Author Topic: BM68RGB V DZ65 RGB V3 HOT-SWAP V KBD67 MKII  (Read 3463 times)
Offline Obliv611
« on: Sun, 02 October 2022, 14:26:39 »
Hey peeps. I have been looking for a 65% RGb Hot swappable PCB  for a build i want to put together. But  its been difficult to find a good review of each board.  I have found these three boards
and based off the reviews each one is decent.. minor flaws here and there but over all good. Maybe someone can provide an alternate board
to help narrow down the choice I want a 65% RGB hot swap (would like under glow) but if no under glow it's not a big deal.  I would like it to be optical switch compatible as well
reason for hot swap is this would be a first build for myself and would like a semi easy building process..
If you cant provide more boards that might fit what I am looking for maybe provide alittle more info on the three boards I previously posted.
Any and all info would be super helpful.. TFI
