Author Topic: [GB] Blueberry | Bouncy 65% featuring seamless wave profile & Blue PVD. Closed  (Read 35661 times)
Offline Toffee Studio
    • Toffee Studio
292311-0292309-1
Interest Check        Discord Server
Blueberry Group Buy
Closed, manufacturing 2/3
ClickClack
KEYGEM
DangKeebs
Chosfox
Limited GB: 500 units (125 per vendor)
Estimated Fulfilment: Q2 2023
Pricing: $379USD $359USD Base kit
Limit: 2 per household
Reviews and Builds
Official Trailers and Build
PCB:
Solder only, QMK & VIA supported, optimized underglow LEDs. Standardized PCB support
Plates:
Universal PC included with base kit, POM, FR4, Brass, Aluminum sold separately
292317-2
All editions ship with:
1x Anodised 6063 Aluminum Top Piece
1x Bottom Piece (6063 Aluminum or Polycarbonate)
1x Polished PVD Brass Badge
1x Polished PVD Brass Weight
1x Polycarbonate 1.5mm Flex Plate
1x Blueberry 1.6mm Flex PCB
1x Laser-Cut 3mm Poron Plate Foam
1x Laser-Cut 2mm Poron Case Foam
1x Laser-Cut 0.5mm PE Foam
6x Laser-Cut 2mm Upper Case Poron Gaskets
6x Laser-Cut 4mm Lower Case Poron Gaskets
x1 Black M2 5mm Badge Screw
x6 Black M2 18mm Case Screws
x4 Black M2 5mm Weight Screws
x4 Case Feet
Specifications:
Mounting style: Gasket-mount
Dimensions: 318mm x 116mm
Typing Angle: 5 degrees
Firmware: QMK Firmware with VIA support
Connectivity: USB-C
Layout: 65% with blocker and top-right badge, Tsangan & ISO layouts supported via universal plate.
292315-3
« Last Edit: Mon, 24 April 2023, 23:01:44 by Toffee Studio »
Re: [GB] Blueberry | Bouncy 65% featuring seamless wave profile & Blue PVD.
« Reply #1 on: Sat, 15 October 2022, 04:44:04 »
Approved :thumb:
    • Toffee Studio
« Reply #2 on: Sat, 15 October 2022, 04:51:37 »
Update 21/03/2023
- Manufacturer payment sent, manufacturing for cases to begin ASAP!
- Hotswap PCBs likely to be made. Please continue to fill out the form in ⁠announcements if you're interested, placing "EXTRAS" in the order number section if you plan to order one with an extra unit after GB units ship.
Additional updates will be given by regional vendors.
Update 29/03/2023
Hotswap PCBs are to be added to the production queue.
Confirmed 20-25 units to be made, sold post GB as in-stock items.
Manufacturing estimate from factory - Around end of April
(Blueberry Base Kits) (edited)
Update 7/04/2023
Lots of machining. From counting, around 25 cases were machined, incl. brass weights
Pending some factory photos when we can get those first finished batches done
Update 8/04/2023
Almost 33 cases have been manufactured thus far. Not much to update during this stage of production, but we'll start releasing updates more often once we have more than 110 cases machined. As we don't want to interfere with any cases until they are finished, pictures won't be provided until the sandblasting and anodising steps are completed.
Thanks again everyone, looking forward to smooth production and fulfilment of Blueberry in the upcoming weeks.
Mini update! Cases are halfway in anodization and sandblasting. Here are a few example extras for reference.
298587-0
Smoother finish appearance achieved through increased sandblasting grit. Apologies for the video compression
* Sandblasting finish.mp4 (6938.4 kB - downloaded 124 times.)
Note: These are sample units, customer units are not used for videos.
New magnetic packaging boxes are in! Made to be much more durable and reliable than the V1 box. Here's the new box you'll receive units with.
298590-2
298592-3
« Last Edit: Mon, 24 April 2023, 22:42:03 by Toffee Studio »
Offline chaucer
« Reply #3 on: Tue, 18 October 2022, 20:10:25 »
This blue color looks very comfortable
Offline stidal
  • milo#3939
« Reply #4 on: Tue, 18 October 2022, 21:41:30 »
where daughterboard
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline kbsomarks
« Reply #5 on: Fri, 28 October 2022, 01:54:03 »
Wow! What a pretty board. Am really llooking forward to getting in on this one, but limited units concerning... Hopefully I have some luck :thumb:
Offline KbJohn911
« Reply #6 on: Sun, 30 October 2022, 09:12:07 »
Came here after seeing your videos on youtube. Have to admit it's very appealing especially with the amount of flex that I've seen so far  :eek:
Offline Springpocket
« Reply #7 on: Sun, 30 October 2022, 10:21:01 »
have they fixed those flaws that was pointed out in the keybored video?
Offline superjackie
« Reply #8 on: Mon, 31 October 2022, 04:35:58 »
please consider 7U stepped cap Hotswap, and other plate options (not as add on only, because dont need two plates...) ty
    • Toffee Studio
« Reply #9 on: Mon, 31 October 2022, 08:03:09 »
Yes, these issues have been addressed with an extensive QC process including an allocated period prior and subsequent to the manufacture process for ironing out any quality issues. Unfortunately, this was a shortcoming of our prototypes and will not be present in GB units.
Offline MattVortex
« Reply #10 on: Tue, 01 November 2022, 08:36:26 »
What's the front height?
    • Toffee Studio
« Reply #11 on: Wed, 02 November 2022, 05:59:59 »
The front height is 20.1mm.
