Author Topic: [GB] Treasure TYPE-9 Brass Macropad ( Series III ) | GB is now live !  (Read 7034 times)
Offline Treasure
  • Industrial Designer / Inventor / Maker
    • Design & Eng
Treasure TYPE-9 ( Series III )
Hi everyone, the GB is now live for the third edition of the Treasure TYPE-9 macropad we are making since 2017.
This new version will come with updated internals and new finish/color options ( IC Thread )
Treasure TYPE-9 is a fully programable metal 9-keys macropad, that can be used for shortcuts, Stream Deck or simply for Artisan display.
QMK & VIA support, compatible with Windows, MacOS and Linux. It also works on iPad ( Works great on Procreate ).
Design-wise, it is a mix of rounded lines and sharp edges, a compact and timeless design that makes it stand out on your desk.
>> JOIN GB HERE <<
Features
  • Crafted from Aluminum 6061 or Solid Brass
  • USB-C interface
  • In-Switch RGB LED
  • 2-piece body construction ( Dedicated Plate and Case )
  • PCB compatible with QMK firmware / VIA
  • Switch Sockets (hot-swappable/no soldering required)
  • Low Profile custom silicone pads with 3M adhesive
Contents
  • 1 x TYPE-9 Case ( Beadblasted Aluminum or PVD Coated + Mirror finish Brass )
  • 1 x TYPE-9 Plate - Bead blasted anodized aluminum ( Grey color )
  • 1 x TYPE-9 Hot Swap PCB ( In-Switch RGB LED)
  • 1 x Treasure USB-C Cable
  • 2 x TYPE-9 Silicone Feets ( Silicone - Grey )
We are proud to present our new finishes : Matte Black, Purple, Silver, Green, Jet Black Mirror (Brass) and Bronze Gold Mirror (Brass), E-White is back.
Solid Brass Special Editions :
Full brass case ( 370gr )
  • Full Solid Brass / Jet Black Mirror ( Jet Black PVD coating + Mirror Polish )
  • Full Solid Brass / Bronze Gold Mirror ( Bronze Gold PVD coating + Mirror Polish )
Aluminum Anodized versions
    Beadblasted Anodized Aluminium ( 150gr )
    • Aluminum / E-White ( Electrophoresis coating )
    • Aluminum / Matte Black
    • Aluminum / Anodized Green
    • Aluminum / Anodized Purple
    • Aluminum / Anodized Silver
Price List:
  • Treasure TYPE-9 / Aluminum Versions - $119
  • Treasure TYPE-9 / Brass Versions - $159
Extras Price List :
  • Extra TYPE-9 Feet  ( 10 beautiful colors ) - $7
  • Extra TYPE-9 Plate ( 4 available finishes ) - $12
  • Extra TYPE-9 Carrying Case ( Grey and Red ) - $19
  • Extra TYPE-9 DSA Line - Keycap Set ( WoB and BoW ) - $13
  • Extra TYPE-9 PCB - $29
Group Buy Opens September 30th, 2022 @ 08:00PM CEST ( Duration: 1 month )
Vendor : Treasure ( http://treasuretypes.com )
Estimated Ship Date: Early Q2 2023
Prototypes :
Other Info
And one more thing, thanks for your amazing support during the Series II run of the macropad.  :)
Below photos by @alexotos, @macherstudio @karanchauhan @tinymakesthing, @elyxyrine and @backslashrabbit of TYPE-9 Series II
>> JOIN GB <<
[/list]
« Last Edit: Sun, 09 October 2022, 07:42:23 by Treasure »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Treasure TYPE-9 Macropad ( Series III ) | GB is now live !
« Reply #1 on: Tue, 04 October 2022, 03:17:53 »
Approved
Offline Treasure
    • Design & Eng
« Reply #2 on: Tue, 04 October 2022, 04:09:51 »
Thanks !
Offline Treasure
    • Design & Eng
« Reply #3 on: Wed, 05 October 2022, 06:45:24 »
Bronze Gold Mirror PVD / Solid Brass version :
Offline Treasure
    • Design & Eng
« Reply #4 on: Sun, 09 October 2022, 07:38:58 »
DSA Line keycaps are available alongside the GB for $13 :
https://treasuretypes.com/products/type-9-dsa-keycap-set
Offline Treasure
    • Design & Eng
Re: [GB] Treasure TYPE-9 Brass Macropad ( Series III ) | GB is now live !
« Reply #5 on: Mon, 24 October 2022, 08:06:53 »
One week remaining !
Offline Treasure
    • Design & Eng
« Reply #6 on: Wed, 02 November 2022, 10:15:31 »
Hello to all.
We have started procurement and fabrication for the macropad
Updates will be displayed on https://tre.sr/updates and on the Discord channel http://tre.sr/discord
Stay tuned
