Author Topic: [GB] DN60 - Seamless 60% O-ring Gasket Mount Board [Sept. 13th - Sept. 27th]  (Read 4185 times)
Offline hlord2000
The DN60
GB Order Link | Discord
291301-0
291311-1
291313-2
Internals
291317-3
291319-4
Available Colors
291303-5
Burgundy
291305-6
Silver
Lilac
291309-8
Black (render)
"dn60 is a seamless o-ring gasket mount 60%. My motivation behind the project was to create a two piece o-ring gasket board with mounting similar to the otd 356 mini, as most of the available o-ring 60% boards follow the unikorn drop in mounting style." - CMG
Sound Test
WKL model available!
Top and Bottom can be different colors with no extra charge!
Quality Disclaimer: A Stock boards may have interior defects, and very very minute exterior flaws. Quality concerns upon shipment will be assessed and determined if eligible for replacement.
Expected delivery: Q1 2023
Board Specs: - Front Height: 17.3mm - Typing Angle: 6.88 deg - Unbuilt Weight: 2.45lb or 1118g
Kit Includes:
  • 1x Top Case (Alu 6063)
  • 1x Bottom Case (Alu 6063)
  • 1x Brass Weight
  • 1x Plate (PC Full or Alu Full)
  • 1x Pcb (Rex60)
  • 1x 70A O-ring
  • 1x Unified DB
  • 1x JST cable
  • 4x 3M bumpons
  • All Mounting Hardware
Plate Compatibility:
  • ANSI/Tsangan/WKL bottom row
  • Full or Split R shift
  • Full or Split BS
  • Stepped or Non-stepped caps
Optional extras:
  • PCB ($32)
  • Plate ($40)
Price: $375 + shipping
Order Here
« Last Edit: Wed, 21 September 2022, 13:49:32 by hlord2000 »
Offline hlord2000
Re: [GB] DN60 - Seamless 60% O-ring Gasket Mount Board [Sept. 13th - Sept. 27th]
« Reply #1 on: Tue, 13 September 2022, 20:38:59 »
Reserved
Offline suyashr99
« Reply #2 on: Wed, 21 September 2022, 16:55:01 »
Glad to see this finally run. :thumb:
Offline powotato
« Reply #3 on: Wed, 21 September 2022, 17:09:56 »
Always good to see new designers in this space. Looking good, ill be picking one up! ;D
