Author Topic: Help with custom Air75 built  (Read 3054 times)
Offline marouxlas
« on: Thu, 22 September 2022, 10:22:02 »
New user here, please be patient...
I am looking to do my first custom built. Something similar to the NuPhy Air75.
Specs: 75%, low profile, no need for wireless or any lighting, this is a productivity keyboard.
Where it gets tricky is that I prefer keys that are close to each other AND keycaps that have no gap (similar to Air75). A volume knob and a split space bar would be great but not a requirement.
Any help to get me started?
Thank you in advance!
« Last Edit: Thu, 22 September 2022, 10:58:31 by marouxlas »
Offline granola bar enthusiast
Re: Help with custom Air75 built
« Reply #1 on: Thu, 22 September 2022, 14:57:00 »
consider a keycult
Offline marouxlas
« Reply #2 on: Thu, 22 September 2022, 15:14:51 »
Thank you for the feedback. I checked their website but nothing is available and I see no new releases for a year. Any other possible vendors would be appreciated.
Offline neverfail
« Reply #3 on: Sat, 24 September 2022, 08:12:15 »
^ He must be trolling with that keycult recommendation. Do consider a NIZ Micro82, it is a great productivity board with "light-tactile" typing feel. It's not low profile per se, but you can always use a flatter/uniform keycaps if you want.
« Last Edit: Sat, 24 September 2022, 08:15:04 by neverfail »
Offline marouxlas
« Reply #4 on: Sat, 24 September 2022, 11:38:58 »
Thanks for the suggestion. Any keycaps that would have minimal gap between keys?
Offline neverfail
« Reply #5 on: Sat, 24 September 2022, 13:04:34 »
Your best bet would be XDA and NP profile keycaps
