Author Topic: isopropyl alcohol removed blue switch click  (Read 4928 times)
Offline poopeejohnson
« on: Wed, 26 October 2022, 13:05:31 »
When any of my blue switch keys start having key chatter, I apply a few drops of isopropyl alcohol and pressing and blowing into the switches. This usually removes the key chatter. For example, today I had key chatter on my W key so I did the usual steps and it got fixed, however, a few hours later my D key started having key chatter so I did the usual steps to remove key chatter and it got removed but after about 30 mins, the D key lost its click. I tried the usual key chatter removal steps again and it temporarily regained its click but then lost it after about 20 mins. What can I do to restore the blue switch click without desoldering?
Offline PlayBox
Re: isopropyl alcohol removed blue switch click
« Reply #1 on: Wed, 26 October 2022, 14:10:08 »
On first glance I read it as: "Rowdy's sick of common answers .... "
and assumed that it was going to be a list of FAQ-type stuff that keeps popping up with annoying frequency.
the fix to your problem is to just buy a new keyboard, first it won't chatter if you buy a good one and if you get a good one with hotswap you could get kalih box jade/navy/white/pink for even better clickiness than blues
propably sent from my amazon kindle 10th gen
« Reply #2 on: Wed, 26 October 2022, 14:40:54 »
how can you know if a keyboard is good enough so that it won't chatter
Offline PlayBox
« Reply #3 on: Wed, 26 October 2022, 23:10:55 »
quality keyboards don't chatter
« Reply #4 on: Thu, 27 October 2022, 05:37:41 »
What makes a keyboard quality? Is there certain makes or switches that do/ do not get key chatter?
Offline PlayBox
« Reply #5 on: Thu, 27 October 2022, 11:24:32 »
also from what i heard worn out hotswap sockets and badly applied solder cause the chatter, i'd reccomend getting a good quality mechanical keyboard from vendors like epomaker, keychron, akko, kbd fans etc. they won't let you down as long as you will watch reviews
« Reply #6 on: Thu, 27 October 2022, 12:23:06 »
ok thanks
Offline granola bar enthusiast
« Reply #7 on: Thu, 27 October 2022, 16:17:08 »
do this to all your switches until you have a linear switch keyboard
