Author Topic: EMT V2 Switch Review  (Read 13967 times)
Offline ThereminGoat
« on: Sun, 30 October 2022, 10:57:03 »
Hey all,
Without much other information out there about them, I could help but be intrigued by the new EMT V2 switches since I use EMT V1s in my daily work board. However, upon immediate inspection these new switches not only look nothing like the originals, but weren't even made by the same manufacturer. So take a look here to see if the newest iteration of EMT switches live up to the reputation of that one anime princess Emilia from Re:Zero, or something. (I have no idea, I just know that's what the name is based on...)
Website: https://www.theremingoat.com/
Article: https://www.theremingoat.com/blog/emt-v2-switch-review
Scorecard Repository: https://github.com/ThereminGoat/switch-scores
Force Curve Repository: https://github.com/ThereminGoat/force-curves
Patreon: https://www.patreon.com/theremingoat
As always, thank you all for the continued support and readership of these reviews. In especially more busy weeks with a much more challenging schedule to navigate around for writing time, its the support I get from you all that makes it a bit easier.
Cheers,
Goat
Offline DashanYYY
    • Unikeys
Re: EMT V2 Switch Review
« Reply #1 on: Thu, 16 March 2023, 16:41:15 »
Didn't know that the V2 was made by Haimu. Haimu created some of the best quality switches that come at a fair price. I guess I need to try the V2 this time.
