Author Topic: Resin or Wooden Palmrests  (Read 57265 times)
Offline AnnieWX
« on: Mon, 19 September 2022, 10:55:02 »
So i have a keychron K6 and i am wondering if i should get a wooden or resin palm rest i type a lot and i notice my hands are getting really tired after prolonged use i am wondering which one is the best and which do you prefer.
Offline fortissim2
Re: Resin or Wooden Palmrests
« Reply #1 on: Mon, 19 September 2022, 14:03:13 »
Just get what you prefer. After all, you'll be using them for the same purpose. :p
Offline ItIsWritten
« Reply #2 on: Mon, 19 September 2022, 14:31:46 »
Resin is easier to clean. Wooden wrist rests often get oil stains from your palms.
Verstuurd vanaf mijn SM-G986B met Tapatalk
Offline TheMastermind
« Reply #3 on: Thu, 16 February 2023, 22:15:19 »
I usually like using wood over resin since it (wood) tends to be a bit softer feeling to me. Although a lot of resin rests look stunning!
