Author Topic: Cherry G80-3000LQC  (Read 2739 times)
Offline london
Cherry G80-3000LQC
« on: Mon, 27 September 2010, 06:37:33 »
Hi
Any ideas where I could purchase a Cherry G80-3000LQC English layout, either from the States or Europe.
Thanks
Offline Senor_Cartmenez
Cherry G80-3000LQC
« Reply #1 on: Mon, 27 September 2010, 07:50:42 »
Go to cherry.com and look up their international distributors.
Ther's like a gazillion shops carrying cherry keyboards
Offline zmurf
    • Cherry G803000LQC With Latest Generation Trackpoint
Cherry G80-3000LQC
« Reply #2 on: Mon, 27 September 2010, 08:03:00 »
You can get one with ISO standard layout (the one UK keyboards are based on) from germany...
http://www.jacob-computer.de/Eingabeger%E4te_Tastaturen_Cherry_Classic_Line_G80-3000_-_Tastatur_-_PS-2%2C_USB_-_105_Tasten_-_Schwarz_-_Deutsch_%28G80-3000LQCDE-2%29_artnr_270414.html
You will not have the UK keycaps.. but at least the layout will be correct. You can always put stickers or paint key correct caps on the keys if you have to be able to see which key that is what.
As I have understood it, it is almoust impossible to get a LQC from the states. And if you would be able to get one it would probably be ANSI standard layout (US keyboard) and not the ISO layout that UK keyboards are based on.
You can see the German keycaps at my picasa gallery:
http://picasaweb.google.com/k.peter.mattsson/CherryG803000LQCWithLatestGenerationTrackpoint#
And watch out for the once called LQCEU... even tough it says EU this is an ANSI standard US keyboard... And NOT an ISO EU keyboard.
« Last Edit: Mon, 27 September 2010, 08:10:31 by zmurf »
At last! A mechanical keyboard with Trackpoint of my own! Now with Hyper-Scroll! And also Ergo-Clear switches. Ohh... look... custom keys! :D
Cherry G80-3000LQC
« Reply #3 on: Mon, 27 September 2010, 08:19:27 »
Hm, ok my bad
The ones I can find anywhere are either LQCDE or LQCEU
I didn't know there is another one with UK layout, also didn't know LQCEU is US layout (sense?), always assumed that's the UK one.
Offline itlnstln
Cherry G80-3000LQC
« Reply #4 on: Mon, 27 September 2010, 08:27:44 »
UK is "UK."  EU is the ANSI layout with the Euro sign on the 5 key.
Cherry G80-3000LQC
« Reply #5 on: Mon, 27 September 2010, 10:07:26 »
Same as we scramble to buy Decks, Filcos, Das Keyboards... All made with cherry switches, go figure. The most ironic is actually Das Keyboards, as it means THE Keyboard. German name, not really available in Germany. Go figure :)
Globalization is just a myth when it comes to the really cool stuff...
Crap on the other hand is available everywhere
