Author Topic: [IC] LM60 M2 - A LM60 variant with brass or steel bars on top  (Read 4708 times)
Offline daviddgm
« on: Sun, 25 September 2022, 06:12:50 »
Hi!
We are thinking about this new design, LM60 M2. Let we know your opinion.
Interest Check Form: https://forms.gle/W5zM7XUExM7uRPi59
Rendered images:
Details
Two top bars of Brass, Steel or PVD
Bottom Aluminum
Case Angle: 6.5 degrees
Mounting: Poron gasket mount or Leaf spring mount - TBD
Case Material: 6063 aluminum
Making process: CNC - sandblast - anodizing
Front Height: 19mm
Back Height: 21mm (with chamfer) and 31mm (before chamfer)
Weight: ~1400g and ~2000g (mounted with brass plate)
Plate:  Aluminum, Brass, PC or FR4
Gaskets: D65 poron gaskets (65x4x3mm) or Rubber spring - TBD
PCB Compability: GH60 style (GH60, DZ60, BM60, etc)
Expected Price
USD 120 more shipping fee
Regards,
Eng. David Martinz - LM Keyboards
« Last Edit: Sun, 25 September 2022, 13:29:23 by daviddgm »
Re: [IC] LM60 M2 - A LM60 variant with brass or steel bars on top
« Reply #1 on: Sun, 25 September 2022, 06:20:02 »
reserved
Offline Neely_12
« Reply #2 on: Sun, 25 September 2022, 09:18:59 »
Please add some information. There is nothing here
Offline vhaarr
« Reply #3 on: Sun, 25 September 2022, 12:16:31 »
I will buy an LM60 when red HHKB comes next month like you said in the LM60 thread.
If this design can support HHKB then I like it :D
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline daviddgm
« Reply #4 on: Sun, 25 September 2022, 13:32:35 »
Yes. We have paid the factory yesterday and them start to make. The red LM60 HHKB Will be done soon. Thank you.
Offline loii
« Reply #5 on: Mon, 17 October 2022, 20:31:58 »
reserved
Offline granola bar enthusiast
« Reply #6 on: Mon, 17 October 2022, 20:39:51 »
can we please make it with arabic text on the back thanks
Offline loii
« Reply #7 on: Mon, 17 October 2022, 21:00:33 »
Liz would be nice
