Author Topic: [GB] DD-40 | WKL and HHKB XT 40%  (Read 38998 times)
Offline dededecline
    • Linktree
« on: Mon, 12 September 2022, 09:47:48 »
DD-40
Links:
DD-40 Product Page
DD-40 Collection Page
Stay up to date with me
About:
The DD-40 is a 12.75u wide gasket mounted 40% keyboard with an RGB LED strip sandwiched between the macro-column and main alpha cluster. Both WKL and HHKB top cases will be available, and the seamed design allows for a two-tone case via available extra tops.
This board is my ideal for a staggered 40% keyboard layout. The 12.75u main cluster gives me the right amount of punctuation and keys to do everything I want without an abundance of layers, while also reducing hand travel as I type. I wanted to include a macro column both for additional flair and as a display piece for artisan keycaps. I thought the LED strip would also serve as a nice visual piece and an homage to one of the board's primary inspirations, the TMO50.
The case design involves some of my favorite design elements in modern keyboards - sharp edges and a two-tone aesthetic. I think the ability to mix and match colors unlocks a lot of potential for theming and photography and is visually appealing, but also optional for those who want a more minimal color palette.
The 6-point gasket system was chosen to give some slight muting that would not necessarily come from a top-mount. Additionally, the position of the mounting points were meticulously chosen in order to give the keyboard an exceptional level of consistency in both sound and feel.
Group buy details:
  • Price: $265 for anodized colors, $280 for e-white
  • Format: FCFS (unlimited)
  • Date: Monday September 12th - Monday October 3rd
  • Colourway options: e-white, black, crimson, navy
  • Layout options: HHKB and WKL, each has big bar and mini bar layouts
  • Estimated shipping timeline: Q1 2023
Board info:
  • 4° typing angle
  • Gasket tab plate
  • 19.5mm front height
  • QMK and VIAL-compatible DB PCBs
  • Accentuated seam
  • Optional RGB diffusion strip
  • Weighs roughly 2 lbs 1 oz built
Kit Includes:
  • Case top and bottom
  • Black aluminum anodized plate
  • Solder PCB
  • DB/JST
  • Gaskets
  • Feet
  • Torx Screws
  • Frosted acrylic LED diffusion window
  • Polyfill
Extras:
  • Additional aluminum plate: $30
  • FR4 plate: $20
  • POM plate: $25
  • CF plate: $35
  • Solder PCB: $45
  • Additional feet: $6
  • Additional JST/DB: $5
  • Additional gaskets: $5
  • Additional tops: $75 anodized/$85 e-white
Additional Color Renders:
Additional Photos:
Typing tests:
Xinxinwong - Lavenders with aluminum plate | https://clips.twitch.tv/GleamingFilthyBubbleteaMVGame-kGs1uTSBlXCzk8sm (full build stream here)
Layout Support:
Two tops will be available, an HHKB top and a WKL top. Each has its own plate to avoid swiss cheese. Each layout has full space and split space layouts available
Special Thanks:
  • Dingusxmcgee For all the help on this
  • OCM Logo, 3DP protos, and moral support
  • Liv PCB design and renders
  • James, Upas, Ana, Chippy, M1w, and the CannonKeys Crew For helping this become a real board
  • Xinxinwong and Lightning For doing build streams
  • Taylor and many others For support and feedback throughout this process
Re: [GB] DD-40 | WKL and HHKB XT 40%
« Reply #1 on: Mon, 12 September 2022, 11:58:25 »
Approved :thumb:
Offline dededecline
    • Linktree
« Reply #2 on: Mon, 12 September 2022, 12:03:30 »
Reserved
Offline Blind_Panda
« Reply #3 on: Tue, 13 September 2022, 18:51:26 »
Hi does this thock
Offline dededecline
    • Linktree
« Reply #4 on: Tue, 13 September 2022, 18:55:23 »
Hi does this thock
Thock, clack, schlick, and plop are all supported sound profiles
Offline WinKeys
    • Win Keys Link Tree
« Reply #5 on: Tue, 13 September 2022, 18:55:40 »
As an avid 40's and Artisan enjoyer this board checks all the boxes for me! The biggest down side of using 40's is the vast majority of them you can only really use one artisan on the esc key but with the breakout macro column on this board you truly get the best of both worlds!
BUY DD-40!
Offline white_rabbit
« Reply #6 on: Tue, 13 September 2022, 19:03:39 »
Great job! Been following this project for a while. ;D
Love the seam design, and the bottom row layout options are exactly what I expect to see from someone who actually uses 40s.
Not to mention the price point on this makes it hard to pass up.
Offline HungHingDaiLo
  • 無間道
« Reply #7 on: Wed, 14 September 2022, 19:37:47 »
Great work, dede!
GLWGB!!
IG: @rayhhdailo
Offline dingusxmcgee
« Reply #8 on: Thu, 15 September 2022, 09:32:03 »
Stoked to see this come to life and even more stoked to see it on CannonKeys! GLWGB!
Offline dededecline
    • Linktree
« Reply #9 on: Wed, 29 March 2023, 08:17:23 »
Update: boards are on the boat to CannonKeys! Expect fulfillment in 1-2 months.
Offline dededecline
    • Linktree
« Reply #10 on: Sat, 14 October 2023, 13:27:32 »
I have created an open source repo for dd-40's PCB and plate files. This should enable anyone to order new ones as needed.
I will likely have more open source repos in the near future! You can browse all of mine here.
Offline nacly
« Reply #11 on: Mon, 16 October 2023, 12:36:12 »
Hey man, you think you could upload the pcb project files as well to the repo?
