Author Topic: [IC]Domikey Salt Lake - Designed by 句Studio | Upd Nov 24,2022(more photos)  (Read 7643 times)
Offline 。
Hi geekhack,I'm 句.
Thank you all for your support of ‘Domikey In Former Days’.
Today I have a new project——Domikey Salt Lake.
Inspired by the Salt Lake, the translucent ABS material is used to reproduce the crystal water of the salt lake on the keyboard, embellished with pale yellow sand and white salt crystals, I hope you can like it.
Set options
Base kit
Base kit has 150 keys, using icon key. R1, R2, and R4 each have two 1U novelties , R3 has one carriage return novelty, R4 has two 1.25U novelties and two 1.5U novelties.(The translucent part is not yet the final version)
Supported:
·MX HHKB, 60%, 65% (one 1.75u Shift), 660 (an extra 2.25u Shift)
·75%
·80%
·Supported WKL
·2u Shift
·UK ISO
Numpad kit
·22 keys.
·Compatible 960/980/100% with Base kit
Spacebars kit
Including:
·The extra B key
·1.75U、2U、2.25U、2.75U、3U(One for each)spacebar
IC Form
Discord
Thank you.
Upd Nov 24,2022
Hi guys ,I have finished the proofing work and commissioned highland studio to take a group of photos for me!
« Last Edit: Thu, 24 November 2022, 02:16:55 by 。 »
Offline treeleaf64
    • treeleaf64
Re: [IC]Domikey Salt Lake
« Reply #1 on: Sat, 03 September 2022, 12:59:18 »
translucent beige when
Everyone must pay the cat tax
Offline pixelpusher
« Reply #2 on: Sat, 03 September 2022, 14:16:54 »
Neat.  I like it.  Also would like all translucent version too :)
Offline DirtyGingy
« Reply #3 on: Sat, 03 September 2022, 16:48:55 »
are you having the clear caps pad printed? because if they are double shot, they will look nothing like the render
Offline Nonnegaard
« Reply #4 on: Tue, 06 September 2022, 01:29:55 »
translucent glow-in-the-dark handarbeige n e avail?
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Wintea
« Reply #5 on: Tue, 06 September 2022, 20:35:06 »
I like this a lot! GL with IC!!
Offline Rotuh
« Reply #6 on: Sat, 10 September 2022, 12:48:20 »
What a fantastic concept! Although kinda weird that the spacebar kit doesn't include a yellow 6.25u spacebar, as it isn't present in the base kit.
Offline 。
« Reply #7 on: Thu, 24 November 2022, 02:27:07 »
Full transparency is not considered for this topic,I wanted to express the texture of the lake with translucency~ :D
