Author Topic: [IC]M·one Tata80 Updates-WK/WKL Solder PCB,Typing test and Custom F13 badge Vote  (Read 19031 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
Hi Everyone,
Thank you for being so interested in Tata80 so far! We would love to share some updates with you and looking forward to your further feedbacks.
Tata80 Keyboard kit Gallery
Update
1. Add extra solder PCB compatible with both WK/WKL ( Add-on, MOQ: 100 pcs)
2. Tata80 Typing sound test list
* All foam, swan gasket
* All foam, silicon gasket
* No foam, swan gasket
* No foam, silicon gasket
3. Custom F13 badge vote
Streamers/Youtubers
We sent Tata80 keyboard kits to some streamers and YouTubers, we will share with you once any of them have a schedule.
- Alexotos - E-white x Copper, WKL Layout ( Time: TBD)
- Clackbait - Green x Copper, WKL Layout ( Time: TBD)
- Xingxing wong - E-white x Copper, WK Layout
Tata80 Keyboard Kit Highlights
  • Modular Gasket Design
  • Custom F13 PVD badge
  • WK and WKL Layout
Two kinds of gasket mount methods
There are both Swan gaskets and Silicon Gaskets, both of which are removable and reusable for your choice.
The Swan gasket is inspired by the car leaf spring structure. The main reason for using leaf springs as an elastic component on the car is that, apart from linking the axle to the car body, they can act as cushioning force and shock absorption. While there are so many gasket mount designs in the market, the elasticity provided gives more support to the plate and PCB, while allowing it to move always touching the metal sheets. Thus it can be bouncy but with enough support all the time.
Based on this design principle, M·ONE Studio designed a spring gasket that is shaped like the neck of a swan, so it was called the Swan gasket.
Comparison of the Swan gasket with the Silicon gasket
  • The Swan gasket has better flexibility. When typing the keyboard, the Swan gasket acts as a cushioning and shock absorption function just like the leaf spring structure of a car, which makes the Swan gasket module feel softer in comparison to the silicone gasket.
  • The Swan gasket can be quickly removed and replaced. Please check the installation video of the swan gasket here 
Having fun is one of the reasons we design every board. So is for Tata80. When we set a default badge for F13, we also try to work out more badges to make it more unique for you.
F13 PVD designs
WK and WKL Layout
- WKL Version PCB
Wired, hot-swap, supports QMK/VIA, 1.2mm thick, flex cuts.
- WK Version PCB
Specifications
Typing angle: 7 degrees
Dimension: 368*140* (20-30) mm
Front Height: 18.7mm
Weight (unbuilt): 1.80 kg
Case Material: 6063 Aluminum
Mounting Method: Gasket Mount
Support ANSI Layout
PCB Specifications:
Hot-swap PCB: 1.2mm thick
QMK/VIA support
WK or WKL layout
ESD Protection
Tata80 WK/WKL Default Kit Contents:
  • Aluminium Top and Bottom Cases
  • Plate (TBD)
  • Hot-swap wired PCB
  • Internal Brass weight
  • Poron foam under the top case
  • Plate foam
  • IXPE switch foam IXPE
  • AI03 daughter board
  • JST cable
  • Swan gasket modules
  • Silicone gasket modules
  • Case Foam
  • Keyboard feet
  • Screw and hex screwdriver
  • M·ONE Stabilizers
Colors: E-white x Copper, Green x Copper, Black x Red, Green x Black, E-White, Black, Grey
Estimated GB price and GB time
GB Price: Within 300 USD
GB time: November, 2022
Tata80 keyboard kit design updated improvement
Tata80 Previous design
We post current design based on its feedback in China.
May 2022- released the first IC post of Tata80 in China.
Updated improvement
- Removed the PVD accents from the four front corners of the Tata80 keyboard
- External weight adjusted to the internal side
The initial version of the Tata80 keyboard kit design in China
The final version of the Tata80 keyboard kit design in China
The board already finished GB in China and gets more ready to meet users' needs outside China. We would love to see your ideas too. If you are interested in this kit and/or have any suggestions, please fill in the Tata80 IC form and join the Tata80 discord channel in Wuque Studio’s Discord server. Thank you.
« Last Edit: Thu, 03 November 2022, 22:25:49 by Ckeeb »
Offline Neely_12
Re: [IC] M·ONE Tata80 - A Swan Gasket Mount keyboard kit
« Reply #1 on: Fri, 14 October 2022, 09:59:31 »
Like the bezels and badge. Please add stepped caps and a normal 1.6mm pcb with no cuts.
Offline DirtyGingy
« Reply #2 on: Fri, 14 October 2022, 10:05:11 »
I'm tired of the flex cut focused boards. It kills sound. A nice design though
Offline Ckeeb
    • MELETRIX
« Reply #3 on: Fri, 14 October 2022, 10:15:48 »
Thank you. We will consider your suggestions, please also fill it in our IC form.
Offline Ckeeb
    • MELETRIX
« Reply #4 on: Fri, 14 October 2022, 10:17:21 »
We will forward it to the designer, stay tuned. Thank you.
Offline HugoChowsky
« Reply #5 on: Fri, 14 October 2022, 10:43:33 »
Please stop with the F13 without 7u Tsangan bottom row for WK.
7u Tsangan bottom row should be the standard for any custom mechanical keyboard.
Offline derPuntigamer
  • NorDe is nonnegotiable
« Reply #6 on: Fri, 14 October 2022, 11:41:50 »
God forbid! Why would that cringe layout should by default on anything? Any practical reasons? Do we need a 0.75 unit longer spacebar? Do we need non-uniformly sized modifier keys in the bottom row?
What could be offered instead as a standard feature is ISO support
Offline Keeblet_257
« Reply #7 on: Fri, 14 October 2022, 15:33:10 »
why no solder?
why no iso?
why no 1.5u 1u 1.5u 7u 1.5u 1u 1.5u bottom?
why is 7u only supported when I get WKL?
for a 400€ TKL I expect more lazout support.
ps.
I know its trying to stay within 300$ but I also know that those 300$ wont include shipping and EU taxes.
Offline mr_foggy
  • neue = nope
« Reply #8 on: Fri, 14 October 2022, 17:41:41 »
do you even realize wk can be built with a 7u right?
really fed up with flex centered boards though. skipping with 0 regrets.
Offline Its Salty
  • I have no idea what I'm doing
« Reply #9 on: Fri, 14 October 2022, 20:12:05 »
Board seems a bit uninspired, like the mount was thought of first. and then a board was built around it. or rather you just slapped it in a large Ginkgo
I do like the designs of the little F13 plate art, but wish that same thought was put into the giant flat face on the back
it's a giant canvas for artists, that's not seeing its true potential...
« Last Edit: Fri, 14 October 2022, 20:34:22 by Its Salty »
Offline aicyborg
« Reply #10 on: Fri, 14 October 2022, 21:16:03 »
I'd rather have an F13 key and a badge, engraving, design, or just... anything above the arrow keys. You know, the huge empty space you could totally use for a ton of different things? :)
Also, please add ISO. We never get hot-swap capable ISO PCBs with any of these, and it'd be nice and definitely make this more appealing in Europe.
Offline Jaoush29
« Reply #11 on: Sat, 15 October 2022, 00:59:21 »
Really like this aesthetic!
Offline Ckeeb
    • MELETRIX
« Reply #12 on: Sat, 15 October 2022, 09:02:07 »
Hi, Thank you so much, if you have any ideas please fill out our IC form and we'll check it out! :)
Offline Ckeeb
    • MELETRIX
« Reply #13 on: Sat, 15 October 2022, 09:04:51 »
Hi,Thank you so much. We will consider your suggestions, please also fill it in our IC form. :)
Offline Ckeeb
    • MELETRIX
« Reply #14 on: Sat, 15 October 2022, 09:12:13 »
Hi, appreciate it. :)
Offline Ckeeb
    • MELETRIX
« Reply #15 on: Sat, 15 October 2022, 09:19:22 »
Hi, thank you so much. We will consider your suggestions, please also fill it in our IC form. We will forward it to the designer, stay tuned.
Offline Ckeeb
    • MELETRIX
« Reply #16 on: Sat, 15 October 2022, 09:22:26 »
why no solder?
why no iso?
ps.
Hi,Thank you so much. We will consider your suggestions, please also fill it in our IC form.  We will forward it to the designer, stay tuned. :)
Offline Ckeeb
    • MELETRIX
« Reply #17 on: Sat, 15 October 2022, 09:29:20 »
Hi, thank you so much. We will consider your suggestions, please also fill it in our IC form. We will forward it to the designer, stay tuned. :)
Offline Ckeeb
    • MELETRIX
« Reply #18 on: Sat, 15 October 2022, 09:29:45 »
Offline Ckeeb
    • MELETRIX
« Reply #19 on: Sat, 15 October 2022, 09:30:14 »
Offline HugoChowsky
« Reply #20 on: Sat, 15 October 2022, 10:16:24 »
If you think about it then it makes sense, but it should be clearly stated in the layout choices image???
If Wuque wants people to be interested in purchasing their product, then please present clear information.
It is just basic principle.
Offline Tokyo-65
« Reply #21 on: Sun, 16 October 2022, 16:42:49 »
looks like a great follow up to the gingko65, the top case follows a similar design layout. Good luck with the group buy.
Offline IconlabsOfficial
  • Where makers make art!
    • Iconlabs
« Reply #22 on: Tue, 18 October 2022, 01:44:44 »
Now, a soundtest video please!
Offline Ckeeb
    • MELETRIX
« Reply #23 on: Sun, 23 October 2022, 21:06:46 »
Thank you.  :thumb:
