Advanced search
it's a keyboard thing
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Marketplace
Interest Checks
(Moderator:
Signature
[IC] UPDATED Magnetic Artisan Tray - Fragment R | "Covering" All Bases
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [IC] UPDATED Magnetic Artisan Tray - Fragment R | "Covering" All Bases (Read 3459 times)
Ikeygai Designs
Thread Starter
on:
Thu, 29 September 2022, 21:15:14 »
Hi Everyone! Welcome to our UPDATED Artisan Tray IC! We are very excited to introduce our Artisan Tray Series -
FRAGMENT
The Fragment will be a series of trays starting with,
Fragment R
. What makes the Fragment series unique is the integration of magnets within the walls of the tray to connect two or more trays to form various shapes. The idea here is that we will offer different shapes and sizes in the future so that various trays can be used in conjunction with your existing trays to make any shape that you would like to. The magnets are placed in calculated positions so that each individual tray can be connected even in offset positions and not just in a linear placement.
Fragment R will be a 5 X 3 artisan tray with a mirror finish that can be put in any slot OR not used at all if that's what you prefer. There will be 3 magnets along the longer side faces and 2 magnets along the shorter side faces (This can be seen in the render below). The magnets will be held in place with rubber stoppers that will also act as the feet for the tray.
This render is for illustration purposes only
By default the logo on the badge will be the Ikeygai logo, but we plan to also offer the choice of having it blank so people can engrave what they want later on. Additionally the bottom side of the badge will always be blank for customization by owner. The badge is removable and can be used in any of the slots.
So what has changed from our previous IC post?
We are happy to announce that all our trays will now come with a lid! The lid will be a case style lid that will give the tray more of a showcase feel. Instead of just raising the walls of the tray and using a flat style lid that just sits on top, we wanted to do something a little different.
The second thing we wanted to introduce is a stand for the tray. Just like the lid we did not want to just make stand for the sake of making one. We wanted the stand to also fit the modular aspect we have kept throughout the tray design. SO, we went with the below design that resembles a keycap. The stand will come with rubber pads to help keep the tray/stand from slipping or scratching. The idea here is that you can use the different faces of the stand to prop up the tray at different angles and even use it with multiple tray combinations. It can also be used simply as a desk decoration
Interest Check Form
Details:
Tech Specs:
Aluminum 6063 Grade
Anodized Finish (Sand Blasting TBD) & Powder Coating/E-coating
Neodymium Magnets x 10
Badge - Stainless Steel Mirror Finish
15 x 1u Artisan Slots
Lid - Acrylic with UV Protection
Stand - Black Anodized Aluminum
Dimensions:
Tray Dimensions are 123mm x 75mm x 12.75mm
Keycap Slots are 21mm x 21mm, with a depth of 8mm (Center slot depth 4mm)
Badge Dimensions are 20.8mm x 20.8mm x 4.25mm
Lid Dimensions are 123mm x 75mm x 12.75mm; Clearance inside lid is 8mm
Stand Dimensions (Biggest dimensions only); Base 29.3mm x 29.3mm; Height 20.58mm; Angle - 17 Degrees
Pricing:
TBD, Tray will come with Lid but stand will most likely be an optional purchase
Colors:
Black, Red, Yellow and Green - Anodized Aluminum
White - Powder coat or E-coat (depending on volume/interest)
Quantity:
Depending on IC and GB (will update as we get more info from all of you)
Status:
Round 1 of prototyping is done. We are now in round 2.
Will keep this post updated, but quickest way would be to check out our
Discord
channel
Contact (Come say hello!):
Discord
Ikeygai Designs
Instagram
@ikeygai_designs(
https://www.instagram.com/ikeygai_designs
Big shoutout to KingK22(AGAIN) for the amazing renders. You should definitely check out their
page
as well!
Thank you all for support!
Last Edit: Thu, 29 September 2022, 21:25:54 by Ikeygai Designs
Logged
ankit
Formerly ankit-sachdeva
Re: [IC] UPDATED Magnetic Artisan Tray - Fragment R | "Covering" All Bases
Reply #1 on:
Thu, 29 September 2022, 21:27:55 »
you don't need to post a new IC every time you update something
Logged
Ikeygai Designs
Thread Starter
Reply #2 on:
Sun, 02 October 2022, 15:29:22 »
Hi!
Apologies for that. We didn't intend to, but there was something wrong with the other post. It was not letting us modify the attachments and kept throwing an error after modifying and trying to save.
Thanks,
Ikeygai
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
Interest Checks
(Moderator:
Signature
