Author Topic: Apple Extended Keyboard II Foam Pads  (Read 3137 times)
Offline apastuszak
« on: Sun, 09 October 2022, 10:21:47 »
I am the proud owner of an Apple Extended Keyboard II, that I picked up last Thursday.
I'm waiting for an ADB to USB adapter to arrive in the mail.
Today I noticed the space bar was sticking. I pulled it off, and discovered that there are two small square foam pads on the right and left side of the space bar right under where the stabilizers snap in. Both pads had disintegrated, but the one on the right exposed the double-sided tape used to stick it to the keyboard and the stabilizer was sticking to that piece of tape.
A Q-Tip and some Windex and now the space bar no longer sticks.
What was the purpose of the foam? Sound dampening? Key fell?
Should I replace the foam, or just leave it as-is?
Offline Nerif
Re: Apple Extended Keyboard II Foam Pads
« Reply #1 on: Mon, 10 October 2022, 12:58:30 »
If it works fine in the end, then, I guess, you shouldn't do anything with it.
̷C̷M̷ ̷Q̷F̷ ̷X̷T̷ ̷[̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷u̷e̷ ̷→̷ ̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷a̷c̷k̷ ̷H̷y̷p̷e̷r̷g̷l̷i̷d̷e̷]̷
Anne Pro 2 [Gateron CAP Brown → Kailh BOX Dark Yellow]
Offline ShawnMeg
« Reply #2 on: Tue, 11 October 2022, 20:59:16 »
Mine came off.  I never replaced it, and it never gave me any problems not having them.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
