Author Topic: [GB] SR2 and S23 by Sho, Aluminum Case for Realforce R2 TKL and 23U  (Read 4455 times)
Offline hong@RebultKeyboards
  • Rebult Keyboards
    • Rebult Keyboards
« on: Thu, 15 September 2022, 21:03:11 »
With the S60 completing production with fulfillment commencing shortly, and the HR2 well in production, Sho is ready to run the next two projects, the SR2 and S23, an aluminum case for the Realforce R2 TKL and aluminum/PC case for the Realforce 23U respectively.
291382-0291384-1
GB Start Date: September 15 2022
GB End Date: October 15 2022
Estimated Fulfillment Date: Roughly 3 Months after GB ends, conservative estimate Q1 2023
Here is all you need to know about the SR2:
Designed for the Realforce R2 TKL Keyboards. It is only compatible with the ANSI layout, as the aluminium plate is not designed to support the ISO layout. It is also not compatible with the RGB versions.
The SR2 sports a simple and boxy design, offering a low-key look while still feeling premium, being machined in 6063 Aluminum. Complete with a USB-C Daughterboard, the SR2 still manages to bring a relatively slim bezel, in line with the typical TKL aesthetic.
There are 4 colors available, Anodized Silver, Anodized Grey, Anodized Pink and Anodized Green.
SR2 Product Page
Price: RM1500 / US$354 / SGD490.50
291386-2291395-3291388-4 [ Specified attachment is not available ]
Here is all you need to know about the S23:
Designed for the Realforce 23U Numpad. Made out of 6063 Aluminium or Polycarbonate, the S23 allows you to turn your Realforce 23U into a more premium-feeling numpad, while preserving the Topre feel and sound that we love.
The S23 also comes with a USB-C Daughterboard, which allows you to use any USB-C cable with it, instead of having an attached cable. The custom aluminum plate also has 3x 2U compatibility.
For Anodized Aluminium, there are 4 colours available, Anodized Silver, Anodized Black, Anodized Green and Anodized Navy.
S23 Product Page
Price: RM719 / ~US$170 / SGD235.11
291397-6291399-7291399-8291401-9291403-10
Note: Both products are CASE and PLATE ONLY, you will need to supply your own PCB, Springs, Domes, Sliders, Housings, Stabilizers and Keycaps.
Rebult Keyboards Discord: https://discord.com/invite/4gsPk7Qx
« Last Edit: Thu, 15 September 2022, 21:09:14 by hong@RebultKeyboards »
Re: [GB] SR2 and S23 by Sho, Aluminum Case for Realforce R2 TKL and 23U
« Reply #1 on: Tue, 20 September 2022, 12:55:04 »
Approved :thumb:
