Author Topic: Can't get rid of ticking on the right side of the sb stabs  (Read 4085 times)
Offline isco19
« on: Mon, 24 October 2022, 15:52:07 »
Cant get rid of ticking just on the right side of the spacebar. I have tried holee mod, balancing wires, dielectric grease, krytox 205g0, different spacebar, switch, owl and durock stabs to no avail. Happening on a qk65.
imgs: https://imgur.com/a/SBwSrKU
Any idea what might be causing that or any workaround?
Thanks in advance.
« Last Edit: Tue, 25 October 2022, 05:56:55 by isco19 »
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
Re: Can't get rid of ticking on the right side of the sb stabs
« Reply #1 on: Tue, 25 October 2022, 08:02:12 »
I really can't think of anything that you haven't tried. Tailor's mod perhaps?
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline granola bar enthusiast
« Reply #2 on: Tue, 25 October 2022, 10:09:36 »
use more dielectric grease
Offline Sup
« Reply #3 on: Wed, 26 October 2022, 08:24:45 »
Durock is bad og cherry stab ins are the best
current
Coming soon
Offline mohawk1367
« Reply #4 on: Sun, 30 October 2022, 16:27:08 »
only if ur on a budget
Offline lakeboredom
« Reply #5 on: Sun, 30 October 2022, 17:40:35 »
Is your key cap straight? There's the hot water trick. Foam under the wire. Syringe with super lube or krytox from the back.
Sent from my moto g power (2022) using Tapatalk