    • Toffee Studio
« Reply #12 on: Thu, 03 November 2022, 07:52:58 »
Hi everyone! We're happy to be able to provide a sneak-peek of the new E-White prototype via our factory.
Have a look. 🙂
Offline Takaoster
« Reply #13 on: Fri, 04 November 2022, 00:15:34 »
Have a look. 🙂
wow the e-white edition is very very nice, gotta get my hands on this  :eek:
    • Toffee Studio
« Reply #14 on: Fri, 04 November 2022, 08:03:26 »
Group Buy in 9 Hours!
PRODUCT WILL GO LIVE AT https://toffeestudio.com/shop AS A SEPARATE PRODUCT. THE EXISTING PRODUCT IS A PLACEHOLDER.
    • Toffee Studio
GB Live now.
Offline mrtn_mo
  • still boppin
Why no shipping to Norway?
    • Toffee Studio
It's been added  :thumb:
Offline MattVortex
Is the included plate universal or ANSI layout? Does the included PCB support ISO?
    • Toffee Studio
The included plate is universal, and yes the PCB does support ISO  ;D
Offline KBKlon
Are feet now included with the base kit (some reviewers claim their unit did not come with any feet). Not a big deal but would be nice to know everything that's included
EDIT: Nvm. saw the latest prototype video a few posts above. Feet cutouts have been made so it's safe to assume feets will be included.
« Last Edit: Mon, 07 November 2022, 02:29:46 by KBKlon »
Offline MattVortex
Is everything ok with the group buy site? I'm getting an "Unable to process payment" error.
Offline Takaoster
Yeah I had this issue too but just tried another time and it seemed to work...
Good luck though!
Offline MarkoFloro
Really underrated board, brings together so many nice features definitely will be copping.
Offline MarkoFloro
Is the default plate ANSI or Universal support?
    • Toffee Studio
The default plate is the universal plate, but we also offer ANSI in plate extras :thumb:
Offline kbsomarks
Just copped, looking forward to it  :)) :))
    • Toffee Studio
PayPal added. Only PayPal is currently operational currently due to payment issues. We are working on the payment issue  :thumb:
    • Toffee Studio
Unfortunately, all orders originally purchased with Stripe have been refunded due to issues with the payment system. We are now offering the Blueberry at $359 USD, and $366 USD for E-White editions.
    • Toffee Studio
Hello everyone!
The vendors for the Blueberry launch on the 26th of December are:
ClickClack.io (CN & Worldwide base) 🗺️
KEYGEM (EU based) 🇪🇺
DangKeebs (USA based) 🇺🇸
Chosfox (CN & Worldwide base) 🗺️
Vendors are not region-locked, 125 units per vendor
ℹ️ Loyalty badges are provided via form on:
http://toffeestudio.com/loyalty
This is a custom rainbow PVD (Oil-Slick) colorway badge provided free of charge for all re-orders.
Existing order numbers and new order numbers are required.
Offline Eatthereet
HYPED!  ;D
Offline CookieFlow
Had followed this board a while ago and always liked it.
Any reason why e-white top / electric blue bottom isn't a thing?
Or even full electric blue? electric blue top / PC bottom?
I would have liked to go for one of these combos (especially full electric blue or electric blue top / PC bottom), but I am a bit puzzled on why they aren't offered since all these colors are being made either way so it shouldn't add much complexity.
I feel that electric blue (as well as the blue PVD) are some of the highlights of this board for me being very unique in a sea of black, white, silver, red, navy boards.
Just a bit of a shame that there is only one option for that electric blue and it's on the bottom of a black top board.
« Last Edit: Mon, 26 December 2022, 16:48:27 by CookieFlow »
    • Toffee Studio
The colors chosen were based off a community poll. Due to logistical reasons, we had to restrict the colour combinations, and our polling showed that the numbers for these combinations were much lower.
We will consider emphasising lighter color options in the future.  :thumb:
Offline lowsmaxduncan12
 Love the idea of the oilslick badges :eek:
    • Toffee Studio
:3ildcat Typing test video #2 coming soon!
    • Toffee Studio
These are the loyalty badges :)
    • Toffee Studio
Update 19/1/2023 AEST
GB remains open. Units to be manufactured regardless of MOQ. Thank you for your patience everyone during this time :)
Offline SoloMilo
Just saw the 3ildcat video on the E-White unit, looking stunning. The E-white is also sandblasted right?
    • Toffee Studio
It is electrophoresis coating, if you’d like to know more about the process we’re happy to receive an email. There should be other posts explaining this process :)
Offline SoloMilo
Just sent an email! Also just wanted to make sure the flex in the final production units will be just as much as the ones from youtube reviewers right?
    • Toffee Studio
Yes, the units displayed in the reviews are identical in design. As long as the same configuration is followed, it will be the same :)
Thanks for your interest.
Offline SoloMilo
Appreciate your swift responses, thanks!
Offline hirashidan
Just got my hands on one of these bad boys but I ordered the extras from a different vendor  :confused:
How can I merge the shipping cost of this? I know it's quite stupid of me
    • Toffee Studio
Please contact us via ticket on discord or email at contact@toffeestudio.com
Offline hirashidan
Done!  :cool:
Offline Iceman15491
I'm guessing the GB is almost coming to an end, do I have much time left to get my hands on this?
    • Toffee Studio
GB closes 26th February. The board won't run again so this is the last chance to get a Blueberry :)
Offline Iceman15491
guess I got no choice but to get it haha
Offline SoloMilo
Ordered ages ago and the wait is kiiiiiling me  :eek:
    • Toffee Studio
Blueberry Group Buy ending in 3 days!
