Author Topic: What is this rubber ring?  (Read 2810 times)
Offline dnLL
« on: Thu, 29 September 2022, 00:14:46 »
Had this included with a KBD8X MKII keyboard I bought second hand last year, 2 big rubber rings that basically can fit around the whole PCB/plate. Are these supposed to dampen the sound/vibration?
Sent from my Pixel 6 using Tapatalk
Offline MIGHTY CHICKEN
Re: What is this rubber ring?
« Reply #1 on: Thu, 29 September 2022, 00:32:14 »
O-ring, for a gummy oring mount
Although I'm pretty sure its not an official mount and it would be more just scuffed modding kinda mount
Offline dnLL
« Reply #2 on: Thu, 29 September 2022, 00:37:25 »
Thanks, exactly what I needed to be able to search and find more info, didn't know exactly what to search for.
Well. I tried putting one as I've seen in a video (so around the gap between the PCB and the plate) and didn't notice any difference (this is very anecdotal and I'm by no means an expert). I'm using Kailh Box Pale Blue switches with a PC plate and just ordered a foam to improve the hollow/ping reverb coming from the big gap in the case.
