the wide variety of boards available, and from that I wanted to combine what I really enjoyed - a gasket pcb mount keyboard with a 13u ‘big mod’ main cluster, a half numrow, and arrow, fn, and nav cluster. This gives you a little bit of everything that you may want or need with easy functionality, but with a comfortable 40s main cluster.
The board had its initial group buy with an acrylic case designed and made by Jake at P3D in September 2021. While I had made the layout for my own preferences, I ended up being shocked by how popular the board ended up being during the original group buy. After the huge amount of love we got for this board, I wanted to approach my real dream of making my ideal 40% keyboard - a metal case."
-Kuro, designer of the 40rmie pcb and layout.
I was happy to be able to bring this dream to life, making the case compatible with the original pcb and mounting method, while completely redesigning the case from stacked acrylic to a 2 piece cnc'd design, with a cherry front lip, lightly chamfered edges, quadratic diffuser, seamless design, and the same 4 degree typing angle.
        Stay up to date on Discord and Instagram here!
Specs/Features
  • pcb gasket mount
  • 4° typing angle
  • Quadratic residue diffuser
  • 4 Top options, Nav or Knob, with or without Winkeys.
  • QMK and VIAL-compatible PCBs
  • Weight built: 4 lbs 2 oz
Kit contents
not including add ons
  • Aluminum top case, with choice of blockers
  • Aluminum bottom case
  • 6x custom p3d gaskets
  • 4x custom p3d feet
  • 4x m1.6 3mm hex screws (grill badge)
  • 8x m3 8mm hex screws (case)
Pricing & Addons
Black Anodized Aluminum: $225 USD
Discounted Cerakote options listed below.
Optional Add-Ons:
    40rmie PCB- $40 when added on using the 40rmie LX order page and ordering with the case.
    Low profile detent-less encoder is available-$4
        15mm encoders are ideal for this case. The product pictures with the artisan knob is a 20mm encoder and sticks up much more than the product pictures showing the custom Cerakote prototype and knob.
    38mm knobs are available:
        Black anodized knob- $25
            Single Color Cerakote Available- $15
            Multicolor Cerakote Available- $30+
        Milled Resin Knobs: $30 (Additional Colorway Pictures Here)
            Abalone Colorway
            Blush Colorway
            Pastel Dreams Colorway
            Peacock Colorway
            Starry Night Colorway
            Solid White Colorway
    ABS, POM, PP, PC, PETG, and IMA plates available.
    3/16" (4.75mm) Thick Glossy Black or White ABS plate is also available.
        This plate is not compatible with plate foam.
    Plate EVA foam- $10
    Case EVA foam- $10
    In addition to the included acrylic milky white diffuser, there are multiple accent inserts available:
        1.6mm Brass (Raw or Raw Bead Blasted)-$10
        1.6mm Copper (Raw or Raw Bead Blasted)-$10
        1.6mm Stainless Steel (Raw or Raw Bead Blasted)-$10
        Multipack of 1.6m IMA in all our colors listed below (Gallery)- $20
            Colors include- Black, White, Graphite, Gold, Copper, Green, Purple, Red, Pink, Yellow, Blue, and Light Blue.
    Additional Case Top in selected layout- $65
        The color will match your original color selection by default. Contact us after your order if you would like a different color.
Colors/Finishes
Thanks to
Kuro, Jake, and Factory, for getting me involved in this project.
Code: [Select]
[url=https://geekhack.org/index.php?topic=118237][img width=480 height=120]https://i.imgur.com/5AUF63I.jpg[/img][/url]
« Last Edit: Wed, 05 October 2022, 23:24:37 by Heist Morty »
Re: [GB] 40rmie LX (sept 1 - oct 3)
« Reply #1 on: Thu, 01 September 2022, 17:22:40 »
Approved :thumb:
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
« Reply #2 on: Thu, 01 September 2022, 18:36:17 »
 Thanks Hoffman! reserved.
« Reply #3 on: Thu, 01 September 2022, 18:47:48 »
if anyone ever asks you what's the best keyboard for gaming show them this
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #4 on: Thu, 01 September 2022, 20:54:28 »
i love this keyboard more than i love puddsy
Offline KuroTheCrazy
« Reply #5 on: Fri, 02 September 2022, 07:03:24 »
It's not a stupid layout guys I promise please believe me. It has an escape key but it just goes to a different school.
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
« Reply #6 on: Fri, 30 September 2022, 12:44:14 »
GB ends monday. thanks for all the support so far folks. hope yall enjoy the case! get your orders in while you can.
« Reply #7 on: Mon, 03 October 2022, 07:32:38 »
Today's the last day! MOQ has been met, please be sure to join the GB today if you don't want to miss out.
Offline Heist Morty
  • MD.Doof
    • Mascis Designs
« Reply #8 on: Wed, 05 October 2022, 23:23:59 »
and GB is over. Thanks to everyone who Joined, we hope to deliver the cases swiftly!
P3d Notion board with group buy updates.
« Last Edit: Mon, 12 December 2022, 18:14:49 by Heist Morty »
Re: [GB] 40rmie LX (GB ended, cases ordered.)
« Reply #9 on: Thu, 29 December 2022, 17:09:51 »
Update in P3D on discord:
Exciting news. I got some of the cases unpacked and built up a Standard + Knob and WKL + Nav to do a final fit check. These turned out absolutely fantastic.
We will start shipping the black ano ones soon. Stay tuned for the order address email coming early next week.
In the meantime we will get hardware bagged up, finish cutting gaskets, finish qc, and then go ahead and get going on Cerakote. We are going to ship black ano cases first though.
