Author Topic: [GB] JRIS65 - PCB Gasket Mount Custom Keyboard | September 27th - October 3rd  (Read 5396 times)
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hi Everyone,
Great News. The JRIS65 Group Buy is launch today.
As we know, JRIS65 is a budget-friendly and high-quality PCB gasket-mounted, full CNC aluminum keyboard. To let everyone able to experience the higher-end customization, we are working on the typing sound, typing feel, craft, and quality of the kit, which benchmarks mainstream customized keyboards.
JRIS65 GB Info:
SKU and pricing
The pricing does not include any tax and shipping fee. The shipping fee to most countries is around USD30-USD40 from China by express. We also work with local Vendors, some vendors' prices may adjust slightly due to import tax and exchange rate, but the total cost will be cheaper than ordering from the Mykeyclub website.
GB Time: September 27th - October 3rd, 2022
Limited QTY: 3000 worldwide
Estimated Delivery: Start packing and sending to vendors and Mykeyclub direct customers early in January 2023
Vendor list
US: KeebsForAll 12AM EST September 27th
Canada: Ashkeebs  11am PDT September 27th
EU: Candykeys 7PM Berlin (GMT+2) September 27th
UK: Prototypist 5pm BST UK September 27th
Oceania: Daily Clack Working hours September 27th
South American: LatamKeys 6PM ART September 27th
South Korea:Geonworks  7PM Kst (GMT+9) September 27th
Japan: Basekeys 18:00 Japan Time September 27th
Singapore: Mecha.Store  6pm UTC +8 September 27th
Indonesia: KeebsMark  21.00 WIB September 27th
Philippines: Jaekeyed 9PM (GMT+8) September 27th
Thailand & Malaysia: Klackzkrypt 11 AM (GMT+8) September 27th
Vietnam: MOKB STORE  9 PM (GMT+7) September 27th
BeyB 8 Pm (GMT+6) September 27th
Rest of the world: Mykeyclub 10 AM (GMT+8) September 27th
Please register the vendor's mail list or join their discord channel for fast updates.
JRIS65 Info:
JRIS65 design concept is elegant, simple, durable, and comfortable.
Full CNC aluminum case: aluminum top case and aluminum bottom case
Simple and atmospheric front side, and laser engraving of LOGO on the back
The weight on the side is the same color as the bottom so that you can feel the nobility in daily use!
The separate daughter board brings you a better typing experience.
PCB gasket jackets or socks make your building more convenient and simple!
JRIS65 Specifications:
Typing angle: 6°
Front height:19.3mm
PCB GASKETS structure
PCB with USB-C daughterboard
Both PCB and plate adopt flex cut design
PCB gasket jackets or socks (included as default)
QMK/VIA Supported
Support PCB stabilizers
What you can customize for JRIS65?
Case Colors Options: E-White/Yellow/Black/Milky-White/E-White + Black/Maroon + Black/Navy + Black/Titanium Grey+Black/Yellow + Black/Pink
Weight Options:
Anodized Alu Weight: Black, Silver, and Gold
PVD Mirror Stainless steel Weight: Gold, Silver, Black, and Chroma
PCBs Options:
To ensure better quality and typing feel, we adopt the separate daughter board and use JST cable for a more friendly building.
Plate Options: PC/POM/FR4/ALU/Brass (Add-on only)/Black core FR4 (Add-on only)
Plateless Options:
We highly suggest building plateless with 5mm extra plate foam and solder PCB. The 5mm extra plate foam will bring a more soft typing feel, and the typing sound will be cleaner. But without the 5mm plate foam, it will also work fine, and the typing feel and sound are very different.
PCB Specifications
Hotswap PCB support layout
Solder PCB support layout
5.2 Bluetooth hotswap PCB(battery included) support layout.
BT PCB is cooperating with Li Dana. LDN’s PCB is famous in China because his PCBs are stable and qualified and user friendly. It has its drive and software, which can edit the key mapping. Please check the software driver interface here.
-8 devices can pair with it at the same time, and it is easy to switch the devices you want
-The power switch is on the PCB, easy to turn BT function on/off
-The fastest response time is only 1.25ms
-The polling rate for the BT PCB is 1ms/1000hz
-The battery is 1000mA. The working time is from around 15 to 30 days, determined by work intensity.
Note: We highly recommend using a PC/ POM/FR4 plate for BT PCB because the Brass and ALU plate will have a little affection for connectivity.
What's Included?
1x Full CNC Aluminum Case
1x Weight( Anodized Alu/ PVD Mirror)
1x PCB (Hotswap/ Soldered/ Bluetooth)
1x Plate (PC/ FR4/ Alu/POM)
1x Type-C Daughterboard
1x IXPE Foam
1x Poron Plate Foam
2x Poron Case Foam
1x Masking paper for PCB
1x JST Cable
10x gasket jackets
20x gasket socks
1 Set of PCB stabilizers O-ring
1 Set of Footpad
1x Silicone pad of battery compartment (We include this as default, so you don't need to consider choosing which PCB to be the default.)
1x Battery(Only for the Bluetooth version)
Gift(will not send make-up or replacements)
1x USB-Type C keyboard cable
1x Carrying Case
Carrying Case
Review links:
Alexotos build E-White&Black Case+Gold PVD Weight+Hotswap PCB +FR4 plate
TofuTypes build E-White Case+Chroma PVD Weight+Solder PCB+Alu plate+POM plate
Yo_keebs build Milky-White Case+Chroma PVD Weight+Hotswap PCB+POM plate+FR4 plate
sviz build Pink Case+Silver PVD Weight+Hotswap PCB+PC plate
Maybe our voice is weak, but we are working to bring you a good value kit. So, the price is competitive enough to let everyone able to leapfrog to experience a higher-end kit and enjoy the customized experience.
Let's stay tuned for future posts.
Please check the MORE prototype photos below#
Pink Case with Chroma PVD Mirror Weight
Maroon + Black Case with Gold PVD Mirror Weight
Maroon + Black Case with Silver PVD Mirror Weight
Milky-White + Black PVD Mirror Weight
Titanium Grey+Black
Accessories
Mykeyclub is a platform that integrates creativity and innovative design, helping more studios join this hobby community and bringing more fun and cool products to you guys.
For more discussions and future updates, please join Mykeyclub discord
Thank you everyone!
Best Wishes
Mykeyclub Team
« Last Edit: Tue, 27 September 2022, 10:24:41 by Mykeyclub »
Re: [GB] JRIS65 - PCB Gasket Mount Custom Keyboard | September 27th - October 3rd
« Reply #1 on: Tue, 27 September 2022, 16:59:22 »
Approved :thumb:
